Team Associated TC4
#2626
Originally posted by Paul_TC4
Hey guys,
I was thinking of getting the Carbon conversion for the TC4..... or at least the chassis. I know many people say that the Carbon conversion makes a HUGE difference, but has anyone noticed a difference in their lap times??
Thanks,
Paul
Hey guys,
Thanks,
Paul
I haven't gone for a full conversion kit as I'm getting the BMI chassis asap, however I put on carbon wishbones on Tuesday and the difference was slight but noticable.
The wishbones are actually the most important part to replace when it comes to graphite parts as they are the bits which are under the most force most of the time and are the bits which flex the most. Although a plastic chassis does have some flex I am reliably informed som of the "lazy" feeling you sometimes get is caused by flex in the arms.
After replacing the arms the car seemed to feel like more of a single unit, with the plastic parts you could notice the back end trying to catch up with the front as the parts bent. I need to get the car back on a big track to test a week on sunday but I'm expecting to improve with this new setup.
#2627
Hi andy....i know you only do the CML site but never mind.
All i want to say is a big thanks to CML for the good customer service.....they offered to send a replacement part (motor clamp) free of charge because it broke before i even used the car...they sent out the wrong part so i emailed them saying i will return it blah blah and they said don't bother returning it and next thing i know i have the correct part coming through my letter box
I've never had that from mirage, helger or centre-point so thumbs up CML
Again andy, i know you only do the site but....do you know if CML have been distributing the new tc4 wishbones yet? or are the old ones still flying around?
#2628
I really liked the BMI TC3 chassis and it seemed to work well. My only thing with aftermarket chassis, people seem to still win regardless. But I am starting to think that with AE not having a plate chassis and it being so much heavier than other cars I think the BMI CF may be the way to go. I just hope the stiffness of the graphite kit im getting will help reduce my scrubbing in the corner. I want to try a BMI topplate to fit the tub chassis though first.
#2629
I picked up a set of Graphite arms for mine on Monday from the office and as far as I can tell they are the improved mouldings. They certainly don't have any excess play on them so I would assume yes.
Obviously your model shop may have some of the old type left over that they are trying to shift but the improved ones are about.
Obviously don't hold me to this, I'm known to be wrong now and again
#2630
Thanks andy
I'm running down at the BIWS this sunday (first time there with the TC4) so ill have a word with the guy at the shop down there..see if he has any graphite wishbones in.
ordered some steel outdrives (lightened of course ) from HK start of the week, aparently they have arrived at their desitnation (but they haven't ) so i hope they come tomorrow...Andy, you had any problems with the fat gears? i melted 3 diffs
Again, i know you only do the site but do you know if CML are replacing gears and outdrives like AE? Just i was talking to the owner of my LHS and he asked me to find out (as i asked him if he was replacing them like AE) if you get what i mean.
#2631
Nope, not had any diff problems, I'm still running the gears that came with my kit.
Not sure on the replacement parts, try giving the office a ring and they should be able to give you a definite answer. (Phone number on the website)
#2632
ok, so the courier was late and the parts did arrive.
included in themparts were a set of polished hinge pins..after fitting these it seemed to increase the slop a bit in the wishbones, hub carriers and chubs
is this normal for the polished hinge pins? however it is one hell of a lot smoother and less binding...and they fit better into the wishbones (not as rough as teh black ones)
on the good side of things...in the order was also steel outdrives and i got my diffs built up with them and they are tonnes better, might weigh a bit more but i can run my diffs looser without the diffs slipping to much
also picked up 4 deg chubs so might give them a whirl this sunday...i hope it all goes as planned
#2633
I read somewhere on here that someone had bought a set of low friction hinge pins? Anyone got any idea, the stock ones almost seem sticky, I polish them but they still start to bind a little bit after a few heats.
#2634
Re: Any of you guys find a fix for the steering
Originally posted by RCknight
rack? The part with the bushings? Someone once said use motor shims, but I can't see how that would work. Has anyone justed glued the bushing on to the rack? That seems to be were there is play.
#2635
i think the whole set is about 10 dollars, and they are silky smooth
although i did notice an increase in slop when i fitted them on my tc4
#2637
Cant beat 10 bux! And no more binding! This car is going to be better by the moment. I still have some things I cant wait to try
#2639
Its been previously posted that the savings from plastic to carbon on this car is pretty significant. The TC4 is really heavy. Kinda surpising really, but thats why the AE guys are doing stuff like cutting off the batter poles to get rid of the strap-weight reduction. Some of the newer plate CF chassis are just sooo light ie. xray.
ROAR and IFMAR STILL require minimum weights. The TC4 is not "so heavy."
I swear...give me a break. Sometimes you people just pull stuff straight out of your a$$e$.
