Yokomo MR-4TC Mini Questions
I just got my Yokomo MR-4TC mini. I'm looking for somewhere that carries spare parts for it. Also, do the shock towers from the standard 1/10 fit on the mini? Any other valuble info would be great too! Thank in advance!!!
The shock towers that will fit are the MR-4 towers, I would go with the graphite towers.... One of the things I would suggest is the aluminum spur adapter... I don't care for the spurs that come with the car myself... Other than that I can't think of much else.... other than threaded shocks....
can you give me the part numbers for the shock towers & spur gear adaptor? Will that adaptor allow me to use standard 48p spur gears? Can I see a picture of your car?
I found a couple parts you may want to invest in....
Graphite Front and Rear Shock Tower - ZS-017TG Alumimum Clamp Wheel Hubs - ZS-011C Direct Drive Gear Adapter w/ Hard Pulley - ZS-630A Tuning parts Front Hub Carrier (5 Deg Caster) - ZM-413 Front Hub Carrier (3 Deg Caster) - ZM-4133 Front Hub Carrier (4 Deg Caster) - ZS-4134 Front Hub Carrier (7 Deg Caster) - ZM-4137 Rear Hub Carrier 0 Deg - ZS-415R0 Rear Hub Carrier 1 Deg - ZS-415R1 Rear Hub Carrier 2 Deg - ZS-415R2 Obviously springs would be good too.... It's all about how much you want to spend... It was fun here but it died really fast.... |
