Like Tree26Likes
Old 01-05-2005, 09:38 PM   #2446
Fatboy Joe's Avatar
Originally posted by rayhuang
fatboy Joe-I thought about saving my gear that way. Can you desribe that bit a bit more-excuse the pun please. And I also noticed two ring marks on one dif ring-which I attributed to one ring from the balls and another ring from the diff gear rubbing.
Thanks for the tip.
Ray
HI Ray, yes, you are right, those two marks are caused by the diff balls on the diff ring and the other ring mark on the outdrive (plastic one) is caused by the face of the diff gear being too thick and it just rubs against the face of the outdrive when loosened 1/2 turn as per manual. Attached below is the illustration of what exactly to take out and which part causes friction. AE knows this problem and they have a new batch of diff gears that came out but I still grind my diff gear to make my diff smoother
Sonny
Fatboy Joe is offline   Reply With Quote
Old 01-06-2005, 12:30 PM   #2447
EricF's Avatar
Joe,
do you have a prt number for the bit, is it made by dremel?
Thanks,
E
EricF is offline   Reply With Quote
Old 01-06-2005, 01:14 PM   #2448
Are the new gears not as thick?! The car accelerates normal and everything it just sounds bad. One more question, but away from diff's. When im going through like a sweeper or any turn for that matter, the car is scrubbing speed badly. I can hear the motor just kinda losi RPM's and its killing me on corner speed. Me and my buddies cars are both doing it. Any ideas on setup on how to correct this?
runnin rc10 is offline   Reply With Quote
Old 01-06-2005, 01:29 PM   #2449
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
I will do a lot of set-up changes tomorrow so anyone buying it to run on carpet-I hope I can help anser handling question. Again-I am no expert-but I will help as much as I can.
Ray
Thanks alot for the help Ray, I will be waiting for a responce tommorow.
Paul_TC4 is offline   Reply With Quote
Old 01-06-2005, 02:02 PM   #2450
fathead's Avatar
That has to do with the diffs, if the front diff is tight it will make the car understeer badly (like a spool) so you are having to use more steering lock than otherwise would be needed which is making your car scrub speed
Slavich Design
fathead is offline   Reply With Quote
Old 01-06-2005, 02:04 PM   #2451
So i need to run my front diff looser? Or both diffs? I thought on carpet you wanted the diff pretty tight...i may be wrong though. That happens alot
Old 01-06-2005, 02:13 PM   #2452
CRASH's Avatar
Trader Rating: 26 (100%+)
You do want the diffs pretty tight for the front and about medium for the rear on carpet. It sounds like you have to much rear traction. Car is pushing correct? If this is correct then you need to stiffen up the rear. If it is not pushing then you may want to try some different tires. If you are running plaids and purples switch to Cyans and Magentas. This got my car to rotate much better and pick up some serious time.
Hope this helps,
CRASH is offline   Reply With Quote
Old 01-06-2005, 02:18 PM   #2453
It does push and the rear end does "stick" too much. Im running purple springs on the rear, and going to try yellows and mess with swaybars this weekend. But I will try to get my diffs set up right. Thanks for the help guys...by the way i got away from purp and plaids, DOUBLE PINK AND DBL PINK/ORANGE on carpet from here on out!
Old 01-06-2005, 02:23 PM   #2454
CRASH's Avatar
Sway bars will help. What up Ray? Can't wait to hear some more results on the BMI Chassis.
Later,
Old 01-06-2005, 02:32 PM   #2455
Did you guys see a big difference when switching to the graphite chassis? Seems the car flexes alot, I think the BMI top plate would be a REALLY good solution
Old 01-06-2005, 02:42 PM   #2456
RCknight's Avatar
Default runingrc10...
Are you running stock? Make sure your adj. is set at zero and you don't have any drag brake set on your seed control. It may be one thing to look into.
RCknight is offline   Reply With Quote
Old 01-06-2005, 02:46 PM   #2457
adj? Yes im running stock. Besides that the car is getting faster, im gonna try your method of setting droop too.
Old 01-06-2005, 03:01 PM   #2458
RCknight's Avatar
Default Sorry it's the TH ATV.
Make sure it's at zero drag. Set it so the car just starts to move.
Old 01-06-2005, 04:09 PM   #2459
1shnot's Avatar
Default help with diff
Hi guys...
just ran my tc4 for the first time ....
Broke front diff out drive, so I got the steel ones and now, they don't stay.. keeps backing off and ends up being 2wd... (I've also got some extra parts, like round diff rings and longer nut and i used a little spacer on the bottom b4 the longer white nut)
HELP!!!!!!!!!!!
1shnot is offline   Reply With Quote
Old 01-06-2005, 04:15 PM   #2460
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: help with diff
Originally posted by 1shnot
Hi guys...
HELP!!!!!!!!!!!
Have you tried thread lock on the lock nut yet? this tends to help if you have a diff that wants to keep come loose
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
