Like Tree19Likes
Old 01-11-2005, 10:56 PM   #2596
RCknight's Avatar
Default Who from AE has said there were any...
changes? I have not read it or talked to anyone from AE that said anything was fixed other than the plastic toe blocks. No stronger/better fitting arms, and no steering rack fixes. Don't you think they would be telling everyone about it if they did make some fixes? Mere rummors.
RCknight is offline   Reply With Quote
Old 01-11-2005, 10:59 PM   #2597
RCknight's Avatar
Default Rayhaung......
is X-ray coming out with a new TC? I read somewhere about testing at the Worlds.
Old 01-12-2005, 05:36 AM   #2598
ChrisP's Avatar
Send a message via Yahoo to ChrisP
Originally posted by ghoppa
my new skin....
a "Frank" inspired scheme....
http://www.rcpics.net/view_single.php?medid=46891
Nice!
What tires are those? They look like the new TRC wheels, but I've only seen them in black so far?
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 01-12-2005, 06:05 AM   #2599
2Fast4U2's Avatar
That is very interesting about setups. Mine TC4 is So close to my TC3 setup its not funny. Only thing that is different is the shock oils and pistons. Other then that same shock locations and springs. High roll centers. I have no clue how you guys get your cars to turn with the setups that I have seen on Ozite. Must be the traction differernce. Running on a small track with Little or no traction. with the amount of 180 degree corners on our track. Car has to be super responsive. I got a few really strange things done to my car. It seems to work, or at least on our track.
Ray-H. Billy S. has probably told you how little traction we have here in KC. I believe that Billy has use the phrase "Ice Rink" before. LOL. Kind of funny. Oh well, its all we got.
2Fast4U2 is offline   Reply With Quote
Old 01-12-2005, 07:37 AM   #2600
rayhuang's Avatar
2fast4u2-I think my original set-up might have been good on your style track-only change from my 6' circle to a 4' circle and youd have crazy steering everywhere. I had to use a 6' circle to be able to drive all the fast corners (7' circle might have been even easier), but with a circle that big-you cannot drive the slow stuff very fast.
As for the Xray-new bulkheads that lower the top deck and spur gear and adjustable pills to raise and lower the axles-thats it so far. But I dont have the inside scoop on Xray-so I dont know anything else.
Ray
Old 01-12-2005, 07:58 AM   #2601
2Fast4U2's Avatar
Not really sure, but i bet it will turn inside 4' easy. Hec our lanes are only like 6-8 feet at best. and you can turn around in those easy. LOL I bet its closer to 3' circle. I will check next time I am out. Just to see.
Old 01-12-2005, 09:26 AM   #2602
Crashmaster's Avatar
Thx for the replies guys. Does all the hardware from the plastic outdrives fit directly into the IRS ali ones?? (unlike the associated steel ones i thk).
Must admit, can't wait to drive this thing, missed the last meet due to bloody exams
Cheers
Crashmaster
Crashmaster is offline   Reply With Quote
Old 01-12-2005, 09:30 AM   #2603
Crash....to have IRS lite diffs you need to go get a rebuild kit for a steel diff and D rings from the plastic diffs 2 seperate part numbers.........hope that helps,
Barry
Barry Baker is offline   Reply With Quote
Old 01-12-2005, 09:37 AM   #2604
ChrisP's Avatar
I'm running the IRS Aluminum outdrives, with the Steel Diff rebuild kit (for the screw and T-nut), CRC diff rings(slightly thicker), MIP thrust rebuild kit (harder washers and balls) and Carbide diff balls....
It all adds up to a diff that is as smooth as butter
TeamXray.com
Team Tekin
Old 01-12-2005, 09:41 AM   #2605
RCGaryK's Avatar
I dunno why people say that. I got to see Butter driver this weekend and he wasn't that smooth until he ran Sobottka's car
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-12-2005, 09:47 AM   #2606
ChrisP's Avatar
Should have rephrased it...as smooth as Dairy butter....not Team Butter... (whom I don't know personally....so can't reference one way or the other) lol
TeamXray.com
Team Tekin
Old 01-12-2005, 09:51 AM   #2607
ChrisP's Avatar
What would be NICE is if Associated were to release a diff kit like this so that I don'thave to pull parts from a bunch of different places in order to assemble a diff like this...
My Xray diffs came complete with Carbide diff balls, carbide thrust bearing assembly, precision ground diff rings...all in the original package....sure Xray parts are expensive...but not so much when you look at al of the other crap i had to get to build something that was roughly equivalent...
Oh yeah..forgot one of the most important steps in my diff-build....I also used a dremel to remove some thickness from the interior portion of my diff gear.....
TeamXray.com
Team Tekin
Old 01-12-2005, 11:22 AM   #2608
utieh's Avatar
Does soemone know if the SD main shaft fits in the TC4?
Thanks.
Gilles
utieh is offline   Reply With Quote
Old 01-12-2005, 11:24 AM   #2609
ChrisP's Avatar
I thoughtI read earlier in the thread that the SD had a slightly shorter shaft?
Possibly someone who has run both can confirm
TeamXray.com
Team Tekin
Old 01-12-2005, 12:13 PM   #2610
utieh's Avatar
I'm not sure but I think the SD shaft is 10mm shorter than the TC3's
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
