Like Tree38Likes
Old 09-19-2004, 12:31 AM   #181
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Originally posted by TPhalen
We NEVER included a graphite chassis with any Team kits....only Factory Team kits. It's basically the same as a Team TC3, except better!
Yeah I guess not...for some reason I thought the team TC3 had the graphite chassis.
So I'm guessing the gearboxes are the same?
Josh
Speedo is offline   Reply With Quote
Old 09-19-2004, 04:35 AM   #182
Originally posted by SpeedTech
andsetinn,
I'm not sure where you are generating the 30% figure, but if you're going off of MSRP ($369.99) then we went far beyond 30%. A good example would be the TC3 Factory Team kit, the price has been the same on our site ever since it was released. Maybe the pricing structure is different in your country?
Steve Wang
Hi Steve. Don't forget the "up to" in front of 30% I admit that this figure is not scientifically calculated but just an estimate based on experience. I do want to point out that when Towerhobbies first listed TC4 the price was 306$, now it's 222$. That is 27.45% price cut and the car is not even on the market yet.
Having high initial price is common among manufacturers, there is high cost of designing the product and the tools, marketing the new product. Then there are hiccups and delays that always come when starting manufacturing new product.
andsetinn is offline   Reply With Quote
Old 09-19-2004, 09:25 AM   #183
SpeedTech's Avatar
oh...hahahaha...we are talking about tower hobbies here...then it all makes sense We usually mark the price on the car with a certain percentage all across the board for all manufactures, new or old, while some shop takes advantage of a new hot car. It makes it very difficult to explain to the customer why they were charged 30% more ($306) few days ago and now it is almost 30% less ($222) I don't know how they do it but I just didn't want people to get the impression from your post that it's going to drop 30% from $220 or so (that would be impossible)
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 09-19-2004, 10:45 AM   #184
PIIHB!'s Avatar
Does anybody know if the motor clamp and cam is the same as the TC3?
PIIHB! is offline   Reply With Quote
Old 09-19-2004, 04:26 PM   #185
Send a message via AIM to micros_rock
Looks the same to me.
micros_rock is offline   Reply With Quote
Old 09-19-2004, 04:53 PM   #186
JimmyMac's Avatar
Part numbers are the same for cam and clamp.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-20-2004, 06:14 AM   #187
Super Moderator
Trader Rating: 17 (100%+)
whats the scheduled release date for the factory team car?
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 09-20-2004, 07:07 AM   #188
Suspended
McSmooth's Avatar
Lightbulb How to make a Factory Team TC4
If you have a Factory Team TC3 and want to have a Factory Team TC4, you will only need the parts listed below. This way you can avoid buying the team kit, and then having to buy all the new parts later.
I went through the TC4 manual and catalog, and compared all the parts in each step to the TC3.
