Bench Testing???????????
You can use a dyno to test motors. ESCs are a different story.
It would take some setting uo but you could turn the SP motor checker into a dyno and do both. It controls the motor through any ESC so you can test settings as well.
But as it has been said before.... The dyno tells only a part of the story. Its the results you get on the track that are the only indicators you should use.
http://www3.towerhobbies.com/cgi-bin...&I=LXAGTT&P=FR
Will check motors.....
I have some of the speed passion units, that do the same thing but they need an ESC to work, but you can also then test the ESC too.....
Later EddieO
Later EddieO
how would you test them with this if its reccommended not to free spin brushless motors?
Mount a fan on it I guess....
However, thats not the requirement on all motors.....seems mainly novak. I've spun up speed passions, trinitys, LRP, with no issues.....you can go on youtube and watch the speed passion motor tester spin up a motor with no load.
Might just be another novak design flaw...
Later EddieO
Later EddieO
Keep the voltage down. Even a Novak should be able do free run at 3 volts. Start throwing 8 volts to them and things might start exploding.
Got a couple 3.5 bladers I think Illpass on lol.
Later EddieO
Later EddieO
Gotcha .... makes sense
