Like Tree26Likes
Old 01-18-2005, 02:49 PM   #2746
RCknight's Avatar
Default Tires...humm.....
I'm using Jaco's tires and all my rims have broken, but then again I hit stuff. I can say most are taps and side swipes. Broke a few arms before I got a NTC3 bumer.
I may need to try a different tire.
On the subject of shocks, I'm waiting for the new Losi JRXS ones. I can't wait to give them a try. I'm also looking forward to the new cvds design. I can't stand building the AE ones anymore. I would get the Yoke caps, but I'll wait for the Losi ones. AE wants too much for their hard coated ones, and again you need Yoke caps.
RCknight is offline   Reply With Quote
Old 01-18-2005, 02:53 PM   #2747
'On the subeject of shocks, I'm waiting for the new Losi JRXS ones. I can't wait to give them a try. Looking forward to the new I can't stand building the AE ones anymore. I would get the Yoke caps, but I'll wait for the Losi ones. AE wants too much for their hard coated ones, and again you need Yoke caps."
tell me about it, the tc3 and tc4 are both amazing rc cars but when i comes to thier shocks they lack big time, i took my 2 hours to rebuild my ae shocks and thier still not perfect, and i know i need to yok caps but which one? the ones that have the bleed screw or the ones without it if im planning to use the bladders?
i thought the whole point of useing shock bladders was to eliminate the bleeding process
kh15 is offline   Reply With Quote
Old 01-18-2005, 03:12 PM   #2748
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Travis S
Or does anyone have any other recommendations for a replacement center shaft?
Square makes a light weight center shaft for the TC4 that weights only 7grams!! ....
CHAMP should be able to get one for you....
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-18-2005, 03:14 PM   #2749
Buy both they are cheap...
Though use either bleed scews or bladders... might be able to use the bleed screw caps with bladders... but not sure...
from what i have gleaned reading these boards.... get the bleeder screw caps and the o-rings for simplicity (o-rings are in the rebuild kit)
buy 2 sets
I am sure the bladder style are fairly simple to use too
MartynD is offline   Reply With Quote
Old 01-18-2005, 04:10 PM   #2750
Default Re: Shock bladders
Originally posted by Poppa Ray
I've been researching bladders for my t3 and I can tell you for the AE shocks the Yok part# ys-8dmh for the bladder only since we can't realy use the cap. Also Yok I think is the supplier for Rayspeed which makes an after market tuned bladder part# rs-04 for high grip rs-03 for med grip and rs-02 for low grip. What I don't know yet is who carries these on line! Any one?
Speedtechrc has them.
DOTMAN is offline   Reply With Quote
Old 01-18-2005, 04:18 PM   #2751
Travis S's Avatar
Trader Rating: 46 (100%+)
-Dave
Who is CHAMP and how do I get in touch with him? Is there any online store that has this? I did a search and found some stuff from them, but not that shaft. I may want to get some of the dif's they got as well. Looks like they can help stop my CVD's from popping out.
Travis S is offline   Reply With Quote
Old 01-18-2005, 04:43 PM   #2752
RCknight's Avatar
Default Anyone get the most recent...
TC4 kit? I read an artical with Cliff Lett in RC Car Action where he said there were changes on the chassis braces, suspension arms diff gears, and arm mounts. There you have it. He recommends you get the newest updated parts. Now, if I can only figure out which parts at the hobby store are the ones that have been updated?
Old 01-18-2005, 05:29 PM   #2753
ChrisP's Avatar
Send a message via Yahoo to ChrisP
Which issue of RCCA and where do we find it?
What about those of us that already have kits?
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 01-18-2005, 05:33 PM   #2754
Bob Nilsen's Avatar
I just got a TC4 Molded Carbon Component Set and I'm planning to do a little cutting on the chassis to remove the battery posts and put a slot in for battery tape, just like my plastic chassis.
One question, do I need to be particularly careful when working on this "Carbon" material? What's this stuff made from, and do I need to take special precautions?
I see people giving warnings when working on "carbon fiber" or "graphite" chassis components...
Bob Nilsen is offline   Reply With Quote
Old 01-18-2005, 05:36 PM   #2755
ChrisP's Avatar
Wear a mask..the fine carbon dust is pretty bad for ya
TeamXray.com
Team Tekin
Old 01-18-2005, 05:39 PM   #2756
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Don't eat the chassis...it may cause choking.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-18-2005, 06:11 PM   #2757
LOL and in some serious cases....DEATH
runnin rc10 is offline   Reply With Quote
Old 01-18-2005, 06:13 PM   #2758
Default Re: Anyone get the most recent...
I just bought the TC4 from Tower Hobbies for $175, and it is the newest kit because it has the new arms, and none of the problem that everyone speaks of. Except having to put shims under the bearings on the steering rack.
thomasf is offline   Reply With Quote
Old 01-18-2005, 06:31 PM   #2759
Losi Shocks actally sound like a good idea, thats what I was going to use on my associated truck before I sold it. They build easy and are super smooth....now all the way to do is wait...and at the current rate who knows when that will be.
Old 01-18-2005, 07:29 PM   #2760
Regional Moderator
FroBoy's Avatar
The layout at the hobbyplex in omaha is rather tight right now, but not near as tight as some other tracks that I've raced on...
www.hobbyplexraceway.com
FroBoy is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
