Like Tree19Likes
Old 12-11-2004, 01:51 PM   #1936
koabich's Avatar
Send a message via Yahoo to koabich
Originally posted by Andy M
I think Associated are currently collating data to come up with the basic setups. They are just trying to get it right before they release it. Remember the TC4 has far more settings than the TC3 so it will take longer to develop definitive setups.
Probably not hugely useful for you guys over there but CML Distribution have just published Olly Jefferies setup from a carpet race last weekend which he won be a country mile.
Last time I checked Olly had just stuck his TC4 into joint 5th place at the World Champs with a 1st, 2nd, 1st from the first 3 races.
Knowing Associated, I am sure they want to get the data right before they post it to the public. Concerning the lack of information, there is a very good possibility that the quality of set-ups that they are looking for have not yet been found. Sending professional drivers, like Barry, out to tracks to test, is really the only way they will figure it out.
Got a real good look at his car and it was your basix TC4 with all the graphite components. Nothing trick at all.
koabich is offline   Reply With Quote
Old 12-11-2004, 01:55 PM   #1937
PIIHB!'s Avatar
I just ordered the graphite component set. Does anybody know how much weight it cuts from the car? thanks!
~Team Wrecking Ball~
**Tamiya TA07 Pro**Gens ACE**Hobbywing**
PIIHB! is offline   Reply With Quote
Old 12-11-2004, 02:01 PM   #1938
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
I am not positive. I know this was said somewhere in this fourm but my guess is about 30 grams.
Hope that helps.
Paul_TC4 is offline   Reply With Quote
Old 12-11-2004, 02:02 PM   #1939
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
So,
does anyone have a setup for a games hall or polished wood floor??
I need some help
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 12-11-2004, 02:21 PM   #1940
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
Ran my tc4 today for the first time at the track and WOW this things is super fast faster than my pro 4 and i could tell you cause my brother ran the pro 4 and i the tc4 and and i was pretty much ahead of him like the whole time. and hes a pretty good driver. but yea i recomend you buying some hardcore racing ti. outdrives cause yeap you guest it mine front one broke! but handling this is car rips. its better than my old ft tc3 i use to have. But if people are thinking of buying it i give you 2 thumbs UP!
Roberto Falcon is offline   Reply With Quote
Old 12-11-2004, 02:22 PM   #1941
RCknight's Avatar
Default First I hope they fix some of...
the flex and slop problems. Tighen up some of the tolerances would be nice.
RCknight is offline   Reply With Quote
Old 12-11-2004, 02:36 PM   #1942
Some of the slop is due to a moulding problem that Associated are aware of and trying to rectify.
For a plastic kit, the TC4 is pretty stiff.
Andy M is offline   Reply With Quote
Old 12-11-2004, 04:14 PM   #1943
i think puting better hingpins will solve the problem!
Old 12-11-2004, 06:39 PM   #1944
G Mills's Avatar
Nope.
G Mills is offline   Reply With Quote
Old 12-11-2004, 07:15 PM   #1945
JimmyMac's Avatar
I second that. Polished hinge pins and aluminium suspension mounts did nothing for the slop. It's still there. And all new parts. But the car still drives good. I guess...
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 12-12-2004, 07:49 AM   #1946
i mean like thicker i bought some thicker ones. but i had to drill the arm and crap and i dont have all that slop i had and if i do i dont feel it.
Old 12-12-2004, 09:52 AM   #1947
PIIHB!'s Avatar
Has anybody else set their TC4 up w/ a motor fan? I've seen alot of guys at my track run them. Here's a pic:
Old 12-12-2004, 10:15 AM   #1948
lazyboy's Avatar
Send a message via AIM to lazyboy
i did, but im currently awating the AE tc4 version factory team fan
lazy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 12-12-2004, 03:55 PM   #1949
Trader Rating: 24 (100%+)
Default tc4
i just ran my tc4 for the first time yesterday and if i tapped a board it would pull the cvd out of the outdrive.i put the axle shims in front of the inside bearing so that it pushes the axle as far into the outdrive as possible.i am running on carpet with foam.has anyone had this problem , if so what can i do to fix it.
also i have to what on the car to steer entering the turn and it has an on power push.
frnt
60w/#2
white springs
arm mounts 1fr/2 -1antidive
shock t out arm out
camber link 2nd from inside one washer
steering blk ball inside
rear
60w/#2
purple springs
arm mounts 4fr/2r +2 antisquat
shock t outside arm out
camber link 2nd from inside 1 washer inside on rear hub
also i am running stock wheelbase and i have 4deg caster blks on frnt and an running -2 deg camber frnt and rear. any help would be thankfull. thanks
triplejracer is offline   Reply With Quote
Old 12-12-2004, 04:06 PM   #1950
buy some hardcore racing ti outdrives there around 21 $ with washers and the small nut.
Thats what happend to me when i ran my tc4 for the first time and then they just broke. i recomend those outdrives i state.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
