Like Tree36Likes
Old 01-03-2005, 08:47 PM   #2386
RCknight's Avatar
Default I tried moving the front shocks in one, but
it was softer and gave me more steering that I didn't want.
I went to 1 1/2 degree of rear toe to free it up in stock, but it didn't have enough bite. So I went back to 2 degrees. May be different with d-pinks.
RCknight is offline   Reply With Quote
Old 01-03-2005, 08:56 PM   #2387
RCknight's Avatar
Default deleted
double post
Old 01-04-2005, 12:22 AM   #2388
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Default Re: runingrc10...
Originally posted by RCknight
I use a sway bar to help take out some steering and to get some rear bite. I'm using purples on the rear and I seem to need the extra rear traction. Soon as my tires wear out, I'm going to orange/d-pink set.
This car has a lot of steering and I'm running a Mazda 6 on top of that. I'm thinking of running an Alfa next.
Droop? Not sure. I set the droop in the front by adjusting the top of the sping so that it's just touches the shock collar and the rear about 1mm from the shock collar. This seem to be spot on for me.
The car really seems to be hooked up for me now, but I'm always searching for something better. I tried 6 degree caster blocks and I liked it better, but that was without shims. So I'm undecided on which was better. The pros say stick with some anti-dive and some anti-squat. I still somewhat new to tunning and I can't tell much of a difference between the 4 and 6. One thing I do want to expirement with is bump steer. Does this give more steering? If so, I don't need any then.
you what? how the hell can you set droop by the shock collar? all your doing there is affecting the ride height, nothing to do with the droop at all.
i can see your setup being totally f*cked
raving-monkey is offline   Reply With Quote
Old 01-04-2005, 01:29 AM   #2389
fathead's Avatar
Default Re: Re: runingrc10...
He means he sets his ride height and then with the car off the ground with the suspension fully extended you screw the droop screws in until the top of the spring just touches the top spring seat which is the shock collar.
I do the same thing to set my droop
Slavich Design
fathead is offline   Reply With Quote
Old 01-04-2005, 01:37 AM   #2390
Fatboy Joe's Avatar
RCKnight was pertaining to this type of technique for droop setting. Photo courtesy of CompetitionX
Droop setting
Fatboy Joe is offline   Reply With Quote
Old 01-04-2005, 01:51 AM   #2391
Fatboy Joe's Avatar
Default Spool Setup
Old 01-04-2005, 06:16 AM   #2392
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
Default Re: Re: Re: runingrc10...
Yeah, I use this method too. It works out to 2mm uptravel every time I've done it.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-04-2005, 06:20 AM   #2393
tc3 racer sc's Avatar
Originally posted by runnin rc10
RcKnight,
We are running a setup something like yours but with white and purple springs. But this weeking in Ohio, we got some help from a local and he wasnt running any shims under any of the arm blocks at all. I found this kind of strage but it worked pretty well. I thought the rear end need to free up just a tad more, but all in all it was decent. I just have one question about the front swaybar? Why on the front? O and how much droop did you run on that setup?
iran the eric d set up with no shims the car was balistic and very fast off the corners and planted
tc3 racer sc is offline   Reply With Quote
Old 01-04-2005, 08:01 AM   #2394
does anyone have a alright carpet setup on rubbers?
smallish indoor carpet track with a stock motor (most likely on cs22s)
Old 01-04-2005, 08:05 AM   #2395
Check out the CML site, I've put up Richard Barton's setup for Watford running T27's on Carpet. Might be a good place to start?
Andy
Andy M is offline   Reply With Quote
Old 01-04-2005, 08:51 AM   #2396
Wicked's Avatar
Can someone lmk if there is going to be a rtr tc4 coming out soon. I am mainly a MT guy but would like to get into TC and well I just don't have all the money right now to build up a nice tc4. But I like the support ae gives to there cars in way of al the after market parts you can get. So I would like to start off with an rtr car then build it up to a team car or better.
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 01-04-2005, 09:01 AM   #2397
Andy
ok, ill take a peek....i used to use t27s actually (control tyre) but now its open im trying out diff tyres
Old 01-04-2005, 09:31 AM   #2398
got his setup printed out ready for saturday.
one thing Andy, i know you do the cml site so does this mean you sort through all the emails?
if so did you get my email (mhirst@gmail.com) about the the motor clamp?
Old 01-04-2005, 09:34 AM   #2399
Sorry Matt, I'm 100% website so I only get the website related email. Everything else goes to the main office.
Old 01-04-2005, 09:36 AM   #2400
Ok, no problem.
hope to hear from them soon
one thing (to the rest of you) have any of you had any problems with motor clamps cracking?
i tightened mine down (not fully) and it cracked accross the lug where the none springy screw goes. i'm not the only person as i know someone else that has had this happen...near same crack line to. i'm thinking its a dodgey batch (we bought our tc4s at a similar time) with a batch of dodgey motor clamps....it still works like, my motor isn't going anywhere but its nice to have a complete motor clamp
anyone?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