Qty Part # Description
1 2221 TC4 4-40x7/16" Button Hd Cap Screw (6)
1 2225 NTC3 Bumper Top Plate
1 2229 NTC3 Swing Rack Hardware
1 2230 NTC3 Front & Rear Body Mounting Posts
1 3875 4-40 x 11/32 Button Head Screw w/ Shldr (4)
2 3916 Bearings for #3908 and 3913 (2)
1 3981 TC4 Ball Stud, Short, Black, .200" (6)
1 3983 TC4 Ball Stud, Short, Black, .300" (6)
1 6265 Steering Drag Link, molded
2 6277 TC4 Ball Stud, Long, Silver, .300" (6)
1 6915 4-40 X 5/8" Flat Head Socket Screw (6)
1 6918 4-40 X 1/2"" Button Head Socket Screw (6)
1 6926 4-40 X 5/8" Socket Head Cap Screw
1 7337 #4 Shim Washer, steel, gold (4)
1 7874 4-40 X 7/16" Socket Head Cap Screw, steel
1 9645 2-56 x 1/8 Button Head Screw (6)
1 31003 TC4 Steering Rack
2 31010 TC4 Arm Mount Shims/Balls/Wheelbase Shims
1 31015 TC4 Caster Block, 0 Degrees (2)
1 31017 TC4 Caster Block, 4 Degrees (2)
1 31019 TC4 Drive Shaft Accessories Set
1 31021 TC4 Main Drive Shaft
1 31022 TC4 Steering Bellcrank Post (2)
1 31023 TC4 Front Bumper Foam
1 31026 TC4 Front Bumper
1 31030 TC4 Shock Shaft Ball Cup
2 31034 TC4 HD CVD Bones (2)
1 31042 TC4 Carbon Components Kit
1 31046 FT TC4 Motor Mount, Blue
1 31052 FT TC4 Titanium Turnbuckle Set
2 31058 TC4 Anti Roll Bar Links
1 31060 FT Polished Hard Hinge Pin Set
1 31064 TC4 Front Aluminum Block - Triangle
1 31065 TC4 Front Aluminum Block - Circle
1 31066 TC4 Front Aluminum Block - Square
1 31067 TC4 Rear Aluminum Block - X 3.0
McSmooth is offline   Reply With Quote
Old 09-20-2004, 07:19 AM   #189
RandyB's Avatar
yeah but good luck locating these parts until a much later date
RandyB is offline   Reply With Quote
Old 09-20-2004, 07:27 AM   #190
hyperformance's Avatar
i think this will be a great car, associated has done all the chassis mods that people do to the TC3, they fixed the areas everyone complained about, added adjustability, and keep the price about the same. if the team kit had the upgrade chassis in the box i would order one TODAY
so when will the factory chassis be availible? i may get a team kit the add the chassis later
hyperformance is offline   Reply With Quote
Old 09-20-2004, 10:51 AM   #191
Steve Wang
The TC3 team was just over 200$ for new one and I would not suggest that you can get the TC4 Team at much lower price. The TC4 started at over 300$ and it just might bottom out at 200$ in six months to year when the manufacturing is up to speed.
TC4 buyers check this out. Should anyone have the TC4 in their basket at Towerhobbies, check the partnumber and price. The one I just removed was number LNHZB9 and it was still priced at 306$ (I preordered one from Speedtechrc instead. Shameless plug I know, how about some discount. )
Old 09-20-2004, 12:59 PM   #192
i was at the tower site yesterday and the team kit was 221.99 (#_LXHZB9)
http://www2.towerhobbies.com/cgi-bin...&I=LXHZB9&P=ML
they've got their "spend $200 save $20" deal going now, too bad the car isn't out yet.... 221.99 - 20 = new TC4 for 201.99
Old 09-20-2004, 01:36 PM   #193
Charlie O's Avatar
Default Release date
Is the scheduled release date still the end of the month?
Charlie O is offline   Reply With Quote
Old 09-20-2004, 05:19 PM   #194
I hope this car comes out at the end of the month. I want one soooo badly now. Got to look at Mike Blackstock's car up close and raced with him in mod TC at the Gate yesterday. His car still had an asphalt setup on it when he arrived at the track. He redid almost the entire setup to run on carpet with foam tires, basing it off of his old TC3 setup and some guesstimation. Did one practice run, made some more changes like removing the rear swaybar, changing the front and rear roll centers, etc. I don't think he really changed it at all the rest of the night, it was pretty dialed already. When asked what he thought of the car, he says it has more steering than the TC3, but is more stable and easier to drive. And this with a pre-production car that's still all plastic!
I can't wait to get mine and get the graphite chassis kit. It also looks like the air induction system will be a must have. One thing Mike told me was to immediatley put 3/4 oz of weight on the right side of the car to get the balance close. But I suppose that all depends on what radio gear you have.
Stealth_RT is offline   Reply With Quote
Old 09-20-2004, 06:31 PM   #195
PIIHB!'s Avatar
Yea steve. I put in a plug for speedtech too! How bout a nemisis body and speedtech decals too?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
