Like Tree26Likes
Old 01-10-2005, 11:16 PM   #2551
Jack Smash's Avatar
Trader Rating: 29 (100%+)
And the next.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 01-10-2005, 11:22 PM   #2552
Jack Smash's Avatar
Close up.
Old 01-10-2005, 11:23 PM   #2553
Jack Smash's Avatar
Last one. Only drawback I found to doing this is youll have to cut out some webbing in a very tight spot to be able to use the rear position.
Old 01-10-2005, 11:41 PM   #2554
Bob Nilsen's Avatar
Looks good Jack... think I'll give that a try.
I'm also working on moving the battery a bit inboard by removing a lil' plastic off of the chassis... just like the popular TC3 mod. I found that I can move the battery inboard about 3mm... and I don't think i killed the chassis rigidity too much
Also... I've been running my batteries with deans connectors which were about 3-4 inches long... cause the wires were attached to the batteries on the *outside* of the car. I'm going to start wiring the way Jack did above... that'll save me 8 grams more on that side of the car...
I think all this will allow me to take off a lot of the 30-ish grams of chassis balance weight that I've added.
I'm also going to move to using the fan kit which should further translate the dead weight on that side of the car into useful weight.
Bob Nilsen is offline   Reply With Quote
Old 01-11-2005, 05:56 AM   #2555
ChrisP's Avatar
Send a message via Yahoo to ChrisP
Anybody compare the weight of the blue aluminum motor mount to the standard black piece...
The black piece feels HEAVY
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 01-11-2005, 06:03 AM   #2556
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Yeah, the blue anodizing is much lighter.
I haven't put them on the scale but they are the same piece. Just a different color. I would be really suprised if there was any difference in weight, other than a standard manufacturing variance.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-11-2005, 06:07 AM   #2557
Default Batteries
In Jack smashs pics (thnx by the way) I noticed that he is mounting the batteries with the tabs on the side, LOL i did this and now have a huge grind mark on my drive shaft..Tab was rubbing so I flipped the batts around. The next thing is by removing the Batterie strap you save 12g? That seems like a lot of weight for something so small. But for those who dont like dealing with tape or cutting chassis for that matter, what about a piece of CF like the stuff that BMI uses? Thats another point, BMI makes the chassis that is supposed to reduce weight by tons while gaining the rigidity that we ALL want while carpet racing...just a though.
Another thing im curious about is the effect of weight in stock racing compared to mod. How much differece is there based on performance when running in each class? I run stock and thats where I would think it would be more important to run a lighter car, I could be wrong though. I just know that with all the plastic parts, and the batt strap, A BMI x-ray is still not beating a TC4.
runnin rc10 is offline   Reply With Quote
Old 01-11-2005, 06:13 AM   #2558
ChrisP's Avatar
I knew the blue was aluminum...thougt a different alloy may have been used for the black piece...
I wasn't expecting it to be lighter just becauseit was blue Blake....lol...you know me better than that I should hope
TeamXray.com
Team Tekin
Old 01-11-2005, 06:16 AM   #2559
I know...LOL.
Old 01-11-2005, 08:59 AM   #2560
Bob Nilsen's Avatar
You guys notice that Baker's car was sprung copper/red?
I'm not springmaster2000... but that strikes me as being softer than normal. Wonder if that's how he ran the main... and what the rest of the setup is like.
Old 01-11-2005, 09:53 AM   #2561
Scrad's Avatar
Trader Rating: 15 (100%+)
I saw a lot of people at the Novak running red and copper springs.
Scrad is offline   Reply With Quote
Old 01-11-2005, 10:06 AM   #2562
rayhuang's Avatar
I have never run below 30 lb up front on carpet-but I wouldnt see why that would be bad in modified if you needed more steering.
Also-BMI is working on a new battery strap for the BMI TC4-but I dont know if it will fit the Associated TC4.
Ray
Old 01-11-2005, 10:16 AM   #2563
Jack Smash's Avatar
I'm running purple up front and copper rear which is one level stiffer than what he ran. I'm am not running a front ant-roll bar. I'm thinking that purple without the bar is close to copper with the bar. I'll try his spring setup in a couple weeks when i can get to run again.
Old 01-11-2005, 10:25 AM   #2564
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
how much is the antiroll bar kit cost?
Roberto Falcon is offline   Reply With Quote
Old 01-11-2005, 10:37 AM   #2565
Jack Smash's Avatar
I think its around $12 - $14.
Looks like Barry and Blackstock have started posting again. Hopefully we will get Barry's setup from the Novak.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
