Old 03-11-2011, 06:52 AM   #1
Trader Rating: 45 (98%+)
Default Newb to TC On Road Racing!
I picked up a nice FT TC3 roller for a very good price and I figured this would be a great entry into the novice 17.5 spec class racing. I put in a Novak 17.5 SS setup.
I am trying to figure out the age old question on gearing.
The IGR is 2.5 and the spur/pinion I am running right now is 72/25 or 75/25 I forget. Either way the FDR is not working with our twisty layout and a long straight. The FDR on my current setup is 7.20 or 7.50...I need it in the mid 5's.
Attached is the gear ratio chart from Associated. But I see nothing to gear in the mid 5 range.
Can anyone help a newbie out?
Thanks in advance!!
alexchen86 is offline   Reply With Quote
Old 03-11-2011, 07:01 AM   #2
olhipster1's Avatar
Trader Rating: 88 (100%+)
Send a message via Yahoo to olhipster1
This should get you closer.
Spur gear / (divided by) pinion = #.##
#.## multiply by IGR (2.5) = Final
80/40 = 2.00 X 2.5 = 5
Side note: I always use 64 pitch spurs and pinions .
put should be same with 48 pitch. anyone confirm!
Gear to run cooler, if you're looking mid 5's then gear closer to 6 and then run for a few minutes and temp the motor...then work from there.
Welcome to onroad, and please have fun....remember the worst day of RC is always better than a good day at work, unless of course you're work as a bartender at a strip club
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
olhipster1 is offline   Reply With Quote
Old 03-11-2011, 07:07 AM   #3
pejota's Avatar
Numbers are the same, i think it's just the diameters and availability of the gears that's different between 64 and 48 pitch.
BTW, you may want to go as low as 4.5 or even 4.0.
You'll figure it out after a few weekends.
pejota is offline   Reply With Quote
Old 03-11-2011, 07:33 AM   #4
tc3team's Avatar
Word of warning about gearing.
Always check the heat of the motor after 2 minutes too after you change your gearing.
As you are new into r/c, it would be costly and disheartening to ruin a motor - it is for anyone!
It is good that you are asking questions though, as there are plenty of them... 15 years of racing and I still find many of them to ask
Sounds like the gearing has already been covered, once you have worked out what gear ratio you need and if your budget allows, buy pinion gears one tooth bigger and smaller each side of your preferred ratio for a bit of flexability/tuning.
have fun
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
newb needs onroad advice please blindnoob Electric On-Road 11 04-01-2010 03:21 PM
Newb to On-road TRXRustler33 Electric On-Road 8 11-01-2009 08:45 AM
ROAR to 4 cell.... Advil Electric On-Road 1394 12-21-2006 09:50 PM
SEO by vBSEO 3.5.0
