Like Tree18Likes
Old 01-02-2005, 05:25 PM   #2326
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Thanks for the good new Jason.
I'll be waiting for one.
Paul_TC4 is offline   Reply With Quote
Old 01-02-2005, 05:26 PM   #2327
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
I don't know if it has been posted or not. But Kai has a chassis in the works.
tc3stocker is offline   Reply With Quote
Old 01-02-2005, 05:27 PM   #2328
tc3stocker's Avatar
Old 01-02-2005, 05:28 PM   #2329
tc3stocker's Avatar
Old 01-02-2005, 05:28 PM   #2330
tc3stocker's Avatar
Old 01-02-2005, 05:29 PM   #2331
tc3stocker's Avatar
Old 01-02-2005, 05:30 PM   #2332
tc3stocker's Avatar
Old 01-02-2005, 05:31 PM   #2333
tc3stocker's Avatar
Old 01-02-2005, 05:32 PM   #2334
tc3stocker's Avatar
Old 01-02-2005, 05:33 PM   #2335
tc3stocker's Avatar
I have enough belt driven cars, this makes me want to get another shaft driven. This and the BMI chassis make the TC4 look better than ever. You just got to love that Asian styling!
Old 01-02-2005, 05:44 PM   #2336
JR Mitch's Avatar
Hello everyone
I had a chance to see the new BMI Racing chassis for the TC4
today up close and it was very impressive. Kudos to BMI and
Jason on one killer chassis
JR Mitch
JR Mitch is offline   Reply With Quote
Old 01-02-2005, 06:21 PM   #2337
newera152's Avatar
Thumbs up new to RC
On the pinion gears for the 17turn, I was using 18 teeth this is all new to me. the gear thats on the motor is called the pinion gear. I had just changed to a 22t 48pitch pinion gear on the 17turn motor. That gave me some more speed, how do I deturmine which pinion gear and which pitch to use on diff motors.
newera152 is offline   Reply With Quote
Old 01-02-2005, 07:00 PM   #2338
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by protc3
hey guys,
i did alot of testing today with the BMI TC-4 carbon fiber chassis kit.testing went very well.the car carried alot more coner speed and was extremely consistant.i ran it with a 8x2 and i could almost drive it with my eyes closed.it was so smoothe and did respond very well to even the most slight adjustments.my only complaint with the car is that its pretty brittle.on occasion that i tagged a pipe it was almost certain of breaking.it took me a bit to get it set up but once i got it she was so nice.all that i am lacking now is a swaybar.even without running a swaybar on the front or rear on high bite asphalt,it still didnt scrub the sides of the chassis on the bottom.it carried so much speed through the corners without getting squirley and was very,very consistant.the car felt the same every lap and i could hit the same lines every time.i am very pleased with the car and feel that this kit is ready to go to production as long as carpet testing went as well.
jason
Sounds like good news
Will we see if for sale before the middle of the month and also is it possible for pre-orders yet
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-02-2005, 07:40 PM   #2339
rayhuang's Avatar
BMI Tc4 good news.
Heres some good news form Carpet testing.
Car has tremendous on -power steering. NO matter the set-up-it always steers on power. It's rotation is quite good-maybe too good right now. Need to dial some of it out. Alsmots all chnages I have done are to take away steering n one way or another-and believe me-its still got plenty.
Also-ease of working on it is far superior to the tub chassis. For exmaple-I made roll center changes all day via the lower hingepin blocks-and I never took off the top deck or diff cases to do them. I simpy loosened both sides-took out one screw and put in or took off a shim and then did the other side!! Piece of cake.
LIke Jason said-car feels noticeably different after every change-which to me means that its stiff enough to not mask set-up changes. Hes also right in saying the TC4 is brittle. Already broke an arm.
I have not found what I would call a dialed set-up on it yet-but I have also only run aboout 9 packs through it and every pack car improves. But its already consistent-easy to drive (even with all the steering) and very sensitive to set-up chnages.
Ray
Old 01-02-2005, 07:55 PM   #2340
Default Re: new to RC
48 pitch is stronger than 64 pitch, 64 gives you finer gearing adjustments and a slight increase in efficiency. You be fine sticking with 48. As for gearing, keep raising the pinion size until you are hitting top speed at the end of the longest straight. If you are topping out before then end keep going up in teeth on the pinion.
MartynD is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
3 x a charm
