Like Tree19Likes
Old 01-11-2005, 10:44 AM   #2566
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
alright well i have mainly a bone stock tc4 just with ti. outdrives.
um i want to know if you need to change the caster blocks up front for a mid size high grip track and has tight turns too. like i said im running it bone stock from the box . just want to know what are the things i need to get for that track i said.
Roberto Falcon is offline   Reply With Quote
Old 01-11-2005, 10:51 AM   #2567
Trader Rating: 194 (100%+)
Originally posted by LoSi xXx S
how much is the antiroll bar kit cost?
Hi LoSi xXx S,
The roll bar at our store is $9.95. Here is the link if you are interested.
TC4 Antil-Roll Bar Kit
Pictures for all parts TC4 will be coming soon. Thanks for your patience everyone!
All-Star is offline   Reply With Quote
Old 01-11-2005, 11:27 AM   #2568
RCGaryK's Avatar
Originally posted by Jack Smash
I'm running purple up front and copper rear which is one level stiffer than what he ran. I'm am not running a front ant-roll bar. I'm thinking that purple without the bar is close to copper with the bar. I'll try his spring setup in a couple weeks when i can get to run again.
I don't know what his roll center or caster was, but I tried the Copper/Red/Medium bar setup on my car that I ran in Brushless and when the track was cooler and grip was low I loved that setup. My car didn't have the initial turn in that I was looking for, and that setup gave me the turn in I needed. I ran that setup in the 3rd qualifier but grip had come up and the car now turned in too hard and was very loose. I ended up going back to the purple front with the thick front bar but went up to a purple in the back too and it was a good compromise. I still would have liked a little more turn in, but I have other things I am going to try. So far I am liking the TC4 on foams a lot.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-11-2005, 01:18 PM   #2569
Hi, i just bought a tc4 from ebay (new in box with a few hop-ups in their original packets ) i was wondering if there is anything special you need to do when you build kit (sanding, etc )
Thanks,
Chazz
Chazz is offline   Reply With Quote
Old 01-11-2005, 01:20 PM   #2570
RCGaryK's Avatar
Get a pack of shims. Also the Graphite tub and "wings" are a big improvement as well
HorizonHobby.Com
Old 01-11-2005, 01:25 PM   #2571
Crashmaster's Avatar
Hi guys,
I've recently aquired a TC4 (the man in the red suite was nice to me ), and I've been reading up on them. The only problem seems to be the outdrives (in respect to the plastic ones that is). As far as replacing them goes, does it make more sense to get the AE steel ones, or the IRS ali ones??
Chees
Crashmaster
Crashmaster is offline   Reply With Quote
Old 01-11-2005, 01:25 PM   #2572
Thanks, i'll will get some shims when it comes, don't need the graphite tub as it comes with it
Chazz
Old 01-11-2005, 01:27 PM   #2573
RCGaryK's Avatar
Crash, I ran my TC4 this weekend with a Novak Brushless on super high bite carpet with foams this weekend....no noticable wear or notching when everything was said and done. I did use a little Tamiya Anti-Wear Grease on the drive pins though.
HorizonHobby.Com
Old 01-11-2005, 01:31 PM   #2574
Bob Nilsen's Avatar
Crashmaster... according to setup sheets on rc10.com... AE drivers Baker and Levanen use IRS aluminum outdrives.
I *assume* those guys pretty much have their pick of all available equipment... and if they like the IRS product then I *assume* it's a pretty good choice.
I've heard that the AE lightened steel outdrives aren't all that light.
Bob Nilsen is offline   Reply With Quote
Old 01-11-2005, 01:32 PM   #2575
Bob Nilsen's Avatar
Gary... which outdrives were you using?
Old 01-11-2005, 01:35 PM   #2576
RCGaryK's Avatar
The stock plastic ones. The only mods I have made to my car from stock are:
Losi 6 Deg front C-Hubs and steering blocks
Losi 0 Deg rear hub carriers
X 2.0 rear toe block
Hard front Sway Bar
Purple Springs
Graphite Component Kit.
Other than that the car is stock.
HorizonHobby.Com
Old 01-11-2005, 01:44 PM   #2577
Scrad's Avatar
Trader Rating: 15 (100%+)
Yeah, the AE lightened outdrives are pretty heavy.
Scrad is offline   Reply With Quote
Old 01-11-2005, 06:20 PM   #2578
RCGaryK's Avatar
Well, now I can add to that list....
Low Friction hinge pins, the dual fan kit, aluminum shock mounts, and some other odds and ends. Can't believe I am working on a foam car...I still hate the cost of foam, but it was very easy to drive fast.
HorizonHobby.Com
Old 01-11-2005, 06:43 PM   #2579
stormperson's Avatar
Send a message via AIM to stormperson
I am pretty sure the entire team ran that spring set up, and yes it does seem odd, but hey, the car was the best it has been yet...
The best AE car there was Timmy's, although he didnt make the show, his car was dailed, and he was also the only AE drivers besides I think Bob running Parma tires...... (both cars were quite good)
Jack- that looks trick, but do you have the bottom milled out so the tape sits flush like baker lol. Also another cool thing i noticed on barry's snowbirds car (which was just a chassis and arms, lol) is that he had ZERO play, i think someone was saying he glued or somehow stuck plastic baggies or something and then cut them, but I would assume after one hit the slop would return... ???
R/C Excitement Special Projects Coordinator
Kwik | Speedmerchant | Parma PSE | KO Propo
Team Pickles
stormperson is offline   Reply With Quote
Old 01-11-2005, 07:08 PM   #2580
RCGaryK's Avatar
Bob ran Purple/Copper. I talked to him a lot about setup stuff and he said he tried Barry and Mike's setup and didn't like it. I didn't see Timmaaaaaaay's car at all so I have no idea what he was running.
HorizonHobby.Com
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
