Like Tree19Likes
Old 11-28-2004, 05:31 PM   #1801
Peter Busch's Avatar
R/C Tech Charter Subscriber
Default Re: adjustable roll center?
Originally posted by rcdave905
I have been driving sedans for a while now, and have one of those stupid questions.
What does everybody mean about the TC4 having adjustable roll centers?
Please explain it to me.
Thanks in advance
Read the back of the book, its in there.
Does anyone know what setup they were running in Cleveland?
Peter Busch is offline   Reply With Quote
Old 11-28-2004, 07:59 PM   #1802
iamramos's Avatar
Default carpet setup
could someone please post a carpet setup for the tc4..foam jacos plaid and purples..
iamramos is offline   Reply With Quote
Old 11-28-2004, 08:37 PM   #1803
Lebatek's Avatar
Send a message via AIM to Lebatek
Default Carpet Starting Point
Without too much variation from the stock setup, I changed only the spring, pistons, oil, shock mounting location, caster and added front swaybar for a carpet race. The car was awesome! Good rotation and corner speed but stable and easy to drive.
Camber locations/washers: stock (from instructions)
Battery: front
Body: Mazda with wing forward
Tires: rear purple, front plaid (Murdock RC tires)
Front:
Purple spring, #3, 60W, upper mount: hole 2 (2nd from inside), lower mount: inner hole, droop 4, black TC4 swaybar, ride height 5mm, .5 degree toe-out, 4 degrees of caster.
Rear:
Red spring, #3, 40W, upper mount: hole 3 (3rd from inside), lower mount: outer hole, droop 6, ride height 5mm, 3 degree toe-in.
After the other team guys get back from Cleveland we can compare and tweak further. Good luck!
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 11-28-2004, 09:39 PM   #1804
Send a message via ICQ to tc3Guru Send a message via AIM to tc3Guru
if any of you guys get the bmi chassis please post on how it goes. thanks.
tc3Guru is offline   Reply With Quote
Old 11-29-2004, 06:23 AM   #1805
Lebatek's Avatar
For those who asked, it was used on a small, tight, indoor track with relatively new Ozite.
I ran out of time to try other things, but quite frankly the car was doing nothing wrong on this particular track.
John Lebak
Old 11-29-2004, 11:31 AM   #1806
tc3Guru, I believe BMI is still working on a prototype chassis for the TC4. Some extra stuff needs to be on the chassis, compared to the TC3 one, to take care of the camber rod mounting, as it is not part of the shock tower like on the TC3. I am looking forward to seeing BMI's setup too, as even with the graphite parts, I feel the TC4 has too much torsional flex in the chassis.
Stealth_RT is offline   Reply With Quote
Old 11-29-2004, 11:57 AM   #1807
dr_hfuhuhurr's Avatar
Trader Rating: 71 (100%+)
Here's what I'm using on a tight ozite track. Car is really easy to drive. Need to work on it a bit more to get it even better.
http://www.rcohio.com/rcohio/html/mo...download&cid=1
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 11-29-2004, 12:54 PM   #1808
Who has the full graphite component sets in stock?
Old 11-29-2004, 03:33 PM   #1809
Trader Rating: 194 (100%+)
Hi guys, just wanted to let you know that we received a shipment of some more TC4 parts in today, including all the Aluminum Arm Mounts, and we are also running a special for R/C Tech members where you get a whopping 200 free All-Star Points if you place an order today! For more info please see our post here:
http://rctech.net/forum/showthread.p...threadid=55668
Thanks everyone for your time!
All-Star is offline   Reply With Quote
Old 11-29-2004, 04:17 PM   #1810
rcboyz on ebay does i do believe.
Old 11-29-2004, 06:08 PM   #1811
lastplace's Avatar
Send a message via Yahoo to lastplace
Blake
Blake,
I've been running close to the same set up and it is dialed in. I'm going to move the front lower shock mounts in to stop the wheels from hitting them. Have you had trouble with excessive front tire wear?
lastplace is offline   Reply With Quote
Old 11-29-2004, 07:02 PM   #1812
If you move the link to the inside hole on the steering knuckle your wheels won't hit the shock bottom. I haven't run it like that so I'm not sure how its going to handle.
Why is everyone running the #3 pistion with thinner oil? Just curious.
Old 11-29-2004, 07:02 PM   #1813
I don't have much time on the car yet. I didn't notice anything abnormal in the 1.5 race days I have on the car no.
I'll be practicing tomorrow night then a club race Wed. evening. I'll post if I change anything on that setup.
Blake
Old 11-29-2004, 07:08 PM   #1814
Charlie O's Avatar
SoCal raceway has a lot of carbon fiber parts including the chassis.
Charlie O is offline   Reply With Quote
Old 11-29-2004, 07:27 PM   #1815
Lebatek's Avatar
Chris,
My car is all carbon fiber -- chassis, arms, towers, everything.
John Lebak
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
