Old 03-03-2011, 04:40 PM   #1
Dadic 78's Avatar
Default HB Cyclone TC A-arms?
Anyone know of another set of A-arms that will fit the HB Cyclone tc? The arms that it comes with seem to break rather easily...
Dadic 78 is offline   Reply With Quote
Old 03-03-2011, 06:48 PM   #2
olhipster1's Avatar
Trader Rating: 88 (100%+)
Send a message via Yahoo to olhipster1
Default try the pro 4
did you try the pro 4 arms?
it doesn't have all the shock mounting holes but appears to a little bit more durable.
I was sizing up the photon arms...which look they would work..but you would have to change to a full Xray or Photon front end.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
olhipster1 is offline   Reply With Quote
Old 03-03-2011, 07:06 PM   #3
Try the "high traction" arms from the Cyclone S.. they have a little more flex to them and are more forgiving.
Serzoni is offline   Reply With Quote
Old 03-03-2011, 09:30 PM   #4
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Default cyclone arms
I have only broken 1 arm in time I have driven my cyclone. I am surprised that you are having trouble. The olny other tougher arms sean to be the x rtay ams on the t2 008 i ran.
High speed crashes? all aluminium front end?
Jaz406 is offline   Reply With Quote
Old 03-04-2011, 03:14 AM   #5
Mike Haynes's Avatar
The tamiya 415 reversible front arm is the same length and offset, you just need to drill the hubs for a thicker hinge pin.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-04-2011, 03:26 AM   #6
warnos's Avatar
I have run the Graphic Arms from the Original Cyclone and Pro 4 and they are heaps stronger allot thicker in the place that the TC/TCX ones break.. but have a bit of sweep built into them..so ur setup may change a bit.. if u break them u will break anything..
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
HB cyclone TC VS. TRF416 PAO_F Electric On-Road 20 09-20-2009 09:19 PM
HB Cyclone TC worthy? Aprila Electric On-Road 45 05-10-2009 11:55 PM
HB CYCLONE TC REAR TOES CHASSIS WRONG? frk Electric On-Road 24 03-30-2009 07:31 AM
SEO by vBSEO 3.5.0
