Old 03-05-2011, 09:31 AM   #1
Robertcooper88's Avatar
Default Gear diff benefits
Can anyone tell me the benefits in using a gear diff over a ball diff in the rear. Also, when should a gear diff be used over a ball diff in the rear.
In the front, why would you use a gear diff in place of a spool, onecway etc?
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 03-05-2011, 10:04 AM   #2
ok, well a gear diff needs a lot less maintenance, it can also be loser without slipping, there for giving you more grip, 99% of the time you use a spool so you dont understeer, if you put a diff in the front and turn left it could give the left wheel more grip so your pushed into a straight line there fore giving understeer, i would only reccomend using it on an open flowing track
Schumacher MI4 is offline   Reply With Quote
Old 03-05-2011, 01:12 PM   #3
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
A gear diff does not slip in any way. All of the torque transfer is done by gears, not by friction of rings on balls like a ball diff. As a result, none of the motor's torque goes into slipping the diff pulley/drive gear relative to the outdrives. If you setup the car properly, and do not let the inside tire become too lightly loaded in a corner, you will be able to put more power to the ground than with a ball diff. As far as the handling difference, with a rear gear diff only, you will notice that the car will rotate/oversteer on-power more than a ball-diff. This can be controlled with thicker or thinner differential oil. The car will accelerate off the corner much harder than with a ball diff, so if you can make the car work with it, it will be faster.
USVTA Member #211
Yokomo BD7 (Mod TC), Corally Phi '07 (VTA)
Support Formula SAE - get kids into engineering!
Brian McGreevy is offline   Reply With Quote
Old 03-05-2011, 01:57 PM   #4
Weird - my experience is the other way around. In tight tracks with a lot of 180's, I feel that geardiff can be an advantage, as it can go through the 180's a lot faster. But this weekend I am racing on a more open track with almost no 180's, and I have swapped my geardiff for a spool.
I almost always use geardiff up front - but at the bigger tracks (like DHI Cup and this weekend's danish nats) I am using a spool.
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 03-05-2011, 05:04 PM   #5
I think the ultimate adjustable set-up is front spool/rear ball diff , as long as the ball diff is set right (ceramic balls, gooped bolt etc...) before race day!!! When traction changes you want a ball diff; messing with oil thickness is a pain.....Also how much rear power do you really need on the ground while turning? Most rear gear diffs cause oversteer even with a front spool! What about rotational mass??? I'll keep running rear ball diffs anyday.......
bertrandsv87 is offline   Reply With Quote
Old 03-05-2011, 10:35 PM   #6
kcunamay's Avatar
Trader Rating: 20 (100%+)
I believe that may be more towards setup and driving style. I run gear diffs in my T3 as I get sick of all the maintenance required for rebuilding the ball diffs. Not only am I faster, but its literally been worry free for me. I've also run f/r gear diffs in mod, as I got sick of the front drive cups breaking on the spool. With 200k weight oil in the front diff, it feels like a spool, but has been way more forgiving on the drive cups in the even of a bump. The acceleration is outstanding.
I have not experienced oversteer with my setup, rather it's been easier to apply power...sooner.
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 03-06-2011, 06:11 AM   #7
Default my setup
I run a rear ball diff with a front gear diff in my 416 and have found this to be a pretty reliable setup. When I first got the car it had real thick goop in the front gears, I washed that out and put in 1500 wt oil and found that freeing it up a bit up front really worked well for me, its stiffer than a ball diff but gives in a bump unlike a spool. I've run on 4 different tracks through the winter and havent found the need to change anything.
The rear ball diff needed rebuilding once and still works well after about 6 weeks, so pretty low maintenance and unless I wreck the front end whacking the wall. I havent needed any drive cups like the spools are prone to breaking.
JoeD. is offline   Reply With Quote
Old 03-06-2011, 06:46 AM   #8
Thunderbunny's Avatar
Trader Rating: 22 (100%+)
I run gear diffs front and rear in my 416X, and it works better for me. I run 1K in the rear, and 300K in the front which is almost like a spool, but is forgiving enough not to break spool cups. Front spools also tend to push off power, so if I need a little more turn in I prefer a gear diff. I race on carpet and asphalt with the same diff set up with no probs. Maintenance is minimal, and acceleration is great. I think every racer should at least have all three (gear,ball,& spool) on hand as tuning aids to figure out what works best for his/her driving style.
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
DeSoto Racing l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
SC10 which differential gear or ball??? cliffhanger Electric Off-Road 88 08-23-2014 02:46 PM
Gear Diffs for TC's.... PitNamedGordie Electric On-Road 45 12-04-2007 12:29 PM
Ball Diff, One Way, Spool tr1kstanc3 Rookie Zone 9 10-06-2005 07:53 AM
Spool benefits? KillWency Electric On-Road 65 08-02-2005 10:19 AM
SEO by vBSEO 3.5.0
