Old 01-26-2005, 02:45 PM   #2956
ChrisP's Avatar
Send a message via Yahoo to ChrisP
64p 96 tooth is the same as the 48p 72 that comes in the kit...
One of the other guys I pit with is using a 98(64p) with no problems
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 01-26-2005, 02:53 PM   #2957
Default All spur gears standard?
Ok, so can I use my tamiya 64dp/96t?
What I mean is do all spurs can be screwed on the spur holder or do you need a sort of adapter or something?
Tbevofreak is offline   Reply With Quote
Old 01-26-2005, 03:00 PM   #2958
RCGaryK's Avatar
I ran a 102 I think..It was a 100 or 102 I threw in there and went down from there as I needed to gear up to keep the roll out the same. And if you are speaking of the 90/95 tooth spurs that came with the Surikarn, yes they fit.
and not to lump all mags together - but one primary source of revenue is advertisers and when you're reviewing their product. . .well. . .that big grain of salt comes into play.
Thanks Boomer. I'm a racer myself and race on a very tight budget. I don't want to spend my hard earned money on something that is a pile, and I don't know anyone who does. I, along with others I know (such as Shane) don't like it when people blow a product up to be the greatest thing out there that you absolutely must by now. Yeah, the manufacturer's pay to advertise, but readers pay for the magazine itself. What's worse, getting a manufacturer cross with you while providing honset feedback so they can further improve a kit or losing any and all credibility by publishing a BS review? I know which I would rather do....
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-26-2005, 03:02 PM   #2959
EricF's Avatar
The tamiya gear should fit. I don't think that you'd need any type of adaptor.
Or does tamiya use metric spaced gears? Don't really know, just shooting in the dark...BANG!!
A 64p/100t spur will fit as that is what I have on my car, you may even be able to go as large as 104, haven't tried.
E
EricF is offline   Reply With Quote
Old 01-26-2005, 03:13 PM   #2960
Default Thanks!!
You guys have been a great help thanx!
I'm ordering my kit tomorow morning on the net!
I'll let you know if my building turns out ok! (you probably don't give a damn about that but.... )
SEE YA LATER!
Old 01-26-2005, 05:00 PM   #2961
Jmccormick's Avatar
the only problem with running a 64p 100 tooth or higher spur gear is that you have to modify the motor adjustment cam to use anything bigger then a 38 tooth pinion. I run a 64p 100/39 with my reedy 19t and in order to do this I had to dremel my adj cam.
In some cases with smaller tires I have run a 41 pinion but anything bigger would require you to modify the motor mount heatsink that runs along the right side for clearance. I did this to the parts that came in the kit after I purchased the factory team aluminum parts. And by doing this to the stock parts I shaved a bit of weight of the car. instead of removing some material from the heatsink I just cut it of completely.
Jmccormick is offline   Reply With Quote
Old 01-26-2005, 05:03 PM   #2962
EricF's Avatar
True, but that isn't a problem when running Modified, which I've been doing a lot of lately.
E
Old 01-26-2005, 05:10 PM   #2963
Jmccormick's Avatar
yeah in mod it wont be a issue but in 19t( especialy the reedy quad whitch i gear about 2-3 teeth higher then my chameleon) and stock it is when you run a smaller tire. I initaly cut my foams to 2.25 but after a while they end up being much smaller which requires a bigger pinion.
Old 01-26-2005, 07:00 PM   #2964
Soviet's Avatar
Default Re: Thanks!!
SEE YA LATER!
I give a damn! I care!
If you simply take your time and cut each part off the spru properly, and take some time to build it well, it will be a perfectly fine car.
Here's to your building success!
Plus, too many people have it in their heads that for a car to be "GREAT!" it must have Ti this and Al that.
TOTAL BULLSHITE!
People say the TC4 seems cheap because it's made of "plastic."
Actually, it's a molded carbon impregnated resin. A material that when compared to ANY metal besides Titanium is stronger per unit of weight than ANY other metal.
It's made out of that material for a reason. Metal bends, tweaks and otherwise is malleable. Carbon impregnated resin/plastic parts either survive or break, very rarely do they bend.
Now maybe some will understand why MANY pro drivers opt to run the old TC3 "plastic" dogbones as opposed to the Al ones. In a hit, the Al bones will ALWAYS bend horribly easily. The fibre/plastic ones will simply flex and take the abuse...or break. However if a fibre bone breaks, most likely your arm and control link is history as well.
I simply LOVE it when KIDS bash the work of PHD holding Engineers in their 30's /40's.
It's a funny sight to behold.
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 01-26-2005, 07:08 PM   #2965
One tool I found real handy when building the car...
a 4-40 tap! get one and use it.
MartynD is offline   Reply With Quote
Old 01-26-2005, 09:46 PM   #2966
Originally posted by DOTMAN
I would say only the rear 2 and 2.5 blocks add value aside from looks and durability. The plastic ones only come in 3 degree
Thanks for the replies guys!
TC4 Rider is offline   Reply With Quote
Old 01-27-2005, 12:19 AM   #2967
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Default Prototype Diff finished
Hey Guys...
Speedway PAL has just finished up there prototype Alloy diff for the TC3/4.... This diff is actually lighter than the IRS diff by 1.5 grams and it will allow you to shim the diff even more than the stock one.....so that means better gear mesh and a quieter drive train...and as a added feature the diff will use durlin dogbone blades for less wear... ..
I will post a pic as soon as I receive mine
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64d
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-27-2005, 05:00 AM   #2968
RoNTC3's Avatar
Send a message via AIM to RoNTC3 Send a message via Yahoo to RoNTC3
Hey guys, I know I'm a little late on the subject but I run a 104 spur with no problems. Any bigger and it hangs out the bottom.
eXpress Motorsports * FOLLETT Motorsports * Final Thoughts Racing
Remember, half the people you know are below average.
RoNTC3 is offline   Reply With Quote
Old 01-27-2005, 06:58 AM   #2969
RCknight's Avatar
Default Dave, do you have a pic of your...
milled out chassis?
RCknight is offline   Reply With Quote
Old 01-27-2005, 07:01 AM   #2970
What is the advantages to have a carbon fiber chassis like one from BMI besides they look good. I have been thinking about getting one, but I just wanted to see if it would be worth it for $125.00.
caleracer45 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
glennhl, nubs
SEO by vBSEO 3.5.0
