Like Tree36Likes
Old 12-30-2004, 06:46 AM   #2266
Are you guys having to cut down tie rods to get them short enough to run shorter camber links? If not, what size tie rod are you running to run the shorter links? Thanks.
runnin rc10 is offline   Reply With Quote
Old 12-30-2004, 10:37 AM   #2267
raving-monkey's Avatar
Send a message via MSN to raving-monkey
my turnbuckles are fine, and i just put 1 degree camber on all round, 0 toe on the front.
and i got tonnes of thread left (well that is in kit roll centre positions)
Dave, you got PM
raving-monkey is offline   Reply With Quote
Old 12-30-2004, 11:50 AM   #2268
CRASH's Avatar
Trader Rating: 26 (100%+)
For shorter camber links I am using 1 1/8" rods.
Later,
CRASH is offline   Reply With Quote
Old 12-30-2004, 11:52 AM   #2269
rayhuang's Avatar
crash-need to alk to you-call me on my toll free line-I'll PM it to you!!
Old 12-30-2004, 01:28 PM   #2270
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Dave, you got PM
Back to you with the set up
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-30-2004, 01:42 PM   #2271
Along with this question, are you guys using the stock kit ball cups, or can the RPM heavy duty ball cups be used instead with the tie-rods that come with the kit? The RPM ones seem like they might be too long?
TC4 Rider is offline   Reply With Quote
Old 12-30-2004, 01:43 PM   #2272
Thanks for the setup Dave
will give it a go this sunday and let you know how it goes
Old 12-30-2004, 05:54 PM   #2273
I wanted to experiment with the shorter roll center locations and the tie rods just seem a little too long to get the right amount of camber with the shorter the link. I didnt know if you guys were using a length other than stock, a buddy of mine shaved down some rods, just wondering if there was a way around it.
Old 12-30-2004, 07:46 PM   #2274
No problem... I hope it works for you
-Dave
Old 01-01-2005, 04:54 PM   #2275
Default Re: BMI TC4 Chassis
Originally posted by protc3
hey guys,i will hopefully be testing it out on asphalt this weekend if i can kick this flu.the car is very stiff.i have had alot of good experiences with my tc3 chassis on asphalt with it being a 3mm chassis and top deck.it was a little more tough to get the car setup but when i got it right it was much faster than when i had it flexing with a 2mm upper deck.i think this tc4 kit is going to be a winner.lets see how carpet testing goes with ray.i will keep you posted on the asphalt testing.
Any News??
Old 01-01-2005, 05:57 PM   #2276
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default tc4
hey guyz out of the box is the stock composite tc4 with high end electronics overweight or underweight?wat about the tc4 carbon fiber kit with high end electronics, overweight or underweight?any help well appreciated
Steven Alexander
crACkeD ChaSsiS is offline   Reply With Quote
Old 01-01-2005, 06:12 PM   #2277
protc3's Avatar
dave,
i will be going out to the track tommorow moring and testing until the evening.i will post the results tommorow night.everything so far is going very well.i did a little farting around locally today and i think all will go very well.i will keep you posted buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-01-2005, 06:29 PM   #2278
Bob Nilsen's Avatar
Default Outdrive alternatives
I seem to be a little too tough on my stock plastic outdrives... I wreck, and they seem to get weakened and then my cvd bones will chronically pop out until I replace 'em.
I'm racing stock... so weight is a factor... what are the next-lightest, but more durable outdrives available?
IRS has aluminum ones... AE has lightened steel... anyone know how heavy these are and which are better?
thanks,
bob
Bob Nilsen is offline   Reply With Quote
Old 01-01-2005, 06:39 PM   #2279
Default tc4
hey man u race at mikes?i use to race there everyweek,very good store/track.lol every1 over there runs xray still?how many tc3s/tc4s?
Old 01-01-2005, 07:02 PM   #2280
Bob Nilsen's Avatar
Smile Caster block revelation
Anyone ever notice how you can easily insert the small hinge pin into the stock castor blocks... but it's very difficult to insert the pin into the 4 degree blocks?
Well... since I assumed this part should be free-moving... i had gotten into the habit with my TC3 and TC4 of filing out the hinge pin hole on the castor block to make the pin move more easily.
However, I noticed that i had a bunch of slop in my TC4 front suspension... so i took a new 4 degree block a new polished hinge pin and just pushed the pin in really hard.... and it went in.
Despite this tight fit, the block still swings quite freely since the pin is rotating in the steering arm rather than in the caster block.
Anyway, thought I'd share... even though the pins are a hassle to get in and out.... some of my slop is gone.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
thundernut6
