Like Tree18Likes
Old 01-05-2005, 02:38 PM   #2431
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
Yes, BMI is working on an upper deck (at least last I heard they were).
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-05-2005, 03:01 PM   #2432
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by protc3
i am going to be releasing a top deck for the car.i just sent some out for testing today.i should have some results soon.it came out very stiff.i was real happy with it.it is made from 2.5mm c/f.
Jason.
Will it be the same size as the upper deck for the twit plate TC4?
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-05-2005, 05:02 PM   #2433
Is the BMI upper deck intended to fit with the stock composite tub?
Will it be possible to purchase both the upper and lower decks separately once released?
MartynD is offline   Reply With Quote
Old 01-05-2005, 05:16 PM   #2434
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i doubt it, i guess they will make an upper deck and lower deck kit..and just the upper deck.
as i doubt anyone would want just the lower deck...it would be to flexible for any racing conditions..it would be like racing with an elastic chassis.
although if you talked to the bmi (sorry i dont know his name ) guy nicely hemight be able to do you a chassis on its own or what ever.
raving-monkey is offline   Reply With Quote
Old 01-05-2005, 05:21 PM   #2435
RCknight's Avatar
Default Glad to read...
Jason! I may keep the TC4 yet if I can get just a top deck.
RCknight is offline   Reply With Quote
Old 01-05-2005, 05:25 PM   #2436
Ya can see where I am going with this I hope....
Buy the upper deck run it with the tub, for perhaps asphalt or just $$ reasons, and then pick up the lower at a later date.
Old 01-05-2005, 06:59 PM   #2437
rayhuang's Avatar
Default diff problem
Hey all,
I want to know if anyone else has suffered this issue with the TC4. I have had a heck of a time with one diff. It needs to be 1/4 turn from locked to be close to tight-but when it doesnt slip-it also has that molllases feel-VERY tight. but it was no problem fitting it into my diff case and setting lash, etc. So Ive been running it looser than ideal.
So I rebuilt it for the 4th time just a few minutes ago with a new diff gear and voila-problem gone. Its tight as can be and also counter rotates free as can be. It did not require any different shimming in the case too. I am happy-next time out on the track I bet the car has more rip and corners smoother now.
Anyways-anyone else or was this a fluke?
Ray
Old 01-05-2005, 07:01 PM   #2438
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Ray, you got one of the thick diff gears in that were in the first batch of kits.
It's fixed now.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-05-2005, 07:06 PM   #2439
rayhuang's Avatar
It's fixed now.
Thanks!! Have fun this week. I wish i could make the NOvak race!!
Old 01-05-2005, 07:10 PM   #2440
Something Im noticing with my diffs, are that they dont feel smooth. The just kinda feel good in one area than a half turn away they seem to bind just a bit...is this the diff gears? They just feel terrible, run fine though.
runnin rc10 is offline   Reply With Quote
Old 01-05-2005, 07:23 PM   #2441
rayhuang's Avatar
My front diff converted to a lt wt steel diff does that just a bit. I plan on rebuilding that one tomorrow night at track-but I just put the whole BMITC4 back together and dont want to take it apart again (now that I know I have bad diff gears)!!!
BTW-as an update on the BMI TC4-Jason tol me it was faster than his TC3 on asphalt. He ran a 8-turn and could flat foot through sweepers other drivers had to lift 3 or 4 times to get throough. And as I said on carpet-it responds to a change and you can tell after a few laps if it helped turn in-mid corner or exit or a combination of all of them.
I will do a lot of set-up changes tomorrow so anyone buying it to run on carpet-I hope I can help anser handling question. Again-I am no expert-but I will help as much as I can.
Ray
Old 01-05-2005, 07:26 PM   #2442
Neil's Avatar
Send a message via MSN to Neil
My lightend steel diff does that too. I've taken it apart installed new rings ring gear nothing helps. But the car seems fine on the track.
Neil is offline   Reply With Quote
Old 01-05-2005, 07:38 PM   #2443
Mine are doing the same thing...what I've boiled it down to is the diff spring. When I built the diff, I collapsed the spring using needle nose pliers. I think that bent the spring to one side a bit?
It's reacing but that's the best I came up with.
Blake
Old 01-05-2005, 09:05 PM   #2444
Fatboy Joe's Avatar
Hi, I hope this tip would help those who have diff problems. The problem is not with the Diff Ring, Spring, Thrust balls or Diff Halves......it is with the diff gear itself. The face of the diff gear where the diff balls are placed are a tad thick on both sides..... what happens is when you follow manual specs on the proper adjustment, the diff halves or the outdrives tend to rub against the face of the diff gear, this gives you a not so smooth action like what you see with yoks or losi diffs. What I did was I dremeled the two sides with a flat stone grinder at a very slow speed setting and made sure that the grinding bit is squared up to get a perfect plane and just grid it around.....how much material to take out?....I didn't measure but I went around the the face grinding it for about 5 secs per side. Make sure you clean the diff gear after and take out the extra bits that where left during the grinding, most especially in the diff ball areas, use an exacto knife. Try rebuilding it again and you'll see a big improvement but if it is still gritty or not smooth, grind down some more, that means you didn't take out that much material on both sides. Word of caution: Please make sure you square up the grinding bit on the face of the diff gear to make a fine flat plane. I've done this to all my AE Kevlar Diff Gears and it always work. My diffs are as smooth as the other cars
Fatboy Joe is offline   Reply With Quote
Old 01-05-2005, 09:11 PM   #2445
rayhuang's Avatar
fatboy Joe-I thought about saving my gear that way. Can you desribe that bit a bit more-excuse the pun please. And I also noticed two ring marks on one dif ring-which I attributed to one ring from the balls and another ring from the diff gear rubbing.
Thanks for the tip.
Ray
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
