Old 11-19-2004, 02:25 PM   #1666
diskostew's Avatar
Send a message via Yahoo to diskostew
No i run on high traction asphalt. i run front and back swaybars. also the kit comes with 3 differnt size bars. pretty cool...
diskostew is offline   Reply With Quote
Old 11-19-2004, 02:26 PM   #1667
diskostew's Avatar
also you have to buy 2 swaybar kits, one for the front and one for the rear...
Old 11-19-2004, 02:29 PM   #1668
RCknight's Avatar
Default was wondering if....
the stock guys were just running one. I'm cheap.
RCknight is offline   Reply With Quote
Old 11-19-2004, 02:31 PM   #1669
diskostew's Avatar
Default Re: was wondering if....
I run stock and i run both... I think it is wort it. my car feels great. verry responsive! well worth the money!
Old 11-19-2004, 02:48 PM   #1670
Jack Smash's Avatar
Trader Rating: 28 (100%+)
You can probably get away with just the front bar on carpet. Most of the carpet setups I've seen for the TC4 have only used a front.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 11-19-2004, 10:10 PM   #1671
Scrad's Avatar
Trader Rating: 15 (100%+)
Did anyone else notice that their foams rub on the steering knuckes? I had to shim the axle and grind away some of the knuckle. Now I remember why I got rid of my TC3 and got my xray's.
Scrad is offline   Reply With Quote
Old 11-20-2004, 01:33 AM   #1672
johnbull's Avatar
Hi friends.
You're in luck. I just got a parcel with both bits this morning so here are some numbers.
YOKOMO alloy shock cap set with bladders (pair) YS - 8D.
YOKOMO silicone shock seals YS - 7S.
Hope this helps.
johnbull is offline   Reply With Quote
Old 11-20-2004, 06:18 AM   #1673
CRASH's Avatar
Trader Rating: 26 (100%+)
Default toe in mod question
RBLove said to use the front block "O" on the inner and the 3Degree Rear block for about 1.5 of toe. Is this right or do I have to leave the stock Square Block in place and run the "O" block in the rear?
Thanks,
CRASH is offline   Reply With Quote
Old 11-20-2004, 09:56 AM   #1674
dr_hfuhuhurr's Avatar
Trader Rating: 69 (100%+)
You have it right.
Inner rear block is the 0, outer (rear) rear block is the 3*.
I'm actually running my exact setup from my TC3 1* rear toe in the rear.
0 block in the front rear, 2.5* block in the rear rear.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 11-20-2004, 10:17 AM   #1675
Bob Nilsen's Avatar
I ended up keeping the rear square block in place and replacing my X block with a Circle... mostly 'cause it's a hassle to get to the square block out w/o removing the tranny case.
This should yield a decrease in rear toe by about 1.66 degrees... making it about 1.44. Is this too little for foam on carpet?
Bob Nilsen is offline   Reply With Quote
Old 11-20-2004, 02:44 PM   #1676
Bob Nilsen's Avatar
I sent in my melted diff and broken rear carrier blocks in to AE and much to my delight I just received a new lightweight diff (with bearings in the package, no less ) and new carrier blocks.
Interestingly, the bag with the blocks had *two* steering knuckles and *two* rear carrier blocks. The first two times I bought this part there were only one of each in the bag... so I guess they corrected that.
Happy AE customer!
Old 11-20-2004, 03:24 PM   #1677
CRASH's Avatar
Default Thanks
Originally posted by dr_hfuhuhurr
You have it right.
Blake
Thanks, just wanted to make sure I was reading it correctly. Off to go compete with a bunch of BMI Xrays.
Later,
Old 11-20-2004, 03:28 PM   #1678
G Mills's Avatar
I picked up some carbon hub carrier and steering knuckles from my local hobby shop. They had 2 packs on the wall. One with two sets of each and the other only had one set of each. The amazing thing was that they were the same price!
Greg Mills
G Mills is offline   Reply With Quote
Old 11-20-2004, 05:14 PM   #1679
I am pretty sure that Associated packaged a bunch of plastic or carbon version Steering Blocks & Hubs completely wrong. They always package the TC3 or TC4 ones with 2 of each in the package.
Probably a mistake on part of the employees in that section of the plant or instructions to them by management.
Yokomo BD7 2016, Tamiya TRF419, Xray X12 2015, Associated B6, B6D, B5M Factory Lite, B44.3, RC8B3, RC8B3e
My Outdated R/C Car collection:
Associated B44, Associated NTC3, Tamiya TRF415, TRF415 MSX MRE, TRF416X
190mph is offline   Reply With Quote
Old 11-20-2004, 09:30 PM   #1680
lastplace's Avatar
Send a message via Yahoo to lastplace
I finially got a chance to run some laps on carpet with my TC4. I think I've found a pretty good set up:
Front: 60 wt, Purple spring, #1 shock tower hole, 4 deg caster block, 1 deg Camber, Plaid Foam
Rear: 40 wt, Copper spring, #4 shock tower hole, 2 deg (0 Block) Toe in, 1.5 camber, all arm spacers back for a short wheeel base, Purple foam
.25 shims Front & Rear Blocks, Camber links inside with 1 shim (.30), 5mm ride height, Battery up front, traction compound only on rear.
Front & Rear arms shimed to remove slop.
The car drives like it's on Rails. Maybe now I can get out of Lastplace!
lastplace is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
