Like Tree19Likes
Old 12-15-2004, 07:26 PM   #1996
Charlie O's Avatar
Originally posted by Speedie
The advantage to using a bigger spur is that it has smaller gear increments than a smaller one. This helps fine tune the gear more.
A finer pitch spur gear has a closer gear ratio than that of one with the same ratio with heavier pitch and it must be larger to have the same overall drive ratio, but with more available gear selection, say a 48 pitch to a 64 pitch, say your motor got hot with a 26 tooth pinion on a 48 pitch but a 25 tooth was to slow on the straight, with the 64 pitch you could go somewhere inbetween and get it right on!
Charlie O is offline   Reply With Quote
Old 12-15-2004, 08:12 PM   #1997
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
Jsaves
Um i dont know i know on the package it said tc3 Ti. outdrives and for my ti means titanium .
Roberto Falcon is offline   Reply With Quote
Old 12-16-2004, 02:23 PM   #1998
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up It's Here
K-Models... TC4Kai conversion Kit... Have a look!! it should be out real soon... put me down for one
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽµ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-16-2004, 02:49 PM   #1999
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
damn that looks SWEET
Javen13 is offline   Reply With Quote
Old 12-16-2004, 03:15 PM   #2000
Damn thats NICE~ . Dave how much would they go for?
Old 12-16-2004, 03:20 PM   #2001
I think that the release date is up in the air and the price will be around 200$...?? ..but thats right on par with most of the stuff that they are selling
-Dave
Old 12-16-2004, 03:32 PM   #2002
damn $200 thats what the car cost, i like the BMI one to and that shouldnt be as much
Old 12-16-2004, 06:26 PM   #2003
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Default Re: Steering problem
Originally posted by Travis S
I am having a problem with my steering that I was finally was able to pin down. My problem is when I turn right or left about 70% or above I get some violent shaking at the wheels for a little bit, but then it works it way back to normal.
I thought something like my hub or foam tire was rubbing on something but that wasn’t the case.
What I figured out is that the gear that the drive shaft is connected to on the steering side and the diff bind when turn 70% or more and don’t continue to go smooth. I tried to move my gears from the back to the front to see if that would help but it didn’t… The cvds must be pushing on the diff and moving it more then it should to the side and this causes it to not run smooth with that other gear in the dif case… I have tried shimmed and un-shimmed and still had problems.
If I have it shimmed then my drivetrain is not free at all… At least if I am going to have this problem I will leave the shims out and have a much more free drivetrain.
Anyone else having this problem and have a way to fix it?
Travis, I've had this very simialar problem in my TC4. And to be honest , I have no clue how it was fixed. Well it still isnt completely fixed but I did get most of the "chatter" out. But what I did was shim up all the suspension arms and the steering carriers so that there is no play. After that, I shimmed the diff gear/ input gear very nicely so that there is no play in between teeth. This did help a litttle. What I noticed was that the cvd's bind slightly on 100% steering EPA, so I would turn that down a bit. Right now, mine is set to 80%. I noticed this horrible noise while the car is on the stand. But once I put it on the track floor, I didnt hear a thing and it didnt perform any different. 1 more thing, make sure all the upper diff case screws are nice and snug down but not overly tightend and make sure the diff is well lubbed.
Hope that helps,
Paul
Paul_TC4 is offline   Reply With Quote
Old 12-16-2004, 09:34 PM   #2004
dr_hfuhuhurr's Avatar
Trader Rating: 71 (100%+)
Anyone have a fix for the front hinge pins being too small?
Also...I got the fan kit the other day. It DEFINATELY cooled the motor down quite a bit.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-16-2004, 09:42 PM   #2005
Blake
There is a Japanese company that will be making a slightly bigger Dia. outer pin set for the front and rear for the TC4 that should be out in January... from what I have nee told they will include the reamer or drill bit to match up the rear hub and front C-hub... ...
-Dave
Old 12-16-2004, 09:53 PM   #2006
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Rumor has it that AE has fixed the problem with the molds and new arms will not have this problem.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 12-16-2004, 10:00 PM   #2007
I wonder if AE will do a swap for the people that have bout the 1st lot of cars ...?
-Dave
Old 12-17-2004, 12:48 AM   #2008
RCknight's Avatar
Default Jack Smash....
if that's true why does AE insist on keeping it on the hush...hush. You would think they would want to keep their customers informed/happy! Not one response from AE's reps here giving us an update. I guess their going to eat some crow on this one. One reason why I'm considering going to another company.
RCknight is offline   Reply With Quote
Old 12-17-2004, 12:51 AM   #2009
RCknight's Avatar
Default Any other...
rumored fixes.
How many TC4s do you guys see at your track? Just one at mine, ME. Racers are keeping their TC3, XXX-S and Pro 4s. This thread seems to be dead.
Old 12-17-2004, 02:41 AM   #2010
At the last Carpet Championship round I went too 2 weeks ago there were 5 TC4's in the A Main of 19T, finishing with a 1,2,3.
There were at least 3 in the B not sure about the rest. In 27T there were a least 3 in the A Main.
The TC4 has also begun to dominate our club nights with the last 3 rounds being won by TC4's with several 2nd and 3rd's aswell.
Andy M is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
