Old 02-11-2011, 07:49 PM   #1
zzrguy's Avatar
Default What size rims do I need?
I have a TC-3 and I want use a 200 mm mustang body, I was told I need a 6mm offset and 26mm on front and 31mm in the rear, but the hobby shop did not have those sizes in stock. Could I use 31mm all the way around the car or would it be better to find the 26/31 combo.
What kind of tire glue do I need, thin or medium? Thanks
I am not Totally useless I can always be a BAD EXAMPLE!
zzrguy is offline   Reply With Quote
Old 02-11-2011, 11:16 PM   #2
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 34 (100%+)
0mm offset, 26mm fronts and 6mm offset, 31mm rears. Fills the wheel wells nicely and is VTA legal. Thin glue is easier to get down in the bead but is also easier to glue your eyelids shut with because it tends to run everywhere!
-rocky b
flatspunout is offline   Reply With Quote
Old 02-12-2011, 08:05 AM   #3
Trader Rating: 24 (100%+)
Is this for the 1965 or 1966 Mustang ?? If yes, then you need the 26mm o offset VINTAGE WHEELS in front and 31mm 6 offset VINTAGE WHEELS in back. I made that bold for a reason. The vintage wheels are specifically made for the vintage tires. The wheel has a different front lip made just for the vintage tires.
If this is for a later model 200mm body then most wheels will work and you have to experiment a bit. On my 200mm body choices, usually 3mm offset,26mm wheels in front and 6mm offset,26mm wheels in back.
Glue is your choice but I find the thicker, slower setting time glue to be a bit easier. I use a small paint brush to apply the glue around the inside wheel edge, then set the tire in place. Usually I do the front of the wheel first and let it set.Then I do the back. That cuts down on getting wet glue all over the tire.
Evoracer is offline   Reply With Quote
what kinda truck should i get for a basher GRIMREAPER Electric Off-Road 33 07-20-2009 07:22 PM
tire and rim size not fitting desertbird Nitro Off-Road 11 05-22-2008 07:57 AM
off road electric getting some what interestin b-man777 Electric Off-Road 54 09-21-2006 06:10 PM
SEO by vBSEO 3.5.0
