Old 10-18-2011, 10:41 AM   #1396
dameetz's Avatar
Anyone here coming from Yoks BD5WR? How does it compare? Recently I ve been thinking of getting this S411. Which one is the latest version and where can I get it the cheapest?
Thanks.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 10-18-2011, 02:00 PM   #1397
Originally Posted by ronsand View Post
I expected that you would chime in! I will try rubber to begin with. It will for sure be a change as I've always been running on foam. I will add the 19t alu pulley to the "to order" list.
You tought so huh hehe You should get Sorex 28R Rubber(Mustit have these ones with JB Blues mounted) or Jaco Green 28Shore for tires. But you probably know this already if i know you correct
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 10-18-2011, 02:17 PM   #1398
ronsand's Avatar
I actually ordered these tires, but with a different insert.
I did not know Mustit had them, so I sent them a request for an extra round of premounted tires.
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 10-18-2011, 03:41 PM   #1399
mattwoodcraft's Avatar
certainly go with the alloy centre pullies a the kit moulded ones tend to wear quiet fast causing the pin to spin in side the pulley even in stock it wears it hard mod in no time the pin will be spinning
mattwoodcraft is offline   Reply With Quote
Old 10-18-2011, 03:44 PM   #1400
Thanks.
go the serpent its provin its self every where and the car is strong and when you make a change it responds well.
the gear diffs are bullet proof all alloy no moulded composit parts to strip
Old 10-18-2011, 04:23 PM   #1401
dameetz's Avatar
Yeah I m going to get it soon, is there a new package of the car, I mean I read some of you post about some V2 thing? If there is what parts are new?
Old 10-18-2011, 05:18 PM   #1402
hacker's Avatar
Trader Rating: 140 (100%+)
withdrawn
hacker is offline   Reply With Quote
Old 10-18-2011, 07:00 PM   #1403
chassi 2.25mm i beleive and the plastics are harder and you get a spur gear now which is quiet handy
Old 10-19-2011, 05:19 AM   #1404
zacabrandy's Avatar
Interested in this car, just a couple of questions if someone in the know wouldn't mind answering?
1. What chassis and top deck does this car come with?
2. What differences does the optional chassis plates make to the car (Ill be running on medium - low grip asphalt tracks)
3. For stock, can the rollout be achieved without any dramas?
4. What spares or option parts are generally needed or is this car good straight out of the box?
I may be able to purchase a kit second hand that is the 2.5mm chassis, it seems to have a top plate on it that doesn't have any holes cut in it, would this kit be too stiff for my above mentioned tracks?
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 10-19-2011, 04:13 PM   #1405
venom54's Avatar
Default S411 V1 V2
Cheers
Aaron
OK, after all the too and fro on this forum the specs as confirmed from the Australian importers.
V1 kits are the standard kits as supplied from SERPENT, 2.5mm chassis better plastics. new blades and spur supplied as standard.
V2 kits are a special request for the ASIAN market with a 2.25mm chassis as the only major change. All other specs are the same (so far). As we all know SERPENT will apply ongoing quality updates to all their kits. So if you are waiting to get the latest and greatest, you will be waiting a long time. Pick up the kit of your choice and enjoy....
Top decks remain the same from the info i have been supplied.
The 2.25mm chassis gives more grip overall and is a tuning option.
Depending on the track you are planning on driving on more grip could be a benefit or a downfall.
For stock, yes no dramas in attaining the roll out required. Use RW spurs from 64T 48DPI to 87T 48DPI. All available from any good hobby shop including ours.
No real options required unless you wish to experiment! The kit is brilliant out of the box. Tune to track conditions as required.
""Current S411 kits either V1 or V2 have all the same components apart from the 2.25mm chassis. Top deck is the same with tentioner mounting hole, chassis with pinion hole is the same, blades, spur and factory updates on the plastics the same. Currently building a 2.5mm chassis and have 2.25mm kits available with the only notable different being the chassis.""
As for your S/hand car questions. If this is a genuine untouched kit you will not have any problems in tuning for your track.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 10-19-2011, 04:30 PM   #1406
RC MARKET's Avatar
Cheers
Aaron
HK & China S411 is 2.25 Chassis ,
is better for rubber tire more flex in the top class.
2mm & 2.25mm was update to v2 , had more hole for motor pinion ,
updated right side battery area cutting & new carbon graphite more linear flex !
upper deck is v2 , had support serpent new belt tensioner .
The Blade , rear upright is V2 ,
& with spur gear .
today was sold out , next shipment next week arrive again !
RC MARKET is offline   Reply With Quote
Old 10-19-2011, 05:23 PM   #1407
damage's Avatar
& with spur gear .
So does the kit that you sell come with 2.25 or 2.5 thick chassis?
http://tinyurl.com/Wiocr
Tamiya Hornet, Airtronics XL2P, Novak 4, 1200 SC Stage III batteries,
Navcom 10 peak, 12 volt lead acid power source
damage is offline   Reply With Quote
Old 10-19-2011, 07:18 PM   #1408
crabboy's Avatar
Trader Rating: 57 (98%+)
RC Market is HK so 2.25.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 10-19-2011, 07:23 PM   #1409
venom54's Avatar
Default S411 V1 , V2 KITS
Removed duplicate.
Old 10-19-2011, 07:32 PM   #1410
venom54's Avatar
OK ,
Unpacked and checked the kit contents between the "V1" and "V2" speced S411 kits.
All parts are the same apart from the chassis. There are no other deviations in either of the kits.
Chassis holes are identical between the 2.25 and 2.5 chassis as well as the top deck. All holes including the belt tentioner mounting hole and pinion access holes are the same and included in both chassis.
The blades are the new versions and same plastic. Spur gear included in both kits.
If there are any further updates these will be posted here.
We now support the 2.25 version S411 and the standard 2.5 version.
Cheers
Ren
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
