Old 02-24-2011, 10:34 PM   #1
Brad.R's Avatar
Trader Rating: 25 (100%+)
Default Duo 2 Question
I had some problems with my duo 2 17.5 motor and took it apart to go threw it and a washer was busted inside, how many washers or spacers should be on the rear of the rotor against the sensor board? Also is it just the one big spacer in the front or am I missing something. There is alot of slack when I put the motor back and I dont want to try and run it like that. Thanks
Bad Brad Rutland
Memphis Missle
Ricky Retardo, (Don't lose that number)
Oops my bad, you were in my line..
You just got passed.. IN THE AIR!!
Brad.R is offline   Reply With Quote
Old 02-25-2011, 12:25 AM   #2
darrenoakley's Avatar
The shims/washers are there to place the rotor in the optimum position in the stator, so i think most motors will be different mate. To be honest a small amount of play you will find in most motors. I am sure your not the first person this had happened to.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Need Help on problem with Tekin 21.5 and Epic Duo 2 21.5 Cain Electric On-Road 10 01-03-2010 08:09 AM
Duo vs. Duo 2 patrick Electric On-Road 8 07-27-2009 02:45 PM
Hyperion 606i or 610i Duo Charger Question? wrxnfx Radio and Electronics 8 10-20-2008 04:20 PM
SEO by vBSEO 3.5.0
