Thoughts about rumores of a Losi XXX-S II
#481
XXX-S Bill,
Is the batt plate hinged onto the chassis?
I'm not understanding this battery mount design. It seems like those screws are going to strip out constantly with the use they are going to get. I wish they would've just went with the standard clips.
#482
Originally posted by Cardboard
XXX-S Bill,
XXX-S Bill,
Too bad the several posted pictures haven't show you the door. The JRXS design won't support standard clips; unless, they get really creative.
#483
I'm with you on this point about direct soldering; but, I didn't look at that part of the chassis enough to determine if the round tube connectors would work.
maybe that will work?
#484
Originally posted by Tom
have you seen how some people solder a battery bar, then bend it over the top of the cell and solder the round tube connector to that.
What you are describing is what I currently do; however, this won't work on the new JRXS chassis. The battery is sandwiched between the two decks with no potential of having a battery bar go anywhere above the pack.
Thanks for your thoughts.
#485
The solution would be to use the bent battery bar over the top of the cells with the pole connector soldered to this tab ..horizontally.
You can still use the pole connector they will give access from the side of the pack.
No worries Mr Harshness,/
Heres anothe car that is similar in concept as far as chassis layout (batts centers motor in front) EVO2 car
#487
Originally posted by HarshGuy
No worries ...if I have to direct solder like the big boys ...then that's what I gotta do
#488
XXX-S Bill- is the trap door hinged into the other side of the chassis?
Badboy RC- that car in the photo, it is made by PTI or something right?
#490
Originally posted by mashimaro
[B]XXX-S Bill- is the trap door hinged into the other side of the chassis?B]
#491
Go to Team Losi JRXS string
We are now beyond rumors about Losi's new car.
Can we all agree to end this string and go to the newer string named "Team Losi JRXS" to continue our thoughts? The two strings are getting pretty redundant.
#492
what the hell is this?
Hi Guys...
Have any of you seen this pic og the car?
Dude it look`s very strange... realy short arm`s
http://www.racerc.dk/news.asp?id=507
Don`t think it will ever work...
Just a my thougt =)
-Michael
TRF415
TRF414mII
TA04-R
Just a my thougt =)
-Michael
TRF415
TRF414mII
TA04-R
#493
Re: what the hell is this?
Originally posted by Michael_Gerner
Hi Guys...
Just a my thougt =)
-Michael
TRF415
TRF414mII
TA04-R
Hi Guys...
Just a my thougt =)
-Michael
TRF415
TRF414mII
TA04-R
#495
Hi Guys...
Just a my thougt =)
-Michael
TRF415
TRF414mII
TA04-R
Hi Guys...
Just a my thougt =)
-Michael
TRF415
TRF414mII
TA04-R
