Like Tree26Likes
Old 11-29-2004, 09:22 PM   #1816
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Originally posted by Lebatek
Chris,
My car is all carbon fiber -- chassis, arms, towers, everything.
c/f arms?
Speedo is offline   Reply With Quote
Old 11-30-2004, 02:46 PM   #1817
Default Cleveland Carpet Setup
This is the setup I ran to qualify 8th inMasters at the Cleveland US Indoor:
Front:
60w, number 3 pistons, white springs, outer mount top, inner mount on arms
front/front block flat on chassis, no spacers
front/rear block .050 spacer
6* C-blocks
0* toe-in
1.5* camber
camber links low and long
Rear:
40w, number 3 pistons, purple springs, outer mount top and bottom
use circle block instead of triangle mount for front mount
2* toe-in block rear (this gives you almost no toe-in)
1.5* camber
Batteries in front
Tires, 2.25" double pink/orange, double pink
Parma Alpha
For me, this was a pretty good setup......not perfect but a good place to start. Since I only had the car a week before, I'm reasonably satisfied. Would have liked to get some laps in the main but got in the second turn pile up resulting in a broken steering block.
Any questions, just ask.
skipstr is offline   Reply With Quote
Old 11-30-2004, 02:53 PM   #1818
2Fast4U2's Avatar
Skipster, Interesting that you had .5 in rear and no spacers in front. Quite a bit of difference. Any reasoning for the height in the rear compared to the front.
2Fast4U2 is offline   Reply With Quote
Old 11-30-2004, 03:23 PM   #1819
Jack Smash's Avatar
Trader Rating: 29 (100%+)
He has a .050 spacer on the circle mount on the front of the car for some anti-dive.
I have joined the steering block breaking club big time this past weekend. 2 TC4 steering blocks and when I ran out of those I broke 3 TC3 ones and then an arm. Never broke a TC3 steering block on a TC3. All of them were caused by driver clipping pipes or getting sideways in front of a field of Mod cars.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 11-30-2004, 03:30 PM   #1820
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I belive that Square has some Alloy Steering Blocks for the TC4 in the works.... it might be next year Jan before they come out though
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-30-2004, 03:36 PM   #1821
2Fast4U2.........Jack Smash is right, that configuration gives you anti-dive which seems to be a common setup for high traction carpet on other types of cars as well. The antidive seems to give you the turn-in you are looking for without the suspension compressing and dragging the front corners of the chassis when running low ground clearance. It would also seems to keep the dynamic caster closer to the static caster.
Old 11-30-2004, 07:33 PM   #1822
Peter Busch's Avatar
Default Re: Cleveland Carpet Setup
Front:
6* C-blocks
0* toe-in
1.5* camber
Rear:
1.5* camber
Batteries in front
Parma Alpha
I assume you didn't put any spacers in the rear of the car and what about swaybars?
Peter Busch is offline   Reply With Quote
Old 11-30-2004, 07:51 PM   #1823
Peter Busch
No spacers under the rear arm mounts, no sway bars. In the future, I will be trying both. The problem we encounter is the conditions(traction available) is almost never available while club racing. Swaybars were on my list of things to try, just ran out of time.
Old 11-30-2004, 08:15 PM   #1824
2Fast4U2's Avatar
skipster- understand now. I misread the post. I saw the front/rear and thought none under the front and .50 under both rears. On mine I noticed that it has alot less rear traction compared to the tc3. Something I was not ready for. I am trying to get that taken care off. I am runing really small carpet track. I will be trying out some sway bars next time out. Its fast, just not as stable as my tc3. But that will come. Even with it on the portly side of the weight scale. When I get the 2 ounces off with the graphite kit, should be better.
Keep us informed about your learning as will I.
Old 12-01-2004, 09:27 AM   #1825
dmatter's Avatar
Can anyone tell me where to find shim kits for the TC4? I bought some for my Kids Radio Shack Cars. But I think I need a Couple more pounds of them for My TC4. I did a Set Screw set up in the Caster Blocks (like the TC3) But still very Sloppy.
dmatter is offline   Reply With Quote
Old 12-01-2004, 12:15 PM   #1826
Shims only take out some of the play. The problem is the hole is too big where the hinge pin slides through. You can fix that with CA but is a pain in the butt.
Skipstr, I know what you mean about the traction, it must have been unreal at Cleveland.
Old 12-01-2004, 12:30 PM   #1827
Charlie O's Avatar
Off power push, but perfect on power steering, kit setup, no shims under rear camber links, 2 in front though, gold springs rear silver front 30wt rear 40 front 5 mm ride ht, batt front, 1deg total toe out, 1/2 deg neg camber anybody got a simple fix? thanks.
Charlie O is offline   Reply With Quote
Old 12-01-2004, 03:21 PM   #1828
dmatter.....Several pages back in the sale swap section, there's a guy that sells high quality , very durable, dupont teflon shims in 5, 10, and 15 thousanth thicknesses.....Iv'e bought from him a couple times.......His prices are really fair also.........His E-mail is breiser652@aol.com Joe B
1/8 Scale: Tekno EB-48.2... Tekin RX-8 GEN-2 W/2050kv... Airtronix M11-X Radio... HiTec HS-7954SH Servo...
1/10 Scale: Associated B-5(rear motor)...Tekin RSX Gen-2 W/8.5t... Savox SC-1258-TG Servo
Joe B is offline   Reply With Quote
Old 12-01-2004, 06:56 PM   #1829
Fatboy Joe's Avatar
Default TC4 Spool Set-up
Hi, any tips on a spool set up? Thanks in advance
Fatboy Joe is offline   Reply With Quote
Old 12-02-2004, 04:20 AM   #1830
ntc3freak's Avatar
how is the tc4 performing for u guys?
ntc3freak is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
