Team Associated TC4
#1878
Registered User
hey learn how to put it toghter first.
#1879
On the nose Stogie
#1880
What's the website for BMI Racing?
#1882
hey guys need some help with my ride
hey guys give me some setup help.ive got a tc4 and need more on power steering.im happy with the car off power.heres my current setup
front
shocks outside hole
30 wt oil
2 hole piston
blue spring
4 degree castor blocks
2 degrees kick up
longest camber link holes
rear
inside hole on tower
30 wt oil
gold spring
short camber link
2 degree rear toe block with losi
1 degree blocks on the car backwards
to make the rear toe 1 degree
rear hinge pins level no anti/pro squat
tires are cs27s
the track is medium to high bite asphalt
with a couple of sweepers wher im struggling
any thoughts?
front
shocks outside hole
30 wt oil
2 hole piston
blue spring
2 degrees kick up
rear
30 wt oil
gold spring
short camber link
tires are cs27s
any thoughts?
#1883
So it sounds like this is more an attribute of medium-to-high bite conditions than anything else... Many of us are having the same problem on carpet with foam tires. Ran the car on some low-bite ozite this weekend and the car rotated TOO well.
Like everything else about the car. Well, nearly everything.
#1885
Any body have a great setup for...
tight, high traction, ozite carpet for stock? I just want to compare setups.
My setup is;
Front
60 weight, yellow springs, top-second from outside, bottom-outer, 4* castor, .50 kickup, standard hinge pin shims, one ballstud shim, ride height 4.0, second ball stud link in, 1*toe, thickest swaybar, plaid foams.
Rear
40 weight, purple springs, top-outter, bottom-outter, arms forward, .5 pro squat, Losi rear wheel hubs forward, 1.5 rear toe, longest tie rod, ride height 4.5, purple rear foams, Mazda 6.
My problem is that I can't get cornering speed off power.
My setup is;
Front
Rear
#1887
Thanks Jack...
what will that do? Am I getting too much traction and scrubbing speed in the corners? Altough the rear doesn't seem heavily planted.
#1890
Slopy Joe
Maybe I missed this,63 pages is alot to go through, but does anyone know if AE is going release a Factory Team TC4 suspension slop shim kit? any help would be welcome
