Ko Propo VFS-1 ESC
#841
I just ordered one of these speedos. Am I going to be less than impressed until I get the ability to program it myself?
#842
can anyone let me know what is/are the difference(s) between the vfs1 and the vfs2??
#844
From what I have seen on the KO website the VFS-2 is a budget version of the VFS-1 as there are less FETs in use.
#845
#846
Someone tell me, whats the deal with the programming function? Am I going to need that for sure or will it still work great with factory defaults? I race stock and 19t.
#849
Hello,
I raced this weekend and the track temp was almost 60°C. Me and a lot of my friends experienced troubles with the VFS1. After 4 minutes the esc cutoff because overheating. I've a 415, we run 12T motors. My esc is not too close to the motor. How can I avoid this problem. Does a heatsink exist foe this esc? Have I got to change the program? Or put a fan?
#850
Originally Posted by Hugo
Hello,
Ko Propo has addressed this issue by making the VFS-1 Competition edition. it has a higher temperature cut off and a trick carbon case.
#852
Originally Posted by flysti
thinking of buying the vfs-1 masami, i race stock so will i still have issues with it shutting down ( going into thermo). i think i would not have issues
but i just want to be sure.
thanks
thanks
#853
Originally Posted by Hebiki
ive only shut down the VFS-1 in 19T running a stock profile on a very hot track. (140 deg F track temp) you will be fine in stock (unless your car is really bad... i.e. binding drivetrain, way off on the gearing, etc) if you run into any problems. post here.. we'll help you out.
#854
Hugo... the esc is shutting down because it is getting too hot. there is a heat sink, but wont work as well if you are overworking the esc. also, check the gearing on your motor. if its off, it might overheat the esc. check your profile and if it is too low, lower the entire profile 3-4 stages at a time until it doesnt shut down anymore. a fan will help, but lowering the entire profile will help the most.
Thanks for the answer, when will the competition edition be available?
#855
I have a very similar Q to that...
Over the weekend I was running my VSF-1 on a large outdoor track with a 7 single and about 3-4 minutes into the run I lost power to the motor, if i stopped for a lap or so it would come back. So I am assuming I was just getting the speedo too hot? I figured the KO would catch fire before it would have a thermal shutdown but i guess not???
