Old 02-19-2011, 07:12 AM   #1
Default tire treatment
I was wondering what you guys do with new tires. Do you use them direct from the packaging or do you clean them first? here we use lrp27x and i notice that when you clean the new tire with tire cleaner, you are removing a layer of wax or something like that. is this wax good for grip or is it better with out it??
Corally_27 is offline   Reply With Quote
Old 02-19-2011, 04:33 PM   #2
Buckaroo's Avatar
Yeah, new tires need to be cleaned before running. This is what I do:
I clean 'em with denatured alcohol, then give them a spin on the tire truer and scuff sand the gloss off carefully. It's very easy to overheat the tires, and that's not good. Fist time on the car, double treat with traction compound (paragon in my case), and then about 5 minutes of zipping around the track to even them out.
Then they get cleaned again with denatured alcohol and they're ready for more paragon and racing.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Buckaroo is offline   Reply With Quote
Old 02-20-2011, 07:46 AM   #3
Trader Rating: 23 (100%+)
That waxy coating you noticed is a mould release that is left over from the manufacturing process and you want to clean that off for sure. After that, everyone seems to be doing something a little different. Scuffing them in with a tire sander is a good idea only if you know what you are doing.
Bonadona is offline   Reply With Quote
Tire Treatment Methods Bony85 Electric On-Road 26 03-05-2012 05:55 PM
Tire Treatment jjdoyle Electric Off-Road 18 09-10-2008 12:34 PM
SEO by vBSEO 3.5.0
