Like Tree26Likes
Old 11-12-2004, 10:40 AM   #1516
Paul_TC4's Avatar
Send a message via AIM to Paul_TC4
Dotman, I said previously that I turned it to 85% which is the correct setting. I did turn it down to 45% which stopped it but the car would barely turn.
Paul_TC4 is offline   Reply With Quote
Old 11-12-2004, 10:46 AM   #1517
Ah...I turned mine down which got rid of the chatter and my car still had plenty of turn in. Actually, removing some steering made me faster too.
DOTMAN is offline   Reply With Quote
Old 11-12-2004, 01:42 PM   #1518
lazyboy's Avatar
Send a message via AIM to lazyboy
Originally posted by RC Driver Gary
Did you look at the setup I posted before you said you thought it was a foam setup? It says right on there he used Yokomo tires and inserts....it was a rubber setup man. The Novak Race was all rubber tire until 2003 0r 2004. sheesh
sorry gary....i didnt see it, ill make sure ill before i speak
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 11-12-2004, 02:35 PM   #1519
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
I punched the stock pins out of the driveshafts that come with the kit, and put IRS pin cushions in - it is a perfect fit.
Josh
Speedo is offline   Reply With Quote
Old 11-12-2004, 07:55 PM   #1520
rcinsight's Avatar
I finally got to drive my TC4 tonight.
The track finally opened up and I had to familiarize myself quickly with the new car before the race.
Right off the bat, I put on the 2 degree rear mount.
The front end was too heavy with the batteries up front when running the oval course so I shifted the batteries back to unweight the front somewhat.
The little bit of traction compound on the fronts proved too muchand caused some chatter in the inner front tire and I did not add any for the rest of the evening. Smooth running from there on.
The springs from my FT TC3 were eventually replaced with softer springs.
The car was a blast to drive and I look forward to practice next week.
rcinsight is offline   Reply With Quote
Old 11-13-2004, 01:56 AM   #1521
bubbles's Avatar
Default Re: Re: still waiting for....
Originally posted by JDM_DOHC_SiR
Next week possibly..?? ..
Tony and insite on this.???
-Dave
*Cough* *cough*. They're on my car right now.
I installed the thickest swaybars, to make sure that everything fit properly. The bars had a slight issue fitting into the aluminium ball studs. There were many burrs still inside the part. I figure that even if I don't end up using the Gold bars, at least they would fit if I wanted to try...
After measuring 0.080in sway bars, they're darn thick! I mean, with my silver springs, I can lift up the right tire, and the left tire rises!(I am assuming 0.080, because I got three different sizes... )
I also noticed that the bars seemed to be poorly cut. It's not too much to worry about, because my kit was kind of fresh, along with being the thickest bar being used...
Tomorow will yield much testing with the new stuff. YAY!
Jay, SoCal tomorrow?
Boomer, SoCal tomorrow?
Dave, I need to send you a PM. I'll talk to you in the morning. Too tired right now.
bubbles is offline   Reply With Quote
Old 11-13-2004, 04:01 AM   #1522
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Tony P.
Thanks for the help. Don is on the ball. I called him on Monday had my new parts on Friday. Even with Thursday being a holiday! That is what I call fast!
Thanks,
CRASH is offline   Reply With Quote
Old 11-13-2004, 04:58 AM   #1523
i.a.s's Avatar
Default Cvd's
One idea for the chatter of the cvd's is what i had and that is thread lock, one of mine was binding, just strip the cvd down just rub the inside of the axle and the coupling with some very fine wire wool this removes any tread lock and be careful when you rebuild them back up that should sort out the problem.
i.a.s is offline   Reply With Quote
Old 11-13-2004, 10:28 AM   #1524
diskostew's Avatar
Send a message via Yahoo to diskostew
Default Re: Re: Re: still waiting for....
SWAYBARS! yes i need some...
as far as socal... I am going to try to make it. I blew out both of my rear shocks in practice thursday... it is kind of mind blowing. all the time i was running tc3's i never blew out bottom seals. and on thrusday i blew out 2! both on the rear shocks... weird... oh well. I will make it out to socal if the wife don't freek if not i am going to try to make it out to La Mirada tomorrow...
If i don't run tonight I might just stop by to hang out for a bit...
diskostew is offline   Reply With Quote
Old 11-13-2004, 01:15 PM   #1525
RoNTC3's Avatar
Send a message via AIM to RoNTC3 Send a message via Yahoo to RoNTC3
Default ESC Problem
Hey guys, I just took my v7.1 out of my TC3 where it has been working fine and put it in my TC4. With the switch off, when I connect the batt the red led comes on and stays on. Turning the pwr switch on makes no difference and pressing the set up button makes no diff.
Any Ideas what happened??????
eXpress Motorsports * FOLLETT Motorsports * Final Thoughts Racing
Remember, half the people you know are below average.
RoNTC3 is offline   Reply With Quote
Old 11-13-2004, 01:19 PM   #1526
rcinsight's Avatar
DO you still have the manual?
www.RC10.com will have the manual to download.
Check for a loose wire at the switch.
Old 11-13-2004, 02:45 PM   #1527
RoNTC3's Avatar
[B]
Thanks for the tip on the switch. It had a broken connection inside the plastic switch housing.
Old 11-13-2004, 03:16 PM   #1528
rcinsight's Avatar
Thumbs up
Yahooo!
Easy fix.
Take care of that ESC and it will last a longtime.
Old 11-13-2004, 03:43 PM   #1529
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Hell yeah, I love the 7.1 in TC, one of the best speedo's I've ever owned.......except for the one I swim in...lol JK, you wouldnt wanna see that I'm sure, I know I wouldnt
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 11-13-2004, 05:00 PM   #1530
edseb's Avatar
Paul_tc4:
The binding on your cvds is something I was warned of. It has something to do with the pins. I switched while building the car and never had that problem. Alos, in the rear, go with the aluminum outdrives on the diff. I had problems initially with the rear diff (sounds like different problem), but when I put in the aluminum and different CVDs in back, I haven't experienced problems. Luckily I was warned up front.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Joe Maxey
