Like Tree19Likes
Old 12-03-2004, 10:43 AM   #1861
Skip109's Avatar
Originally posted by protc3
hey guys,just wanted to show you the new kit i am working on for the tc4.let me know what you think
If you cant Innovate, Imitate
Skip109 is offline   Reply With Quote
Old 12-03-2004, 02:55 PM   #1862
protc3's Avatar
imitate?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-03-2004, 03:04 PM   #1863
Default Re: Protc3...
Originally posted by RCknight
can you remove the diff cases without removing the upper deck?
Looks like he has holes drilled to access the diff case screws
DOTMAN is offline   Reply With Quote
Old 12-03-2004, 03:09 PM   #1864
protc3's Avatar
thats correct dotman.thanks for answering. you will be able to remove the top half of the diff case while the car is assembled.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-03-2004, 03:17 PM   #1865
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to HVFracingwilly
Curios what kinda price range are we talking for the new chasis and when will it be available.
Hobbytown USA Oshkosh
www.revolutionraceway.com
HVFracingwilly is offline   Reply With Quote
Old 12-03-2004, 03:23 PM   #1866
protc3's Avatar
it is going to run around the same as my tc3 kits.(109.99)
it should be ready before the end of the month
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-03-2004, 03:25 PM   #1867
where do i pick one up?
Old 12-03-2004, 03:27 PM   #1868
Send a message via AIM to Johnnytc3
is it stiffer than the stock graphite chassis?
Johnnytc3 is offline   Reply With Quote
Old 12-03-2004, 03:33 PM   #1869
lazyboy's Avatar
Send a message via AIM to lazyboy
harsh skip...harsh...jason does fabulous work down there in sunny state of FL...
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 12-03-2004, 03:50 PM   #1870
Scrad's Avatar
Trader Rating: 15 (100%+)
Has anyone else purchased the TC4 lightened steel outdrives. Well I did and it doesn't use the D ring washers for one. Plus there is no notch for the diff nut to sit in. I had to use a screw driver to get it to tighten down. When I did get it tightend down the thing binds up. One side of the outdrive has a larger diameter and I think it hits the diff gear.
The TC4 handles good and is fast, but it is such a piece of crap. There are so many things wrong with it. Granted they can be fixed but I paid good money and it should be right the first time. I think AE has a bunch of morons designing this kit. I'm so disappointed with the quality.
Scrad is offline   Reply With Quote
Old 12-03-2004, 03:56 PM   #1871
51
51's Avatar
Scrad: The lightened steel outdrives use the same rebuild kit as the standard steel diff. The plastic outdrives are the only one that uses the "D" ring and aluminum lock nut. If you try to run the lock nut with either one of the steel diffs you'll have nothing but problems slipping the diff.
To correct this, use part number 3926 (Diff Rebuild Kit, for steel diff) along with the same diff balls and gear that came with your kit and everything should work fine.
51 is offline   Reply With Quote
Old 12-03-2004, 07:08 PM   #1872
Skip109's Avatar
Originally posted by 51
Actually the smallest one is incorrect. The sway bar thicknesses are as follows:
Black = 0.055
Silver = 0.063
Gold = 0.078
You are right that was a B4 bar. ( hmmm. the are the same....)
Old 12-04-2004, 05:22 PM   #1873
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Jason... Pre-Orders.??
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-04-2004, 06:05 PM   #1874
Stogie's Avatar
"Longhorn fan" & Mr.BMI... knowing Skip, I don't think that's what he's getting at - more the ditch of the molded chassis and the move to graphite, like so many of Associated's competitors - Tamiya, Losi, HPI... Nobody's disputing BMI craftsmanship.
... or am I reading it wrong, Skipper?
☆☆☆ Chad Stowe ☆ ready to run some Mod TC again, finally ☆☆☆
Stogie is offline   Reply With Quote
Old 12-05-2004, 06:35 PM   #1875
EricF's Avatar
I'd have to agree that Assoc. should have included a instruction sheet or given more details as to which additional items will be required for the lightened diff. change. Mainly for those that are not fimilar with AE diff's.
Other than that I have no complaints.
E
EricF is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
