Old 11-16-2004, 07:07 PM   #1591
Send a message via AIM to Javen13 Send a message via Yahoo to Javen13
yeah i am suprised associated didnt do anything about there wheel nuts the stock ones are kida big and stick out the low profile one are nice
Javen13 is offline   Reply With Quote
Old 11-16-2004, 07:08 PM   #1592
RCknight's Avatar
Default 2nd pratice night...
car hooked up well other than some over steer. Need a swaybar and lightened outdrives. Broke several rear wheel hubs. Slow glancing impacts. Don't get the molded graphite wheel hubs. No front arms broken after putting on the NTC3 bumper. The car works well for small tight carpet tracks. So far, I'm pleased, considering I have not used all my tunning options. I'll get some of the new Losi's shocks when they come out. Otherwise the foam dampers are working well for this track.
RCknight is offline   Reply With Quote
Old 11-16-2004, 07:13 PM   #1593
RoNTC3's Avatar
Send a message via AIM to RoNTC3 Send a message via Yahoo to RoNTC3
Default NTC3 Bumper
So... does the NTC3 (RPM) bumper fit? I was wondering when RPM was going to put one out for the TC4.
That was the best upgrade I made on my TC3
eXpress Motorsports * FOLLETT Motorsports * Final Thoughts Racing
Remember, half the people you know are below average.
RoNTC3 is offline   Reply With Quote
Old 11-16-2004, 07:22 PM   #1594
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
You can use the RPM NTC3 front bumpers on the car. However you will need the rubber grommets or whatever they are called to secure it. You might be able to get something at the hardware store instead of buying the complete NTC3 front bumper.
Kraig
KT Hobbies
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-16-2004, 07:26 PM   #1595
RoNTC3's Avatar
Thanks Kraig, by the way, I just ordered from K&T yesterday for the first time. Looking forward to many more!
Old 11-16-2004, 07:39 PM   #1596
Default Re: NTC3 Bumper
you may want to send an email to this guy kevanichko@columbus.rr.com
He makes a wide front bumper that's a direct replacement for the stock bumper. I have one on my car. I've used his bumpers in the past on my TC3. It's takin' a beating and is still in pretty good shape. And it has TC4 carved into it (makes it look a little cooler)
DOTMAN is offline   Reply With Quote
Old 11-16-2004, 07:56 PM   #1597
ghoppa's Avatar
Trader Rating: 48 (98%+)
anybody willing to post a picture of their RPM NTC3 front bumper for "us" to see?????
I am very interested to see the size "grommet" you all used...
I too, would like to make this mod on my TC4...
ghoppa is offline   Reply With Quote
Old 11-16-2004, 08:00 PM   #1598
Have a check back through the thread, there were some pictures posted a while back.
Andy M is offline   Reply With Quote
Old 11-16-2004, 08:07 PM   #1599
Charlie O's Avatar
Default NTC-3 front bumper
It's all just nitro TC-3 stuff & an RPM Nitro TC-3 plastic bumper!
first get a nitro TC-3 front foam bumper & the nitro TC-3 front bumper grommets, then just get a RPM nitro TC-3 plastic bumper or a Associated nitro TC-3 plastic bumper, it fits right on!
Charlie O is offline   Reply With Quote
Old 11-16-2004, 08:08 PM   #1600
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note that we got our entire shipment of TC4 parts in stock (hop-ups and spares) and we should have a very complete line of TC4 parts by tomorrow morning.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 11-16-2004, 08:18 PM   #1601
ghoppa's Avatar
question,
Charlie, I was @ my LHS "lookin" through a NTC3 manual, and I did not notice the "grommets" for the bumper anywhere in the instructions....whould you happen to have the part number? I did pick up the RPM bumper, but I didn't think I needed to pick up the upper and lower AE "plastic" pieces from the NTC3 kit (or do I) Aren't the upper bumper pieces fromt eh NTC3 and the TC4 "identicle"???? as for the lower plastic piece, I noticed the the NTC3 piece is where the lower ginge pins mount to, but the lower piece on the TC4 is strictly for the bumper....
Old 11-16-2004, 10:47 PM   #1602
RCknight's Avatar
Default I'm having a problem with...
the NTC3 bumper on my TC4. The RPM plastic bumper keeps bending down and the center pops up. Anyone know who makes a hard NTC3 foam bumper? Perhaps this will keep it from popping up and the front bending down.
Old 11-16-2004, 11:06 PM   #1603
RCknight's Avatar
Default Anyone else have problems with...
the center shaft? I think it my be too long and it does not float as much as the TC3 one did. I noticed the shaft ends were scuffed from the screws in the drive cups. Screws are tight and the foam pads are in place. I noticed the shaft pushed through the pads. I pushed in the cars ends and it binds the shaft. It does it in alittle less than 1mm. Anyone suggest a fix?
Old 11-16-2004, 11:12 PM   #1604
JDM_DOHC_SiR's Avatar
Trader Rating: 30 (100%+)
Default Re: Anyone else have problems with...
Use a soft O-ring on them... vice the foam spacers... or you can swithc to the TC3 drive shaft and cups
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64d
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-17-2004, 01:18 AM   #1605
Bob Nilsen's Avatar
Couple comments on the Nitro bumper mod:
As charlie o just said, you can use the stock NTC3 bumper *or* the RPM NTC3 bumper.
Not being familiar with the NTC3 I read the above posts and thought I had to order the RPM bumper. I also bought the stock NTC3 bumper to get the rubber grommets, and if I knew then what I knew now, i'd just use the stock NTC3 bumper.
With either bumper I found that I had to dremel off a bit of the middle hole in order to get the bumper to lie flush on the bumper mount. I had to remove a bit more material in order to get the bumper to not collide with the front suspension mount block on impact. I suggest you guys take a look at this when doing this mod.
ghoppa: The grommets are part 2232
Bob Nilsen is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
