Like Tree18Likes
Old 01-02-2005, 12:54 PM   #2311
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
whats the difference from the old and new spur gear?
Roberto Falcon is offline   Reply With Quote
Old 01-02-2005, 01:37 PM   #2312
I thought it was diff gears too thick, not the spur gear...
Haven't seen anyone report the spur was too thick..
MartynD is offline   Reply With Quote
Old 01-02-2005, 01:49 PM   #2313
Neil's Avatar
Send a message via MSN to Neil
Sorry I meant the ring gear its the one with the diff balls in it. You can take your calipers and measure the thickness of the ring gear. I dont know what the spec is offhand but the overly thick one was causing my diffs to lock up midway through the run. If you have some spares from your old tc3 they will work fine.
Neil is offline   Reply With Quote
Old 01-02-2005, 01:52 PM   #2314
oh maybe i read wrong so whats the difference then?
from the old and new diff gears.
Old 01-02-2005, 02:05 PM   #2315
The new ones and the ones you would buy as parts are not as thick, permitting the balls to ride properly on the rings.
In the kits the diff gears were slightly too thick not allowing the balls to ride on the rings properly, associated has acknowledged the problem, if you believe yours are too thick, if you call AE with proof of purchase I think they will help ya out.
Old 01-02-2005, 02:14 PM   #2316
Default Re: runnrc10....
Originally posted by RCknight
you shouldn't be stripping the front knuckles. Don't keep turning the hex, man! Just tighten it down until it's snug. No more, no less.
If you have to remove the ball stud and screw it back in, make sure you back turn the ballstud counterclock wise a few turns so that the threads drop down, then screw it back in snug. You should do this with all the screws that go into plastic or carbon molded parts. Your parts will last much longer between rebuilds.
Ive tried this on my tc3 and I dont think I did it right. The problem im seeing is that the ball stud will "drop" down into the knuckle and only screw in on the last few threads so its weaker. Sometimes I can just pull the whole thing out, thats how I know they are stripped or they just wont tighten. But I will mess with it and see if I can get it all fixed w/o having to go to aluminum. Or at least till I quit hittin stuff
runnin rc10 is offline   Reply With Quote
Old 01-02-2005, 02:19 PM   #2317
Try using CA at least to make it last until u buy alu
Old 01-02-2005, 02:32 PM   #2318
newera152's Avatar
Default New to RC!
I have the TC3 and love it, I hav changed some of the parts out for stronger ones It's all good my problem is under standing which spur to use to get more speed. any help.
era152
newera152 is offline   Reply With Quote
Old 01-02-2005, 02:48 PM   #2319
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
on the spur go down for top end and up for low end
Javen13 is offline   Reply With Quote
Old 01-02-2005, 02:57 PM   #2320
newera152's Avatar
Thumbs up
That will help , that may be why guys running 27t and I'm running 17t is faster then me.
Old 01-02-2005, 03:08 PM   #2321
Try going with a larger pinion before changing the spur gear...
Check AE's recommended gear chart as a starting point. Also could be your motor needs a rebuild.
Old 01-02-2005, 03:33 PM   #2322
are you running the same pitch gear as the other guy because 10teeth is a pretty big jump
Old 01-02-2005, 04:04 PM   #2323
schmelme's Avatar
just wondering what shims everyone is running under the hinge pin mounts? Stock setup or? I did actually search the forum so dont go nuts if its already been asked. Running rubber on ozite on smooth moderatly tight track setups.
schmelme is offline   Reply With Quote
Old 01-02-2005, 04:54 PM   #2324
RCGaryK's Avatar
That other person may also be running 64 pitch gears too.
So here's something I came across talking to a lot of different people on the TC4. Flex is an issue, that's been talked about over and over again. One driver even said he is able to flex the graphite arms in his hands. Would it be possible to simply retrofit the TC4 with FT TC3 arms and use the TC3 Swaybar mounts? Seems like it "should" fix some of the problems. Any thoughts?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-02-2005, 05:22 PM   #2325
protc3's Avatar
hey guys,
i did alot of testing today with the BMI TC-4 carbon fiber chassis kit.testing went very well.the car carried alot more coner speed and was extremely consistant.i ran it with a 8x2 and i could almost drive it with my eyes closed.it was so smoothe and did respond very well to even the most slight adjustments.my only complaint with the car is that its pretty brittle.on occasion that i tagged a pipe it was almost certain of breaking.it took me a bit to get it set up but once i got it she was so nice.all that i am lacking now is a swaybar.even without running a swaybar on the front or rear on high bite asphalt,it still didnt scrub the sides of the chassis on the bottom.it carried so much speed through the corners without getting squirley and was very,very consistant.the car felt the same every lap and i could hit the same lines every time.i am very pleased with the car and feel that this kit is ready to go to production as long as carpet testing went as well.
jason
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
