Like Tree26Likes
Old 12-07-2004, 05:02 PM   #1906
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Originally posted by LoSi xXx S
anybody got a nice setup for a small track? track is 80ft X 50ft
I would start with the stock setup with less toe-in for the rear and tune from there. If you want the car to be more agressive for those tight corners, move either the front or rear arms back.
Originally posted by RCknight
I need a longer cvd axle. The treads don't go into the axle nut far enough with wheel spacers. I'm using low profile wheel nuts. Is there another car brand that has a longer cvd axle than the TC4?
Does anyone use a wider wheel base just in the front? How does this affect the car's handling?
Most of the time I run the locknuts backwards. I have even had to do this with the low-pro's. Havent seen any longer axles.
As far as running the front wider than the rear, it tends to give the car more corner entry steering but the rear end may start to come around mid corner.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 12-07-2004, 05:25 PM   #1907
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Need help...
Square makes a Axle that uses a 4m nut like most metric cars and it has a bit more lenght on the threads.. also TOBEE Craft makes a thinner Hex clamp that will allow more of the Nut to lock down.. but the trade of to this is that the wheel trak becomes a bit narrow and you will more than likely have to grind a bit off of the front steering knuckle to make 28mm or 30mm foams fit.?
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-07-2004, 06:01 PM   #1908
RCknight's Avatar
Default Thanks guys.
All I need is about 2mm longer (threads) and it would be fine. I used some thread lock, maybe that will work long enough for racing day. Going to try
RCknight is offline   Reply With Quote
Old 12-07-2004, 08:02 PM   #1909
RCknight's Avatar
Default Man, I hate building AE shocks!
I can never get them to all rebound the same. I build them according to the instructions and they never all come out the same. Then I have to wait until all the air is gone and start over again. What a waste of time!
I can't wait to get a few sets of Losi's new shocks. I'll bet there nice, smooth and easy to build. I'm glad they are a neutral color.
Old 12-07-2004, 08:06 PM   #1910
stulec52's Avatar
Trader Rating: 26 (100%+)
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
they are not a waste ( spelt WASTE, not WAIST f.y.i.) of time.
you are just not quite getting the knack of building them.
I find if you fill about 3/4ers, then pump the air out then top off.
They all come out very very close for me that way.
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
Old 12-07-2004, 08:08 PM   #1911
RCknight's Avatar
Default Anyone find some fixes for the steering...
Anyone still using the stock servo link. I have about 2-3mm of play left/right I would like to get solved.
Also I noticed the shocks rub on the c-hubs. Anyone have to shim the bottom end of the shock?
If you mount the shock one in on the bottom and one in on the top, is the shock angle the same as if you had it on the outer settings? Or does this change the handling?
Old 12-07-2004, 08:15 PM   #1912
I have a problem bleeding the shocks, they never seem to bleed, I fill them up and get rid of air and go to bleed and nothing really comes out...lol some times it works good and others its horrible. I dunno, I like the losi's better.
runnin rc10 is offline   Reply With Quote
Old 12-07-2004, 08:21 PM   #1913
RCknight's Avatar
Default Yes, yes, I know....
thanks for the SP lesson. I know the difference. I'm A.D.D. it's hard for me to pay attention. I hate writting!
Old 12-07-2004, 10:01 PM   #1914
Jack Smash's Avatar
Default Re: Anyone find some fixes for the steering...
I think you have to grind the c-hubs a bit to keep the bottom of the springs from rubbing.
If you mount the shock on the inner hole, it gives the shock less leverage so that it feels softer.
Old 12-07-2004, 10:15 PM   #1915
Trader Rating: 15 (100%+)
Default shocks
first off change to the yok caps with the bleed holes .. perfect every time same rebound no matter what.. next run one .060 shim behind the ball stud for the shocks to clear...they usually only hit with less than 4 deg blocks. for the steering slop its the center mounts ..just ad one 3 mill shim under the rack and it will get most of the slop out.
AARON YOUNG is offline   Reply With Quote
Old 12-08-2004, 01:16 PM   #1916
RCknight's Avatar
Default AARON....
I'm not sure what you mean by the "Center mount." Put a 3mm shim where? Do you mean replace the spring with the 3mm shim? I put two shims under the steering posts which helped some.
Old 12-08-2004, 01:20 PM   #1917
RCknight's Avatar
Default If going to the bottom inside....
hole makes it less stiff, should you go with a harder spring if I have too much over steer again?
Old 12-08-2004, 01:21 PM   #1918
Stiffer Front = Less Off Power Steering
Softer Back = Less On Power Steering
Andy M is offline   Reply With Quote
Old 12-08-2004, 01:23 PM   #1919
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Originally posted by protc3
hey guys,just wanted to show you the new kit i am working on for the tc4.let me know what you think
Well, I got 6 Losi XXX-S, and three more to come (I don't plan on switching to the JRXS, and I want to have all the parts in multiples so I can run the car for years to come) and now I think I might have to throw a TC4 into the mix, this chassis is awesome, can't wait to get one for the rug, maybe for stock, run Losi for everything else on the rug.
How do yall like the steering on the TC4, I just got rid of 2 TC3's and I liked the steering of a XXX-S better (it feels smoother) I was just wondering what the racers thought.
tc3stocker is offline   Reply With Quote
Old 12-08-2004, 02:01 PM   #1920
RAP66's Avatar
Originally posted by tc3stocker
<edit>
I like the car, compared to my TC3s it feels more planted and more reactive. I ran it box stock (except the shoil oil 60/40 #2 pistons) on the rug, with Jaco red/red. Aside from my hacked driving I felt the car was railed (provided I paid attention to the race line)
Rich Pedro
rap66@rcracing.com
www.rcracing.com
RAP66 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
