Like Tree45Likes
Old 12-14-2004, 02:36 PM   #1981
davepull's Avatar
with a 98 or 100 spur run a 33 pinion you can't get right @ 7.5 the way to figure final ration is
SPUR / PINION X 2.5 = FINAL DRIVE RATIO
davepull is offline   Reply With Quote
Old 12-14-2004, 02:43 PM   #1982
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
ok it doesnt matter at least its close to 7.5 but which spur can i buy that fits there good? 98 or 100?
Roberto Falcon is offline   Reply With Quote
Old 12-14-2004, 02:44 PM   #1983
do i have to buy a spur adapter for it too?
Old 12-14-2004, 03:01 PM   #1984
davepull's Avatar
No it should bolt right on. I'd run a 96. a 96 spur 32 pinion is a 7.5 final.
Old 12-14-2004, 03:08 PM   #1985
yea, so does 100/33 it doesnt really matter what number spur.
Old 12-14-2004, 03:37 PM   #1986
davepull's Avatar
ahhh yah it does
a smaller spur spins up fast = more speed
bigger the spur = more torque.
Old 12-14-2004, 03:43 PM   #1987
Speedie's Avatar
The advantage to using a bigger spur is that it has smaller gear increments than a smaller one. This helps fine tune the gear more.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 12-14-2004, 06:17 PM   #1988
ntc3freak's Avatar
what is tphalen's website?
ntc3freak is offline   Reply With Quote
Old 12-14-2004, 06:19 PM   #1989
www.competitionx.com
DOTMAN is offline   Reply With Quote
Old 12-14-2004, 06:20 PM   #1990
davepull's Avatar
http://www.competitionx.com/home/
go here
Old 12-14-2004, 06:24 PM   #1991
ntc3freak's Avatar
thanks guys.very fast reply.superb.
Old 12-14-2004, 07:47 PM   #1992
Bob Nilsen's Avatar
Lufaso posted his Cleveland Setup information at http://home.comcast.net/~mlufaso/rc/TC4/index.html
Thanks Mike!
Now let's see the other drivers setups!
Bob Nilsen is offline   Reply With Quote
Old 12-15-2004, 04:17 AM   #1993
ml
ml's Avatar
Send a message via AIM to ml Send a message via Yahoo to ml Send a message via Skype™ to ml
I'll try to post the CompX visual setup sheet later this week, but the file size is much larger.
-ML
Thanks Mike!
ml is offline   Reply With Quote
Old 12-15-2004, 04:32 PM   #1994
Jsaves's Avatar
Default Hardcore Ti. outdrives
losi xxx s,
You have said twice that you recomend hardcore ti. outdrives.
I looked on their site and only al. outdrives.
Am I missing something?
Jsaves is offline   Reply With Quote
Old 12-15-2004, 06:56 PM   #1995
Travis S's Avatar
Trader Rating: 46 (100%+)
Exclamation Steering problem
I am having a problem with my steering that I was finally was able to pin down. My problem is when I turn right or left about 70% or above I get some violent shaking at the wheels for a little bit, but then it works it way back to normal.
I thought something like my hub or foam tire was rubbing on something but that wasn’t the case.
What I figured out is that the gear that the drive shaft is connected to on the steering side and the diff bind when turn 70% or more and don’t continue to go smooth. I tried to move my gears from the back to the front to see if that would help but it didn’t… The cvds must be pushing on the diff and moving it more then it should to the side and this causes it to not run smooth with that other gear in the dif case… I have tried shimmed and un-shimmed and still had problems.
If I have it shimmed then my drivetrain is not free at all… At least if I am going to have this problem I will leave the shims out and have a much more free drivetrain.
Anyone else having this problem and have a way to fix it?
Travis S is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
