Like Tree1Likes
Old 12-23-2004, 01:56 AM   #2161
RCknight's Avatar
Default One thing that I noticed on the X-ray...
is that it has swivel ball joints in stead of ball cups. I use to run those back in the day and they didn't have any play. I wonder if this would make any car more consistant? Can any X-ray owners chim in here? Anyway to change over to this type of ball joint on a TC4? Any company that makes a small size and light weight?
RCknight is offline   Reply With Quote
Old 12-23-2004, 02:23 AM   #2162
RCknight's Avatar
Default Diff grease?
Anyone else use anything different for diff lube? It always seems to liquefy and spin off. I run my diffs tight, so there is not a heat problem. Is there anything thicker, less diff wearing? I once saw some thick red stuff someone used on their diffs, but I can't remember what it was or who made it.
Old 12-23-2004, 03:56 AM   #2163
RCKnight....
Jason (ProTC3) has said before that the diff cases can come off without removing the top deck. The Top deck looks secured to the outisde lower housing mouts. There are also 2 holes in the deck to gain access to the bearing cover screws on the housing.
If you remove all the screws I presume the upper housing will lift and slide out the front.
Can't wait to get one of these to try.
Andy
Andy M is offline   Reply With Quote
Old 12-23-2004, 04:22 AM   #2164
RCknight's Avatar
Default Yes...looks like you could...
side it out from the front and rear. Thanks, I didn't see that one.
Old 12-23-2004, 09:18 AM   #2165
EricF's Avatar
Default Re: Diff grease?
Losi make a tan / brown colored lube.
EricF is offline   Reply With Quote
Old 12-23-2004, 09:30 AM   #2166
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
its probably some car grease he was using i never seen and r/c red diff lube.
Roberto Falcon is offline   Reply With Quote
Old 12-23-2004, 10:44 AM   #2167
dr_hfuhuhurr's Avatar
Trader Rating: 70 (100%+)
Use shoe goo...best stuff I've ever uses.
Seriously though...the silicone lube is best. You don't need much of it. Read here for the best way to build a diff.
http://www.teamirsrc.com/techtips.html
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-23-2004, 11:00 AM   #2168
so you dont put lube on your diff gears?
Old 12-23-2004, 11:55 AM   #2169
raving-monkey's Avatar
Send a message via MSN to raving-monkey
nope, what i usually do..when building any diff is fill in the holes with a little bit of lube and put the balls in, then put a little bit on the dry side of the balls (because one side will be lubed, other side will be dry) and it seems tow ork alright, fairly smooth and last pretty long.
raving-monkey is offline   Reply With Quote
Old 12-23-2004, 12:03 PM   #2170
rayhuang's Avatar
I got my TC4 today. Its all all graphite version-soon to be made a R&D test mule!!
Got a question for you guys (Crash!) running on carpet with foams. Are you going stright to Losi rear hubs to reduce toe in or doing somethng else? This is for stock. I am sure when I strap the mod in it-I'll go to 2º toe in.
Old 12-23-2004, 12:30 PM   #2171
I bought another set of hinge pin blocks and put a circle mount on the rear. This changed the rear toe to almost exactly 2 degrees and had a good effect on the handling with my stock.
Got my best ever finish at my local championship and the car was on winning pace when I wasn't making mistakes
Andy
Old 12-23-2004, 12:36 PM   #2172
CRASH's Avatar
Trader Rating: 26 (100%+)
Ray you have mail.
Later,
CRASH is offline   Reply With Quote
Old 12-23-2004, 12:38 PM   #2173
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Ray- go straight to the losi blocks and castor hubs. It helps add overall stiffness to the car as well. Not to mention the holes don't strip.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 12-23-2004, 12:42 PM   #2174
rayhuang's Avatar
Thanks Crash and Stephen!! I see a lot of improvement over the TC3 straight away. I also got the lt. wt. steel outdrives. Now I gotta see if I can scrounge up some diff rings for them. I had a mega buck spare parts box for my TC3-but I traded it for a XRay parts box. You just never know when your gonna need an Old part do ya????!?!?!!@@#@*
Old 12-23-2004, 12:44 PM   #2175
Moderator
Ray- heh, I use the IRS alu outdrives on my stuff with the IRS cvd's and pinsavers, never had a problem yet.
SMC Racing
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
RotorTruck
