Like Tree18Likes
Old 03-11-2017, 01:48 PM   #15121
IndyRC_Racer's Avatar
The TC4 tub chassis cars are a good entry level vehicle because they are very durable. The only real weak point on the TC4 is the steering rack. If you have been racing/bashing this car for a while, you've probably broken your steering rack in half. This is caused because the stock foam bumper doesn't extend all the way to the wheels on the car. If you are running wide tires (VTA) it is easy to catch the tire on a barrier and transfer all the energy which breaks the rack. The easiest solution to this problem is to buy a wider foam bumper.
A good option for a replacement foam bumper is the Parma Universal Ultimate bumper (Parma part #PAR8052). Here is a link on A-main and they are in stock...
https://www.amainhobbies.com/parma-p...par8052/p33910
If you didn't click on the link, basically it is a light dense rectangular block of foam. There are probably other manufacturers that sell a similar universal bumper. Any bumper that extends all the way to at least the middle of the wheels would be a good option. Obviously if you buy a rectangular block of foam, you will have to trim it to fit your car/body.
If you search youtube, you can find plenty of videos on how to easily trim foam rubber pieces using either an electric carving knife or a hot wire cutter.
Another bumper option for the front of a TC4 is to use the hard plastic wide bumper made for the Nitro TC3 (NTC3), which is only $5 USD. Here is a link on Team Associated website to the wide bumper AE#2232 ...
https://www.teamassociated.com/parts...h_rubber_pads/
If you clicked that link, you will have noticed that there is a hard bumper and 3 rubber grommets. So how does this mount to a TC4?
Below I've attached a few photos of a similar NTC3 bumper made by RPM that I'm using on one of my TC4's. You will see that the grommets on the TC4 bumper go on the posts where the stock foam bumper mounts. To use a NTC3 bumper on a TC4, you will also have to modify/trim down the stock foam bumper. This is a decent trade-off for having a very wide bumper that should protect the front end components from any spirited driving someone might want to do.
Note: I believe the RPM NTC3 plastic bumper is discontinued. However, I've been able to find several available on eBay when I searched today (3/11/2017). Be advised that the RPM NTC3 bumper DOES NOT come with the rubber grommets/bushings and the only way to buy them is to purchase an AE NTC3 bumper. However, I'm sure that you could find something at a big box hardware store to use as a substitute.
Hope this info helps.
Team Associated TC4-rpm-ntc3-bumper-mounted-tc4.jpg   Team Associated TC4-rpm-ntc3-bumper-stock-rubber-bushings.jpg
THEBIGBULL and RotorTruck like this.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 03-11-2017, 02:30 PM   #15122
One final post about TC4 bumpers...
In the picture below you will see 3 different TC4 bumper configurations.
170mm wide - Left (Team TC4 w/TC3 shaft) - Parma Ultimate TC4 bumper (discontinued)
140mm wide - Center (FT TC4) - Stock TC4 foam bumper
170mm wide - Right (Club Racer TC4) - RPM NTC3 plastic bumper with hard TC4 foam bumper (140mm)
As you can see on the middle chassis, the stock foam bumper doesn't even extend to the edge of the a-arms. The other issue is that it is a softer foam, so it will deflect more in a head on collision.
Old 03-14-2017, 11:16 AM   #15123
RotorTruck's Avatar
You could also use a Associated 2232 Wide Front Bumper With Rubber Pads NTC3
with a normal TC3 foam bumper 3852
And that RPM wide bumper sure is sweet.
-Brad
RotorTruck is offline   Reply With Quote
Old 03-15-2017, 11:26 AM   #15124
So speaking of all those shims. I was looking at where the links are mounted plus what AE has as the default set up sheets and there seems to be a shim discrepency. Does anyone know what the default number of ships are under the ball stud for the front and rear turnbuckle links and everything else. This is for a Club racer, tub chassis.
djgrom is offline   Reply With Quote
Old 03-16-2017, 09:48 AM   #15125
The following setup sheet if you open it says it is the stock setup for the TC4 Club Racer.
https://www.teamassociated.com/pdf/c...edit_2007b.pdf
It shows that there are 2 ball stud washers under the inner camber link ball studs.
