Like Tree19Likes
Old 02-03-2005, 02:34 PM   #3166
utieh's Avatar
Originally posted by Tbevofreak
Guys, do you need to buy the steel diff assembly when using the lightened steel outdrives?
Or can you just use the stock assembly with it?
Thanks!!
yes the diff rings and the nut are different.
I've also removed the shims in the input shaft and one on the diff on the gear side, it's quite free now.
TBEVOFREAK, do you use Corally plugs?? it seems that it is needed to Dremel the chassis a bit to make them fit...
utieh is offline   Reply With Quote
Old 02-03-2005, 02:57 PM   #3167
ChrisP's Avatar
Send a message via Yahoo to ChrisP
I mounted my Corally plugs on battery bars and it works great
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 02-03-2005, 03:01 PM   #3168
utieh's Avatar
Do you buy some special battery bars or do you bend them yourself, I saw MuchMore makes some.
Old 02-03-2005, 03:03 PM   #3169
Utieh,
yes I use Corally plugs but I re-soldered the plugs higher on the batteries so it would fit.
You can trim the chassis also but I think its easier to solder the plugs in a different way.
Me also I took out one shim out of each diff and its much better!
Did you take out all the shims off the shaft?
See you!
Tbevofreak is offline   Reply With Quote
Old 02-03-2005, 03:18 PM   #3170
utieh's Avatar
Yes I removed first one shim from the diff, then the one from the input shaft and finally both of them, at least now I can get 3 second of spin, driving the car will do the rest, I was just afraid to remove too much shims, I used to break a lot of oneway gears on my SD because they were to much back lash with the oneway diff in the gear case...
you should remove each shim one after another and see what happens.
Old 02-03-2005, 04:03 PM   #3171
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Originally posted by utieh
I didn't even finish to build it...everything is done but lie you the drivetrain doesn't spin more than a second, had tried different shimming, removed the grease out of the bearingbut it's not really free, I found a way to mount a Mabuchi with some thick shims, I will break in the transmission tomorrow.
Unfortunately I'm working the whole week end so I won't be able to try it this week, maybe next week end
Mine spun for 5-10 out of the box with no changes. If yours isn't, you did something wrong.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 02-03-2005, 05:08 PM   #3172
lie = like
MartynD is offline   Reply With Quote
Old 02-03-2005, 11:46 PM   #3173
Boomer's Avatar
ahhhh - color me an idiot - editing my post. . .
Old 02-03-2005, 11:57 PM   #3174
Are the shock towers easy to break on TC4? both regular and graphite.
ME-student is offline   Reply With Quote
Old 02-03-2005, 11:59 PM   #3175
Bob Nilsen's Avatar
No... I've yet to break a shock tower.
Bob Nilsen is offline   Reply With Quote
Old 02-04-2005, 12:03 AM   #3176
utieh's Avatar
Your smile is a little bit suspicious on your avatar, are you sure with the stock shimming it spun for 5-10s??
I can probably get 4-5sec now, but after removing almost all the shims...
The stock plastic shock towers are a little bit flexy, but I never heard about breaking them.
Old 02-04-2005, 12:18 AM   #3177
RCknight's Avatar
Default Anyone have the BMI upper deck....
for the tub chassis? If so how does it work?
RCknight is offline   Reply With Quote
Old 02-04-2005, 12:59 AM   #3178
Speedie's Avatar
Originally posted by runnin rc10
What do you mean even with the board. Wouldnt this mean that the wheels wouldnt have already been touching it? I would thing that with no droop/limiting in the suspension that with the shocks fully extended that they would already touch the ground. Why did these cars have to incorporate this adj. it only makes for my headaches!
I Screw both sides screws in until both wheels are off the board then drop them down till they are just touching with the board evenly.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 02-04-2005, 02:55 AM   #3179
I agree with utieh, I wonder how you got 5-10 secs of free spin?
I only removed some shims on the diffs and it spins for 2-3 secs
I'm tired of all this free drivetrain thing, I'll just run the car a coule of times and it should do the job
But I have to admit, I'd love to have a drivetrain that spins for 5-10 secs I sould've bought a PRO4!
Sock towers shouldn't break unless big crash
Cheers!!!!!!!!!!!!!
Old 02-04-2005, 04:18 AM   #3180
I had 1-2 secs free spin, until I removed a few shims now up to 2-3 secs, I suppose if I hooked up the dremel to the back wheel I could get it to spin for at least 5-10 secs...
Break the car in TB, and heh don't judge a car based on free spin.
I've seen people break the plastic and carbon shock towers (rear anyways) usually just after flipping the car and hitting the end boards at the end of the straight. (so hitting the boards with the top of the car)
My car is going great and my driving is progressing nicely, now I just need to find a bit more steering at high speed power on, and a bit less steering at low speed power off...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
