Like Tree5Likes
Old 01-02-2005, 06:35 AM   #2296
Neil's Avatar
Send a message via MSN to Neil
Those are cool do they use the stock diff parts? And where do you get them?
Neil is offline   Reply With Quote
Old 01-02-2005, 06:38 AM   #2297
Rainbow 10 in Japan.
Nella-Nobrob is offline   Reply With Quote
Old 01-02-2005, 08:24 AM   #2298
WVRedNeck's Avatar
Default Swaybar
Hey folks.
Would anyone happend to have a photo of how the swaybar is mounted or install instructions?
I picked up a kit from a racer at my local track last night who bought the kit for one bar for his TC3 and he didn't give me the instructions.
Thanks.
*EDIT* Figured it out
WVRedNeck is offline   Reply With Quote
Old 01-02-2005, 08:26 AM   #2299
RoNTC3's Avatar
Send a message via AIM to RoNTC3 Send a message via Yahoo to RoNTC3
Originally posted by CRASH
28mm are fine, just space out the wheel. Or you can use the aluminum hex hubs they space it out just fine.
Later,
Thanks crash, I have alum on the TC3. Are they the same part#?
eXpress Motorsports * FOLLETT Motorsports * Final Thoughts Racing
Remember, half the people you know are below average.
RoNTC3 is offline   Reply With Quote
Old 01-02-2005, 08:40 AM   #2300
Trader Rating: 22 (100%+)
Originally posted by RoNTC3
Hey guys, I finally got my TC4 together and mounted my jaco 28mm foams on it. The front tires rub on the steering block and ball cup. What is the popular fix? 26mm tires or dremel the block and ball cup?
hey Ron, What up? Either the spacers like they say, I use Parma tires no problem.
eXpress Motorsports***VBC
fastasu2 is offline   Reply With Quote
Old 01-02-2005, 09:19 AM   #2301
raving-monkey's Avatar
Send a message via MSN to raving-monkey
Default Re: Rayhung....
Originally posted by RCknight
what is that gizmo on top of your BMI TC4 upper deck? Just wondering.
i not rayhaung but never mind
i believe it is a shottky, like the ones you get with the GT7 etc (i think their rated at 32A but dont quote me on that)
raving-monkey is offline   Reply With Quote
Old 01-02-2005, 10:19 AM   #2302
CRASH's Avatar
Trader Rating: 26 (100%+)
Anyone have the part number for the lightened steel outdrive diff rebuild kit?
RoNTC3, yes it is the same part number for both cars.
Thanks,
CRASH is offline   Reply With Quote
Old 01-02-2005, 11:07 AM   #2303
BBSpence's Avatar
Trader Rating: 37 (100%+)
Originally posted by BBSpence
ASC3926 is the diff rebuild kit for steel diffs.
BBSpence is offline   Reply With Quote
Old 01-02-2005, 11:08 AM   #2304
tc3 racer sc's Avatar
Default had to run my tc 4 in emergency
well i had to run my tc4 because my pro 4 broke and didnot hve a part for it,but to ell you the truth the tc4 felt more quicker off the corner than the pro 4 and transition very well, i just need more top end speed a little dodnot brake anything the setup i used was the eric d. no shims and i was planted so still litte slop in suspension need to be wrk on
tc3 racer sc is offline   Reply With Quote
Old 01-02-2005, 12:07 PM   #2305
ghoppa's Avatar
Trader Rating: 50 (98%+)
Originally posted by Joe B
ghoppa...First.........For the IRS lite outdrives to function "properly" you have to use the NITRO TC-3 assembly instructions, not the electric TC-3 assembly......First you need the nitro PN#6575 nylon T-nut and the standard PN#6582 (electric or nitro) diff spring that you already have, these both go into the "long" diff half (the spring first, then the T-nut)........then, the thrust bearing assembly & diff bolt gets installed thru the short diff half (instead of the long one)........this is because the IRS lite drives have no recess for the small diff nut (thats no longer needed) to properly center the thrust bearing and diff bolt..........I haven't used the associated lightened steel units as of yet, but if they ALSO have no recess for the little diff nut, then you should be able to use the 6575 nylon T-nut.........Joe
Joe,
what is your opinion if I went with the "whole" ADT diff assembly (minus the steel outdrives and using the lightened steel ones-which I have for the TC4, or getting the Aluminum IRS ones) "TAKE A LOOK"
https://www2.towerhobbies.com/cgi-bi...?&I=LXBME7&P=Z
"LET ME KNOW........."
ghoppa is offline   Reply With Quote
Old 01-02-2005, 01:12 PM   #2306
Neil's Avatar
I used the TC4 light weight outdrives with this rebuild kit.
http://www2.towerhobbies.com/cgi-bin...?&I=LXPA07&P=0 It works great and is very smooth. And you dont have to screw with the dog bones.
Old 01-02-2005, 01:19 PM   #2307
ghoppa's Avatar
did you use the diff gear (& pinon gear) that came in the TC4 kit????
Old 01-02-2005, 01:31 PM   #2308
Neil's Avatar
Yes I used the stock updated spur. I have an early tc4 kit and it had the bad spur gear too thick.
Old 01-02-2005, 01:35 PM   #2309
ChrisP's Avatar
Send a message via Yahoo to ChrisP
Does anyone know of a source for 5/64" carbide or ceramic thrust bearing balls?
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 01-02-2005, 01:41 PM   #2310
ghoppa's Avatar
this might be my "nemisis"....
I'll give that a try w/ a newre version of the diff & pinion gears...(do you know how to tell the difference between the bad ones' and a good set of gears???)
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
