Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 03-12-2008, 05:31 PM
  #2401
Uhm, what did you do? More details. I bet you reversed polarity on the batteries.
I don't think KO has any obligation to you. Yes it is an oem'ed product, but the simple fact is you didn't buy from KO. I don't see how KO has to service support another companies product. If you've had it for several months now, you're waaay past any warranties so you'll have to shell out the $$$ to have it fixed.
DirtyRacer is offline
Old 03-12-2008, 05:41 PM
  #2402
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
i had a 2.1 that i bought new put it in the car put two batteries through it and then nothing. the light was on but nothing else, sent it in they said it was not covered long story short they fixed it,it was a $5.00 part and after repair of $40 plus parts and shipping lets say i wasn't happy. so good luck
20 SMOKE is offline
Old 03-12-2008, 05:42 PM
  #2403
20 SMOKE's Avatar
if you send it to ko they will send it to japan and it will take 3 months before you get it back, i know
20 SMOKE is offline
Old 03-12-2008, 05:49 PM
  #2404
Actually no they won't. The real repair guy is back. He can service it in shop.
There is a point of no return when you fry these speedos. I've done it recently.
BUUUT check this out. I know for a fact you can buy the C2's directly from KOAmerica at a significant discount. Low enough to eliminate having your speedo repaired. Trust me on this. Contact Rob at KO.
Old 03-13-2008, 02:18 PM
  #2405
Tron 101's Avatar
Trader Rating: 23 (96%+)
Nah no reverse polarity, when your setting up a 200 dollars setup plus more, you tend to be finicky.
But what 20 smoke says, happenned to both my speedos! The light is on but NADA! On one of em the light is blinking but NADA.
I wonder if there may be a flaw in a bad batch circulating, cuz the second one , well to make things short and sweet, WOW Speed-DOH!
Anyway HB has wrote me back stating that I should send both of them in. YEAH, The customer has prevailed!WOOT.
Until I get the bill...
Oh well maybe they'll give me a two-fer, eh?!
Thanks for the input guys!!
Tron 101 is offline
Old 03-13-2008, 02:24 PM
  #2406
Tron 101's Avatar
Oh but as for frying or "thermal overload" notta chance, I have had all the necessary set-ups, capacitor ,shotky and heat sink, besides I never had the speed control get even close to being as hot as a motor, never.
The fact that i didn't see smoke was what tipped me off to it being a manufacturer defect. Anyway the warranty of any repair should be a minimum of 3 momnths, and the new Twister that was shot is only a month old, so....(fingers crossed).
I have actually been running Twister 2.1's in my tc and pan for around a year, I never had a problem with heat or shut downs, once I did have to perform surgery on the receiver J plugs but that was the extent of it.
Tron 101 is offline
Old 03-13-2008, 02:43 PM
  #2407
Good to hear they are gonna help you out.
One thing to try....it's a long shot. But maybe your transmitter setup was lost, try redoing the one touch setup.
If the bill is over 50...call up Rob at KO. trust me...you'll be glad.
Old 03-13-2008, 07:09 PM
  #2408
Tron 101's Avatar
Only the controller that has the constant light will go into the set up. But you cant do anything with an ESC that doesn't deliver power to the RX. It is weird that the esc shows its getting power but the RX shows no light? The RX works though.
Tron 101 is offline
Old 03-16-2008, 09:13 PM
  #2409
Maybe the switch is bad?
Old 03-17-2008, 12:31 PM
  #2410
quantum's Avatar
i have a multi setting adapter if any one needs one
you have pm
quantum is offline
Old 03-17-2008, 03:26 PM
  #2411
Ferrarimk13's Avatar
they are selling the C2 for less than 50$?
Ferrarimk13 is offline
Old 03-17-2008, 06:30 PM
  #2412
just contact Robert at KO America and ask him about the C2s speedos
Old 03-18-2008, 07:11 PM
  #2413
Nova F1 Racer's Avatar
Need some help/advice.... I've got a Twister 2.2 in my 12 scale and after I got t-boned last week the ESC acted strange and now it won't work right....
The thottle cuts in and out and I've tried to reset with no luck... Could it be the NOVAK capacitor?
Nova F1 Racer is offline
Old 03-18-2008, 08:01 PM
  #2414
Rewire the ESC completely and see if that helps. Also ensure that its not your transmitter/receiver cutting out.
Otherwise... you may have a broken esc
I know i am stating the obvious... but i hope it helps
rcnewb2004 is offline
Old 03-19-2008, 04:40 PM
  #2415
i doubt its the power cap, but you can try switching to the included one, and resetting it.
