Carpet touring setup. >
Old 02-25-2011, 06:16 PM
Driftster's Avatar
Trader Rating: 15 (100%+)
Default Carpet touring setup.
Any general guidelines for caster and camber? Maybe even ride height. I know all setups are different but there must be a "rule of thumb" Thanks Jason
Driftster is offline
Old 02-25-2011, 08:16 PM
SammyZ's Avatar
Trader Rating: 138 (100%+)
jason,
try this:
Front
Camber: -1 degree
Castor: 4 degrees
Ride height: 5mm
droop: any value
Rear
Camber: -2 degrees
Ride height: 5mm
droop: any value
leave your shocks in the position they
are now. Try a 17-19in-lb spring up front
and a slightly softer spring in the rear.
Start here and tune from there.
SammyZ is offline
Old 02-25-2011, 10:36 PM
Here Jason, just another perspective.
Front:
-1.5 degrees camber
4 degrees caster
16-17lb spring
2mm of droop measured over ride height
5-5.5mm ride height
0.5-1 degree of toe out
Rear:
-1.5 degrees camber
14-15lb spring
5-5.5mm ride height
2.5-3.5 degrees of toe in per side
Good luck,
Danny
Danny-b23 is offline
Old 02-26-2011, 04:08 AM
Driftster's Avatar
Thanks guys!!
Old 02-26-2011, 06:39 AM
Chaz955i's Avatar
Front:
-1.5 degrees camber
4 degrees caster
16-17lb spring
5-5.5mm ride height
Rear:
-1.5 degrees camber
14-15lb spring
5-5.5mm ride height
Good luck,
Danny
+1 on the setting. Can't ignore droop unless you like having the back of the car pass the front going into turns.
Chaz955i is offline
Old 02-26-2011, 11:36 AM
The 2mm droop will at least get you close. The car may be a bit "taily" but at least it will be consistent. If you feel you need more rear traction, go to 3-4mm droop measured over ride height in the rear.
