Old 02-10-2011, 03:13 AM   #1
Trader Rating: 16 (100%+)
Default Suspension travel setup
I've seen lots of discussion about droop and downstops, but never anything about arm movement in the opposite direction. So... how about it? Is there any tuning to be done, or grip to be gained, by limiting or somehow extending suspension "uptravel"?
mahamoti is offline   Reply With Quote
Old 02-10-2011, 06:48 AM   #2
gubbs3's Avatar
Not really anything to be done. Nearly all designs ensure that under normal operation, you won't hit the max up travel. If you do, it negates all the tuning you do with springs and oil because you literally "hit" a barrier of travel, sending a shock of weight transfer to that wheel. Its very unpredictable. If you've ever heard of someone refer to a "snap-roll" this is sometimes where during a hard corner the suspension will hit the limit of up travel causing the tires to dig in and almost pole vaulting the car onto its lid.
gubbs3 is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
How to set suspension travel? Airflow Electric On-Road 7 06-18-2009 01:29 AM
Optimal RC10T4 Setup Dorion Electric Off-Road 9 12-09-2008 08:34 PM
Official Xray M18 ''setup'' thread maximebeauvais Micro and Mini Scales 7 09-06-2006 02:13 AM
SEO by vBSEO 3.5.0
