Old 11-17-2004, 04:10 PM   #1621
Coxy's Avatar
R/C Tech Charter Subscriber
I also don't know what's going on with the AE shocks. I have had AE shocks for years and never had a problem with them but the new TC4 ones blow out all the time. I will be replaceing them with what I think are the best shocks HPI/Tamiya hybrid shocks.
Coxy.
Coxy is offline   Reply With Quote
Old 11-17-2004, 04:20 PM   #1622
PIIHB!'s Avatar
I installed Tamiya Flourine coated TRF shocks after the first night of racing the car. Best shocks out there.
~Team Wrecking Ball~
**Tamiya TA07 Pro**Gens ACE**Hobbywing**
PIIHB! is offline   Reply With Quote
Old 11-17-2004, 04:46 PM   #1623
What shocks are you guys blwoing out? The blue kit ones of the FT ones? I race their offroad stuff and have unobtanium shafts with the threaded bodies and never have problems. I use the green slime and replace the orings every few months...
I have no previous experiance with the Tamyia shocks... Why ar ethey better?
Just remember, nothing is free.
ultragraffics is offline   Reply With Quote
Old 11-17-2004, 05:09 PM   #1624
Peter Busch's Avatar
Not sure how to search just this thread, I'm sure I saw some posts awhile back about people making swaybars. I just wanted to get some idea's on how to do it.
Peter Busch is offline   Reply With Quote
Old 11-17-2004, 05:16 PM   #1625
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Originally posted by Coxy
I have done a pretty cool/interesting spreadsheet of weights of all the carbon v's plastic v's alloy parts, if your interested email me at coxycrc@yahoo.com .
I also agree the toe blocks should be made in plastic, the alloy ones and so heavy to the plastic ones.
I have been using Losi castor blocks in the front mainly to get rid of the slop from the AE ones. The losi ones only need a slight flie to sit them in the arms and there is zero slop. I also take out one of the arm spacers and replace it with a Tamiya 1mm spacer, again zero arm slop with this little bit extra thickness.
I must say the polised hinge pin set is a real good option. Takes out a lot of slop and is way smoother.
The new chassis def makes the car pretty stiff. I think the only thing I can't get yet is the roll bar mounting kits. Not interested in the bars as I make my own, but the mounting gear seems to be the hardest to get.
Coxy.
Mails sent your way
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64d
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-17-2004, 05:53 PM   #1626
From me too
Andy M is offline   Reply With Quote
Old 11-17-2004, 06:24 PM   #1627
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
to run sway bars on a tc4 you could run tc3 arms by drilling the hole out with a 7/32 drill bit and then you could run the tc3 sway bars on the tc4
Javen13 is offline   Reply With Quote
Old 11-17-2004, 06:32 PM   #1628
Jack Smash's Avatar
Trader Rating: 28 (100%+)
You also need to trim the outside camber hole off the chassis braces for the bar it self to clear.
Kyosho / Orion / Amain.com / Protek
Jack Smash is offline   Reply With Quote
Old 11-17-2004, 06:33 PM   #1629
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
It's actually 7/64, not 7/32. Unfortunatly due to the inability to get option parts, I have already done it.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 11-17-2004, 07:14 PM   #1630
PIIHB!'s Avatar
They just are! ok?
They are really smooth. The threads are soooo much finer then the ae shocks. They are a bladder design which makes them easier to get smooth w/ no air.
Old 11-17-2004, 07:30 PM   #1631
fathead's Avatar
Making the swaybars themselves is really pretty easy.
Go to your LHS and they will most prob have a good selection of sizes of piano wire, can't remember the standard TC3/4 bar thickness, should be easy to find out, then buy a length of wire the same size plus one smaller and one bigger.
Then it's as simple as bending the wire with a pair of pliers to match or bending to fit if you haven't got a sway bar
Slavich Design
fathead is offline   Reply With Quote
Old 11-17-2004, 07:42 PM   #1632
thanks for correcting me thats what i ment
Old 11-17-2004, 08:08 PM   #1633
Charlie O's Avatar
Default NTC-3 bumper grommets part #
Originally posted by ghoppa
question,
Charlie, I was @ my LHS "lookin" through a NTC3 manual, and I did not notice the "grommets" for the bumper anywhere in the instructions....whould you happen to have the part number? I did pick up the RPM bumper, but I didn't think I needed to pick up the upper and lower AE "plastic" pieces from the NTC3 kit (or do I) Aren't the upper bumper pieces fromt eh NTC3 and the TC4 "identicle"???? as for the lower plastic piece, I noticed the the NTC3 piece is where the lower ginge pins mount to, but the lower piece on the TC4 is strictly for the bumper....
The part # for the grommets is 2232, it is also the part # for the AE large plastic front bumper also.
Charlie O is offline   Reply With Quote
Old 11-17-2004, 08:26 PM   #1634
ghoppa's Avatar
Trader Rating: 48 (98%+)
thanks Charlie O!!!!
ghoppa is offline   Reply With Quote
Old 11-17-2004, 08:47 PM   #1635
Scrad's Avatar
Trader Rating: 15 (100%+)
I'm putting my kit together and the damn hinge pins are bent. What junk. Are the TC3 hinge pins the same sizes? I think I may get some lunsford ones.
Scrad is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
