Like Tree31Likes
Old 12-06-2004, 09:35 PM   #1891
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Slopy Joe
Originally posted by swb
Maybe I missed this,63 pages is alot to go through, but does anyone know if AE is going release a Factory Team TC4 suspension slop shim kit? any help would be welcome
Doubt it... What I used ti get rid of some of the Play/Slop... was some .7mm & 1mm tamiya silver shims that are used on there cars to space out the sus arms... They work quite well.
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-06-2004, 09:50 PM   #1892
swb
Default slopy
Thanks Dave,,
my arms are shimed tight front to back, but have no way to take slop out of where the hingepin/plastic ball go into the pin block, so I guess I should ask if anyone knows of a "Factory Team" (correctly molded) sus. arm block set
swb is offline   Reply With Quote
Old 12-06-2004, 10:01 PM   #1893
Default Re: slopy
Thanks Dave,,
I think that the Plastic Ball that AE makes is about .5mm to small in Dia. so this is where some of the Slop is coming from... I was able to reduce some of it by applying a small about of thread lock around the plastic balls..... some what of a temp fix but you will need to re-apply it after a day at the track.. but you will notice some of the play go away...something else to try out
-Dave
Old 12-06-2004, 10:06 PM   #1894
swb
Default Re: Re: slopy
-Dave
Have you tried the alum. blocks? and did they help
Old 12-06-2004, 10:12 PM   #1895
JDM......what I do is apply plastic bag around plastic pivotball then push the ball in....works great.....
Barry
Barry Baker is offline   Reply With Quote
Old 12-06-2004, 10:18 PM   #1896
Barry
Thanks for the Tip Barry! I'll give that a try
Old 12-06-2004, 10:19 PM   #1897
Default Re: Re: Re: slopy
I am using the Alloy Block now I have less play now than when I used the plastic ones
-Dave
Old 12-06-2004, 10:24 PM   #1898
THeGame's Avatar
Send a message via AIM to THeGame
Default Baker
when are you going to post your setup from the champs ???
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 12-06-2004, 10:26 PM   #1899
swb
Thank you, ill try both
Old 12-07-2004, 05:55 AM   #1900
CRASH's Avatar
Trader Rating: 26 (100%+)
Originally posted by Jack Smash
If the rear doesn't feel that planted then I would make the tire change and not change the bar. There is almost no reason to use plaids and purples anymore since the Orange/ Dbl pink and dbl pinks came out.
Is this even the trend know for stock? I new it was for mod and 19 turn.
Thanks,
CRASH is offline   Reply With Quote
Old 12-07-2004, 06:58 AM   #1901
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Yes, unless you are running on some crazy carpet that gives no traction and need to get side bite back.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 12-07-2004, 11:49 AM   #1902
Trader Rating: 17 (100%+)
Send a message via AIM to Roberto Falcon
anybody got a nice setup for a small track? track is 80ft X 50ft
Roberto Falcon is offline   Reply With Quote
Old 12-07-2004, 11:56 AM   #1903
theres pic of the track but the layout is different now.
Old 12-07-2004, 04:52 PM   #1904
RCknight's Avatar
Default Need help...
I need a longer cvd axle. The treads don't go into the axle nut far enough with wheel spacers. I'm using low profile wheel nuts. Is there another car brand that has a longer cvd axle than the TC4?
Does anyone use a wider wheel base just in the front? How does this affect the car's handling?
RCknight is offline   Reply With Quote
Old 12-07-2004, 04:56 PM   #1905
stulec52's Avatar
Send a message via ICQ to stulec52 Send a message via AIM to stulec52
Default Games Hall Setup
Mostly I think this would be for the UK guys.
ANyone got a good setup, or at least starting point, to run the TC4 on a games hall floor?
You know the sort of thing, Schumacher 20 mm Yellow Minipins, and next to no grip.
E-mail me with any help as I am doing an event back in Scotland, but coming from Canada I want to try to get a setup before I get there.
thanks
www.pmhobbycraft.ca/store/
www.tamiyaclub.com/
stulec52 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Joe Maxey
