Like Tree36Likes
Old 01-20-2005, 12:03 PM   #2806
The car is Sweet. I love the way it drives.
DOTMAN is offline   Reply With Quote
Old 01-20-2005, 12:14 PM   #2807
To increase the rotation at the last Carpet Thrashnal over here I shortened the wheelbase and put on a 4 deg Castor block running flat spacers all round. I also moved the shocks out at the front to line up with the rear and softened the springs slightly to get a bit more front end under braking into the hairpins.
Only complaint I had at the end was my side to side rolling seemed a little excessive so I'm giving a full set on anti-roll bars a try at the weekend.
Oh also reducing the 3 deg toe at the back to 2 made the car feel nicer in the turns.
Andy M is offline   Reply With Quote
Old 01-20-2005, 01:50 PM   #2808
Oh yeah...My friend used the 2 degree rear mount with the Losi 1/2 degree carriers reversed to take out another degree of toe
Old 01-20-2005, 01:58 PM   #2809
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
why doesnt AE sell the 2.5 or 2.0 rear on mount in plastic or than only factory alum.?
Roberto Falcon is offline   Reply With Quote
Old 01-20-2005, 02:02 PM   #2810
Buy the plastic mounts and switch the circle for the square in the rear. I haven't measured it, but it would seem to be somewhere between 2 and 2.5 deg.
MartynD is offline   Reply With Quote
Old 01-20-2005, 02:06 PM   #2811
i dont get it ? do what?
Old 01-20-2005, 02:18 PM   #2812
If you buy the plastic set of blocks again you can use the Circle block on the rear instead of the standard X 3 and it gives you approximately 2 deg rear toe
Old 01-20-2005, 02:20 PM   #2813
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
he's saying that if you dont want to buy the alumium block buy a set of plastic blocks and that by putting a circle block were the square should go you will get 2.0-2.5 deg of toe in, in the rear
Javen13 is offline   Reply With Quote
Old 01-20-2005, 02:57 PM   #2814
Exclamation Just one question before buying TC4
Hi,
I'm new to this forum and I would like to know if the TC4 has any stripping problem since it's shaft driven car?
I have a EVO3 Surikarn and this was a BIG problem and it needed some shimming to fix the gears from stripping
Does the TC4 need any shimming?
I don't want to go thru this again
after having so much pain with my evo3!
I'm just about to buy it, I just need a quick answer!
Thanks in advance,
Will.
Tbevofreak is offline   Reply With Quote
Old 01-20-2005, 03:00 PM   #2815
Only time I have stripped a diff gear is when I shimmed it too far to get max free spin. I now have good free spin and no stripping problems.
JWATT is offline   Reply With Quote
Old 01-20-2005, 03:15 PM   #2816
RCknight's Avatar
Default Does changing to...
a more consistant shock like Tamiya's make a difference for anyone?
RCknight is offline   Reply With Quote
Old 01-20-2005, 03:17 PM   #2817
RCknight's Avatar
Default Thomasf...
No, I'm not David.
Old 01-20-2005, 03:21 PM   #2818
think the only difference by going to the tamiya shocks is the ease in which you can build them...
I wouldn't know if they are better performing or not... tempted to find out, after my last shock rebuild..
Old 01-20-2005, 03:24 PM   #2819
I agree. Proper shimming is vital to all shaft cars particularly the EVO3. I think the AE gears are better, but they still need to be properly spaced. Proper shimming will also free up the drivetrain too
Old 01-20-2005, 03:31 PM   #2820
Default Re: Does changing to...
People make a big deal about the Tamiya shocks...which are good, but the AE shocks have work great. At least they have for me and I have four sets. If you already have AE shocks and don't want to spend the money on Tamiya, buy the Yokomo shock caps for the AE shocks. It's a lot cheaper. They use bladders like the Tamiya shocks which makes rebuilds real easy. You can also go even cheaper by getting the Yok shock caps with the bleed screws. They're not quite as easy to build as the bladder type but still very simple. The AE shocks are smooth and consistent. I don't know why people are saying bad things about them. The only issue to me is the cap. Just replace'em
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
