Orion R10 Pro.
#16
So I've just connected my Orion R10 Pro (2/3S) after using the 1/2S for about a year without any problem. But when I connect the ESC it doesn't respond to anything and starts blinking (red) with a beep sound. The speedo doesn't respond to the transmitter (but give's BEC through, cause the servo works), doesn't react on the Program Box. Doesn't react on the set-up button of the switch.
Anyone seen this before? The Trouble shooting page doesn't say anything about this behavior.
Some advice?
Regards Robert
Some advice?
Regards Robert
#17
After rereading it many times it almost sounds like you got a second system, I'm confused.
Their are tons of r10 threads in various forums but a quick search didn't give an answer.
#18
Which R10 Pro do you have ? the 65101 for 1s/2s or the 65102 for 2s/3s. When it was working correctly were you running 1s or 2s ? And now when it is not working are you running 2s or 3s ?
But I've found the problem. I made an internal short circuit with the receiver and switch wire. There was a large solder pin sticking out the Print Circuit Board, and when I rerouted the wire's and screwed the case on again, the pin punished one of the wires, making a short circuit, which made the speedo stop working (luckely the smoke stayed in ;-))
Thanks for the help.
Regards Robert
#20
Funny you mentioned that. I've managed to plug my wires reversely and turned it on. No smoke but the smell was definitely there. corrected the polarity and still ran. Did it once with my MMP. Let's just say I won't be using mamba again. Had the esc for about a year and some change and still TQ'ing and making the Mains. Orion's new slogan, " with quality so good even a toddler can use it".
#21
you will have blown the capacitors though,i was daft enough to do it and had to get new ones
#22
Some advice?
Regards Robert
Some advice?
Regards Robert
