Team Associated TC4
#1561
Tech Legend
Trader Rating: 51 (100%+)
Re: Re: Re: Re: Re: Re: Nice car
Originally posted by JDM_DOHC_SiR
Send me the parts I can get them done
#1562
Shiming Blocks on Carpet.
Are most people removing the Block Shims when running on carpet?
#1564
I had to do a little work with mine but they definately are better than the "old" TC3 ones. Make sure you pay attention to the shimming. I have one shim next to the pinion on front and rear shafts and two on the other side of the case.
Plastic Diffs = 2 shims on long outdrive
Steel Diffs = 4 shims on long outdrive
#1565
Scrad: You shouldn't have to do any blueprinting on the gearbox cases...I say shouldn't but....
#1566
Hey Tony
Just wanted to say thanks for coming out this past weekend to SRS. It was fun running against you guys. I didn't get to say thanks before you left. Being able to see your battery thru the body was awesome
#1567
#1568
What's the best source for ceramic bearings for TC3/ TC4.
Someone that will post world wide.
#1569
Check out the new videos in
www.radiocontrol.gr
There are some close ups of TC4s.
First there is one which I cannot remember to whome it belonged and then there is Barry's beautifully built TC4 with new shocks.
In the last video you can watch Marcīs best two laps of the whole event, a 12.5 sec. followed by the lap record 12.4 sec.
www.radiocontrol.gr
#1570
shocks.
I just bought this kit yesterday and I already feel hate for it. lol
Being w/ bag A. I've built a few kits. anyway. The shockcap when I go to tighten down the o ring comes like halfway out of the shock and it's not even tight. what's going on? and also one of the shocks is leakin out the bottom. what is the deal w/ this. lol. I've to it assembled right w/ the book.
#1571
ceramic bearings
-Boca http://www.bocabearings.com/
#1572
ive never had any problems with it leaking did you put the o-ring on the shock body or inside the shock cap
#1573
I also have had the same problem with the shocks leaking. I followed the book step by step and they still leak. Not sure what is going on with them.
#1574
I've built mine without the top/cap O-Rings and I've had no leaking at all.
#1575
Re: shocks.
