Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 05-08-2006, 03:20 AM
  #1876
TO KO PROPO Staff
I broke the switch cover Can I get a new switch cover? Where can I order one from and what is the part numer?
Thnx
Gerd
Gerd is offline
Old 05-08-2006, 10:38 AM
  #1877
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Gerd
TO KO PROPO Staff
Thnx
Gerd
Gerd,
you can also email your request to Robert Morris (Ko PROPO Staff) at [email protected]
that way he'll get it faster... sometimes he gets very busy and isnt able to come onto rctech.
- Chris
Hebiki is offline
Old 05-08-2006, 11:26 AM
  #1878
Does anyone have a profile for a 17t motor on a high speed asphalt circuit?
Or can i use the 19t profile.
Thank you
Fred.
kruit is offline
Old 05-08-2006, 12:00 PM
  #1879
Trader Rating: 17 (100%+)
Anyone try hyper booster with VFS1 before? any inputs...thanks
EngTat is offline
Old 05-10-2006, 11:07 PM
  #1880
Hi im going to be running 1/12 4 cell and i wanted to no which
one of these speed controls would work better for that
KO PROPO VFS-1 Pro or the
KO PROPO VFS-1 Pro Competition Version
Matthew.H is offline
Old 05-11-2006, 12:00 AM
  #1881
Nicadrauspro4's Avatar
Both models will work well with your 1/12.
Nicadrauspro4 is offline
Old 05-11-2006, 02:51 AM
  #1882
Pro has a higher temperature cut off... so if u will run pretty hot... then pro will be better.
rcnewb2004 is offline
Old 05-11-2006, 05:47 AM
  #1883
Does anybody know how much higher the thermal cutoff is on the VSF-1 Pro Comp vs Pro?
I thought that Robert said that when you hit the higher thermal cutoff you may ruin the Pro Comp. Does anybody remember? Thx
Charles is offline
Old 05-11-2006, 05:50 AM
  #1884
Is there a chart that shows equivelent settings between the novak GTX and the VSF-1? For instance if you had a mod setting on a GTX that you like and wanted to use the same setting on the Ko?
Charles is offline
Old 05-11-2006, 05:59 AM
  #1885
the pro version does not have temperature cut off i believe
EngTat is offline
Old 05-11-2006, 10:24 AM
  #1886
The competition does have a thermal cutt-off but very high. If you do hit the thermal cutt-off on the competition, you might have already damaged something in the esc.
-Robert
KO PROPO Staff is offline
Old 05-11-2006, 10:28 PM
  #1887
That's what I thought you had said earlier, Robert. So I am using the pro only. I moved the cap and the super shotke off the top of the esc. Plus I have added a fan. I will see how that goes tomorrow
Charles is offline
Old 05-11-2006, 10:38 PM
  #1888
sorry, my twister 2.1 written it is not equip with thermal protection on a supplement notice i thought the pro comp version is the same as hara2.1
EngTat is offline
Old 05-11-2006, 10:58 PM
  #1889
thanks guys for the help
Old 05-12-2006, 10:46 AM
  #1890
That is called lost in the translation. It does still have a cutt-off, but if it is activated most likely something is damaged.
