Like Tree18Likes
Old 01-31-2005, 12:22 PM   #3076
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Default Re: Need an answer... QUICK!
Originally posted by Paul_TC4
Does anybody know how much lighter the "lightened" outdrives are compared to the steel ones that come with the tc3?
Thank alot....
Btw,
I actually dug up my gram scale yesterday and compared the IRS aluminum and the Associated diff halves. The steel ones are 14 grams heavier than the IRS with the full assembaly.(bearings, ring, etc.)
Paul_TC4 is offline   Reply With Quote
Old 01-31-2005, 02:03 PM   #3077
O.K. so this is probably a pretty dumb question. But what is the stock TC4 chassis made out of. I just got the TC4 carbon component kit, and it looks like the same stuff. Can someone tell me if I got the right kit is the carbon kit the same as graphite? And if not where can I get the graphite kit?
caleracer45 is offline   Reply With Quote
Old 01-31-2005, 02:08 PM   #3078
Originally posted by lastplace
Thanks for the link. I put the spring on the wrong side. Wish Assoc. would have included the instructions with the part.
Don't feel bad, after posting my diff question on previous page, I took it apart again, and I had put the spring on the wrong side as well!
I was not using the gear that came with the TC4 kit, I had bought a replacement. Seems better now, but not "buttery" smooth as I have heard some describe!
Paul
paulct is offline   Reply With Quote
Old 01-31-2005, 02:11 PM   #3079
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
the carbon kit is a little greyier in color
Roberto Falcon is offline   Reply With Quote
Old 01-31-2005, 02:13 PM   #3080
Thanks LOSI I guess it is now that I look at them side by side
Old 01-31-2005, 02:30 PM   #3081
lastplace's Avatar
Send a message via Yahoo to lastplace
Ok this is going to my last diff question...
The TC4 comes with #3916 bearings, the Steel outdrive instructions call for #6909 bearings. Are they interchangeable?? The LHS does not have #6909's so I cannot compare the two.
lastplace is offline   Reply With Quote
Old 01-31-2005, 03:26 PM   #3082
Greg Amendola's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to Greg Amendola
Default Shock Stiffness and High-bite carpet setup
The stiffness has alot to do with shock angles and the location of the shock ends.
If you stand the shock up more, the more stiff and less progressive it will become. This will reduce roll and will reduce overall traction.
Also, the location of the shock play an important role in it's stiffness. As you will notice, the front shock is mounted more inboard than the rear shocks. This gives the suspensionmuch more leverage on the shock, and thus it feels softer than the rear with an equal amount of force.
If you are running carpet and have decent bite, I suggest you try my setup. Go with Purple springs and the medium Swaybar at first. It traction is high, use the included setup. Your car should turn about a 2' circle when steering is adjusted properly for this setup.
Good luck,
Greg
PS> Be sure enlarge the image before printing...
Greg Amendola is offline   Reply With Quote
Old 01-31-2005, 04:49 PM   #3083
If you go to the associated site, you can download a full parts list in excel format for all their parts. Those two numbers show the following:
78469506909 6909 Bearing, 3/16 x 5/16, for steel diff 2 $6.00
78469503916 3916 Bearing, 3/16 x 5/16", for #3908 and 3913 pr $11.00
Same size, not sure if they are made of different things. the 3916's are twice the price, unless the 6909 is the price for one, hard to tell from the spreadsheet.
Paul
Old 01-31-2005, 05:19 PM   #3084
ChrisP's Avatar
Send a message via Yahoo to ChrisP
The specs list ID and OD...not thickness....
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 01-31-2005, 07:54 PM   #3085
jsp
The bearing are interchangeable.
jsp is offline   Reply With Quote
Old 01-31-2005, 09:16 PM   #3086
I built the steel diff with the bearings that came with the tc4 kit and had no problems "smooth as butter". Raced last weekend with no probs from diff. Check the diff after one or two runs, make sure its not loosening up. I put a little threadlock and I also take a pair of pliers and crimp the first few threads ever so slightly on the diff screw before screwing it into the "t-nut"
thomasf is offline   Reply With Quote
Old 02-01-2005, 12:21 AM   #3087
Crashmaster's Avatar
Originally posted by utieh
Sorex 28 with JB or Sorex inserts
Give this one ago:
http://www.cmldistribution.co.uk/pro...d_09_01_05.pdf
Cheers
Crashmaster
Crashmaster is offline   Reply With Quote
Old 02-01-2005, 02:16 AM   #3088
utieh's Avatar
Originally posted by Crashmaster
Give this one ago:
Cheers
Crashmaster
Thank you very much !
Do you know where I can download the last version of Acrobat for Mac, I have problem downloading PDF files recently.
Thanks again.
Gilles
utieh is offline   Reply With Quote
Old 02-01-2005, 04:15 AM   #3089
lastplace's Avatar
Rebuilt the steel diff correctly this time... works great.
Thanks for all of your Help!
Old 02-01-2005, 05:43 AM   #3090
Default TC4 stock setup
I just ran the stock setup posted about 7 pages back. I have to say I loved it when I had everything in working order..hahah. The longer camber links are nice, but the only thing I used was 6* caster blocks instead of 0*. But through some of the corners at high speeds, it seemd like the car would almost hop, and skip. Any ideas?
runnin rc10 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
