Old 10-16-2011, 03:58 PM   #1381
mingnon's Avatar
Originally Posted by mattwoodcraft View Post
i also asked the same question from rcmarket, the best spurs if your running stock and they have all the sizes from 60-90 48p are the RW spur gears they are not off set like the xray ones and there is plenty of room for meshing and not running close to the belt i have been useining these and they are great RW spur gears
Matt
if possible (and its okay to ask) can you point me in the direction of someone who stocks the RW 48p spur gears, have been looking and cannot find any under 64tooth
cheers
---------------------------SMA The Home of GREAT Racing------------------------------
mingnon is offline   Reply With Quote
Old 10-16-2011, 04:40 PM   #1382
RC MARKET's Avatar
Originally Posted by xtaiji View Post
Belt tensioner?? My top deck has no hole
V2 had more hole !
RC MARKET is offline   Reply With Quote
Old 10-16-2011, 04:41 PM   #1383
RC MARKET's Avatar
Originally Posted by valtsu23 View Post
Any ideas when the delrin spool outdrive is available? Part number 401428.
Team Driver testing now !
Old 10-16-2011, 07:31 PM   #1384
mattwoodcraft's Avatar
Originally Posted by mingnon View Post
Matt
cheers
i beleive your in luck as i think they are made in the uk obviously i live in australia i will give your there web address
www.rwracing.co.uk
neil@rwracing.com.uk
hope this helps
mattwoodcraft is offline   Reply With Quote
Old 10-16-2011, 07:33 PM   #1385
i have spur hears from these guys as low as 60 teeth the biggest spur gear i use is a 66 but for my track is still to big i run a flat 4 FDR
Old 10-17-2011, 02:00 AM   #1386
mingnon's Avatar
Thanks Matt, im still learning local track, but most are running 2.8-2.9ish from what i can work out. Have just changed motors in mine and giving it a run tomorrow night, so will be able to work some more things out
Thanks for your help with the spur gears, really appreciate it
Old 10-17-2011, 04:10 AM   #1387
no probs it took me a while to find the rite spur gears to.
Old 10-18-2011, 04:40 AM   #1388
ronsand's Avatar
Default New to the serpent S411 club
Just pressed order on one of these (latest release with 2.25mm chassis) and I'm looking forward to try it out. At the same time I ordered the regular spare parts and a extra gear diff for the front.
Are there any other must have option parts I should fit when building the car, or is it OK right out op the box? I will be running indoor carpet.
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 10-18-2011, 05:24 AM   #1389
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i would get teh 3.5 rear toe plate for carpet. and use the 3 from the kit rear , and move that to the front F and use the 2 for Front R .
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-18-2011, 06:46 AM   #1390
ronsand's Avatar
If I understand you correctly then it should be like below:
FF: 3.0
FR: 2.0
RF: 0.0
RR: 3.5
Can you please explain with a few words the reasoning for these changes?
Does anyone else have an opinion on this?
I bought the spring sets so I should be OK there. What about the sway-bars for indoor carpet (rubber)? 1.4mm is standard on the car.
Regards Ronny
Old 10-18-2011, 07:54 AM   #1391
Pattojnr's Avatar
FF: 3.0
FR: 2.0
RF: 0.0
RR: 3.5
Regards Ronny
on the track i have run on, i found the extra toe in at rear helped wiht on power grip. the car has lots of steering. so to stop the car biting so hard at the front mid corner, i widened the track width. i even had on Blue front springs, which is very hard. but i think Red fronts would be better. rear bar i removed, front swaybar i used kit 1.4.
Serpent - Walter RC
Old 10-18-2011, 07:55 AM   #1392
jrxs-r's Avatar
Ronny,
Get the swaybar set as it is an important tuning tool. 1.8, 1.6, 1.2mm bars.
The reasoning for Patto's changes to the front is to widen it up and take away some steering. It can also be achieved somewhat by getting the +1mm offset wheel hexes.
Get some 0.5mm suspension block spacers too for the rear.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 10-18-2011, 08:39 AM   #1393
ronsand's Avatar
Thanks guys, much appropriated. I will order the 3.5 suspension mount, 0.5mm spacers and sway bar set.
Are you guys running a gear diff or the spool in the front? I was thinking to run the gear diff with thick fluid (300.000-600.000).
Old 10-18-2011, 08:59 AM   #1394
Hey Ronny finaly you came to sense Going to run rubber or?
You should get the 19T Alu pully, i noticed that the plastic ones got sloppy right away.
*Sanwa M12*Hitec*
*TLR Eight 3.0*Fusion X3LFM*
Team_Elli is offline   Reply With Quote
Old 10-18-2011, 09:21 AM   #1395
ronsand's Avatar
I expected that you would chime in! I will try rubber to begin with. It will for sure be a change as I've always been running on foam. I will add the 19t alu pulley to the "to order" list.
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