I forgot to mention in my TC4 bumper posts that a NTC3 foam bumper (AE #2227) should also work on the TC4 since they share the same upper plastic bumper mount (3 post).
Here is a link on their website for the bumper. It lists for $5 USD.
https://www.teamassociated.com/parts...7-foam_bumper/
(EDIT)
I recently tore down a TC4 to clean/rebuild it and make sure the suspension/drive line was free. I took my time and made sure everything was right, but I was working late into the night. This morning I looked over the car and realized I used 2 left side camber blocks on the car...DOH! Not sure the car would have handled well with positive camber on the right front.
Old 03-19-2017, 11:40 AM   #15126
32819toon's Avatar
I'm looking to upgrade my tc4 rtr. Will the tc6 shocks fit ? My plastic ones leak oil really badly.
Also, do the tc6.2 ucjs fit or will I need to use tc6.2 caster blocks ?
I've been racing for quite a few years and got the tc4 which I'd bought for racing outside, and am using it indoors on carpet. So far I'm impressed with the handling and how quick it rotates through tight corners & chicanes.
32819toon
VBC Wildfire D08, Yokomo BD7 RS, Schumacher Atom, Tamiya M03, M05 (outdoor Mini), M03RWD, MF01-X, BSR M-Rage, ABC Gambado, Associated TC4 (outdoor car).
32819toon is offline   Reply With Quote
Old 03-19-2017, 11:44 AM   #15127
I recently replaced my shocks with these TRF shocks.
Tamiya, 55mm TRF Special Damper Set (Hard BK) ,(42102)
They are the best shocks Ive ever built. had no problems building them. the rebound was equal across all 4 shocks first time around and my old shock springs fit perfectly.
Shop: https://www.shapeways.com/shops/tech-innovations
PJRacer is offline   Reply With Quote
Old 03-19-2017, 04:10 PM   #15128
gigaplex's Avatar
The DCV axles won't fit the TC4 without at least replacing the front knuckles and bearings. There have been a few posts on this subject in this thread, try having a look back.
gigaplex is offline   Reply With Quote
Old 03-19-2017, 05:06 PM   #15129
I have created new front hubs and hub carriers (replaced C-Hub) for the TC4 to use the TC6 DCV. I have had some good luck during my testing so far with the ones I made at home. I am just waiting for my final prototypes to arrive so that I can be sure the bearings fit snug before making them available for sale.
check out these links for details. I can post pictures tonight of my DC4 with my new hubs and hub carriers
https://www.shapeways.com/product/V5...dcv-conversion
https://www.shapeways.com/product/SL...dcv-conversion
THEBIGBULL and Aaron P like this.
Old 03-19-2017, 08:51 PM   #15130
okay, here we go with the pictures of my steering upgrade. This upgrade allows a tighter turning circle using the TC6/7 DCV and my custom designed steering hubs.
Final product will be better quality printed arms due to laser printing from Shapeways. The hub carriers in the picture was printed by shapeways. I will post a picture when the arms arrive and a couple of weeks.
The 3D printer parts are quite strong and durable
Team Associated TC4-steering21.jpg   Team Associated TC4-steering22.jpg   Team Associated TC4-steering23.jpg
Old 03-20-2017, 01:39 PM   #15131
32819toon's Avatar
Thanks gigaplex & pjracer.
PJ- are you planning on taking orders ?
Will tc4 dcjs fit ?
32819toon
Old 03-20-2017, 03:30 PM   #15132
Will tc4 dcjs fit ?
These will be available for order in the next few weeks. They are designed to use the TC6/TC7 DCV's with a spool.
Old 03-20-2017, 04:02 PM   #15133
gigaplex's Avatar
Will tc4 dcjs fit ?
Which TC4 DCJs are you referring to?
Old 03-21-2017, 08:15 AM   #15134
32819toon's Avatar
Sorry, I meant tc6 dcjs
32819toon
Old 03-21-2017, 12:37 PM   #15135
With a 55 tooth spur can a 3.2 to 3.8 fdr fit in the FT TC4?
Another words, what is the best spur to use for this fdr range. I put a 60 tooth spur and a 45 tooth pinion, but it was a royal pain to install.
SouthFloridaApp is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
3 x a charm
